C450/C43 AMG
Brakes and rotors
Old Aug 22, 2021 | 01:26 PM
Sommy's Avatar
C43
Brakes and rotors
I’m fairly sure my brake pads will need to be changed next servicing. The advisor told me when that happens my rotors need to be changed as well.
I go back to the dealer for servicing as I feel they do the best work and I had a bad experience at an Indy shop.
Whats a good price for brake pads and rotors for all 4? I have a 2017 C43. I believe they told me $1,050 when I asked before.
Bonus question - I need new tires and know they will push an alignment. I have about 50k miles, do I need an alignment yet? How much will that run?
Old Aug 22, 2021 | 01:30 PM
stockbmw's Avatar
2018 C43
Go to rockauto or anyother part store and price out your brake parts. Add 1 hr labor per corner (should be way less like 30mins) times that by what your local area charges say $100 per hour and you will get the norm.
Old Aug 22, 2021 | 01:41 PM
user33's Avatar
See: https://mbworld.org/forums/c450-c43-...ml#post8393883
Old Aug 22, 2021 | 03:31 PM
AMGiggity's Avatar
nothing
It is your money but I'd personally stay away from the Stealership. Look for reputable indies near you; there should be plenty in DFW.
Old Aug 22, 2021 | 07:16 PM
paj's Avatar
paj
17 C43 AMG
I second that! The dealership in Tulsa charges $165 an hour for service!
Old Aug 28, 2021 | 09:34 AM
Freder8d's Avatar
2017 AMG C43
Easy to do
Do them yourself. I did mine a few months ago and had no problems whatsoever. I was also able to paint the rotors while I had them off. And I went with these guys product.
https://www.r1concepts.com/
Old Aug 29, 2021 | 12:26 AM
Boostman76's Avatar
2016 C450 AMG Sport, 2018 GLE400
In need of pads here too...anyone know what the front rotor minimum thickness is on stock rotors? Mine have developed a deep lip on the outer edge so its tough to get an accurate caliper reading to see how thick my rotors are. Car has 95k on it and they seem to be original.
Old Aug 29, 2021 | 04:08 AM
TLADILA's Avatar
2017 Mercedes-Benz C43 AMG Sedan
You don't have to buy new rotors when you change your pads. At 50k miles I highly doubt you need to change the rotors, measure it or ask a shop to measure it before you change anything. To be honest I think dealerships have **** quality service but that doesn't mean the mechanic shops are any better. You either have to find a trusted place or do it yourself. I bought front break pads, rear pads, and sensors for $350 Canadian for my 2017 C43 and changed them in like 2 hours.
You probably don't need an alignment but if you notice the steering or suspension being off then you can go in for one. The dealership charges $300 something Canadian for AWD alignment. I wouldn't bother unless you notice something off.
Old Aug 29, 2021 | 04:12 AM
TLADILA's Avatar
Do you have 95k miles or km?
I don't know the minimum thickness but if you don't notice vibrations in the steering wheel when you break or other things like that your still good.
Old Aug 29, 2021 | 05:40 PM
W205C43PFL's Avatar
To add to forum member TLADILA, I came across this image posted by forum member user33 before, it is an image of the wear indicators on our rotors. As long as you don't reach such thickness, you should be fine.
Edit: Found original post > https://mbworld.org/forums/c63-c63s-...ml#post8396321
Old Aug 29, 2021 | 08:56 PM
Boostman76's Avatar
95,000 kms...no...vibrations at this point
this is awesome...learn something new everyday! Will take a look in the morning to see as i have never noticed those wear indicators (although never looked hard enough)
thanks for the intell!
Old Aug 31, 2021 | 11:28 AM
z28lt1's Avatar
C450, GLS 63 and a few other things
For those asking about minimum thinkness, I had the specs of minimum, new, and what they were actually at as my first pad change:
https://mbworld.org/forums/c450-c43-...diy-notes.html
My front rotors made it to the second pad change, the rear rotors still with more life to go. My mileage is probably worse than most as we live in stop-and-go-land (to go anywhere from my house, I pretty much have 4 stop signs and 2 traffic lights in 1.5 miles, so continues stop and go), so I'm probably not a good benchmark, but I got roughly 45k miles on the front rotors.
Old Sep 1, 2021 | 08:09 PM
Boostman76's Avatar
Great info..thank you
