C63 AMG (W204) 2008 - 2015
List of LTH (Long Tube Headers) Manufacturers for C63?
Old Aug 1, 2010 | 02:56 PM
  #76
harrower's Avatar
2009 C63, 2007 GL 450
Originally Posted by RStevens63
570 at the crank from a K3 package would equate to around 465rwhp. I don't think I've ever seen a Kleemann 63, or any car that didn't have longtubes vs manifolds make those numbers and I don't think anyone has ever tested their larger throttle bodys on their own either. Should prove interesting.
we will see. I as well found their claims of 570 a little hard to believe as well based on spec of the kit, but on other hand K1 worked as spec'd so we will see.
Old Aug 1, 2010 | 03:01 PM
  #77
harrower's Avatar
The best number I see with their tune and full exhaust is 537ps which is 530HP. Some tuners are seeing those numbers or better with tune alone.We need to see this system/tune at track at work. My question is, can someone cut through all the fog and just tell me in USD what the exhaust will cost including taxes, import fees, etc?TIA!
send me the PN#s of parts you want (can get them on their website) and I will get you price from local dealer. Taxes as I said before would be zero as I would be exporting the product. As far as duties, that would all depend on what the declared value of the system would be on commercial invoice when it is shipped.
Old Aug 1, 2010 | 04:38 PM
  #78
bhamg's Avatar
C63 AMG
Originally Posted by harrower
Hi B - I was going to go with Kleemann K4 but apparently they are having problems with the cams and the launch of the product according to Corry is aways off. So now I am going to piece what I can together as follows:
1. KW K3 Coilerovers
2. ECU/Headers/pipes - if Cargraphic checks out I might go with them. If not then I will go with K3 from Kleemann which covers ECU upgrade, a set headers with sport cats, and large trottle system. They throw filters in as well, but I don't think there will be much gain with filters. Should put me around 570 at crank.
3. Evo pulley
4. Just ordered some Rays VR G2s which should cut some serious weight off running OEM rims. Need to decide on some rubber, but shooting for 275 min on rear
5. CF hood arrives on Monday
6. CF front lip diffuser is already and ready for install.
7. CF roof spolier arrived Tuesday
8. RevoSport CF grill on order
9. EvoSport 2-Piece Rotors -back ordered
That would be it. I have already done most of the interior except for CF gauge cluster which I will be ordering from MaCarbon. That should be it for the time been. These things are money-pit!
Wow!!
Old Aug 1, 2010 | 05:28 PM
  #79
RStevens63's Avatar
E63
I'm glad we're going to get to see what the full K3 package does before & after. Thank you!
  #80
RStevens63's Avatar
E63
Thank You!!
Old Aug 1, 2010 | 07:00 PM
  #81
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
The two things I do not like about the Cargraphic system are:
1) The collector position before the final bend. They really aren't long tubes.
2) The collector size and mid-pipe size (diameter of only 2.75")
These facts are what ultimately swayed me to the MHP headers with their long/smooth collectors (after the final bend) and their 3.00" mid-pipes. I ordered my headers, mid-pipes and swappable cats on Friday!
Old Aug 1, 2010 | 07:17 PM
  #82
Sincity's Avatar
Harrower: Do you know if the headers will mate to the stock pipes (after cutting) without the use of these connecting pipes:
CARW204C63LP - Connecting pipe from header to X pipe **Removed secondary Cats** 18 90CZK inc. VAT = $976.98 - 20% = $781.58 retail
Old Aug 1, 2010 | 11:59 PM
  #83
RNS-11Z's Avatar
09 C63
Interesting, this is a picture of my headers. I am sure it is 3in the one i have coming, but we will find out in the next few days. here is a pic below
Old Aug 2, 2010 | 12:03 AM
  #84
alqamzi's Avatar
2009 c63, 2011 GT500
They look awesome
Old Aug 2, 2010 | 12:25 AM
  #85
Sincity's Avatar
How do these Cargraphic headers alone slip onto the stock pipes? Do you need to get a coupler/flex coupler piece or is using the those connections pipes that eliminate the secondaries a must? They sure look really good.
Old Aug 2, 2010 | 12:40 AM
  #86
Great pic, RNS-11Z.
Cargraphic lists the piping diameter throughout their whole exhaust as 70mm (2.75"). This data came directly from their site. Where did you get 3.00" from?
I would like to know what the primary tube sizes are. It's hard to tell if they are 1 3/4" or 1 7/8" by looking at the photo.
Old Aug 2, 2010 | 12:50 AM
  #87
The headers themselves won't slip into anything other than the mid-pipes you see in the photo. Those mid-pipes are supposed to bolt up to the front of the factory resonators with (I would assume) the factory clamps. The odd part is their connections look the same on both ends (L/R) in the photo above. It doesn't look like it will bolt-right up to the OEM resonators.
A good comparison shot of the MHP long tubes from avengerboater . . .
Last edited by superlubricity; Aug 2, 2010 at 01:07 AM. Reason: added photo for comparison
Old Aug 2, 2010 | 01:06 AM
  #88
Even Money's Avatar
'15 VW GTI
I think just by looking at the pics, the MHPs are definitley bigger mid pipes than the car graphics and the bends look smoother as well. You guys are hurting my wallet!
Old Aug 2, 2010 | 01:10 AM
  #89
BerBer63's Avatar
2009 C63
Look like the real deal...super clean.
Old Aug 2, 2010 | 02:25 AM
  #90
harrower's Avatar
Let me find out for you and get back to you
Old Aug 2, 2010 | 03:26 AM
  #91
avengerboater's Avatar
C63 AMG
The MHP long tubes have served me very, very well.
Old Aug 2, 2010 | 07:14 AM
  #92
hhughes1's Avatar
2013 Chevy 427 Torch Red
Bear in mind that I made a direct change from a K2 catless setup to MHP long tubes and picked up 44whp and 32#'s of torque same dyno 2 days apart. 1/4 mile info in sig really seals the deal for long tubes over log style.
Old Aug 2, 2010 | 12:09 PM
  #93
Sincity's Avatar
Thanks.
Cargraphic pipes are 2.75". I thought ours is 2.5"?
Old Aug 2, 2010 | 12:39 PM
  #94
Mrbig's Avatar
mhp all the way guyssss
Old Aug 2, 2010 | 07:45 PM
  #95
alqamzi's Avatar
I just ordered MHP LT's too
Old Aug 2, 2010 | 11:35 PM
  #96
Sincity's Avatar
And the primaries (is that what you call them) at the flange are bigger on the MHP, MBH, and EvoSport as well.
Old Aug 2, 2010 | 11:54 PM
  #97
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
Our headers use 2 inch primaries and are swedged to be an exact fit to the header flange. We do not step down from flange to primary. In fact because We manufacture them ourselves. We can do a few custom things upon special request. (more on that later)
Old Aug 2, 2010 | 11:56 PM
  #98
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I have a request, what about RHD headers please!
Old Aug 3, 2010 | 12:00 AM
  #99
How did I know that was coming. I'll look into it again. If someone wants to play the shipping back and fourth game with me. I'd strongly consider it.
Old Aug 3, 2010 | 12:10 AM
  #100
bhamg's Avatar
C63 AMG
LIke I said, there are good choices out there in the world of headers but in the end the MBH headers won out for me ALL things considered...I appreciate them more every day. JMHO.
