C63 AMG (W204) 2008 - 2015
500WHP C63 Edition 507 DYNO'ed
Old Jun 17, 2017 | 12:59 PM
  #276
skratch77's Avatar
2005 E55
Originally Posted by Infiniti
pardon me if i'm wrong and i dont want to search. didnt you give the op a hard time saying he dynoed in great weather and that helped? and now your saying my bad weather inflated it? which is it?
No you are not understanding and I'm done with this.he dynoed in amazing weather to put down high numbers.it was 57 degrees but his Dyno used a 1.03 correction factor.to get that cf the weather would of needed to be about 103d out.
You see ? His numbers were inflated on top of being in excellent conditions
Old Jun 17, 2017 | 01:12 PM
  #277
604 C63's Avatar
2012 E550 Cabrio
Originally Posted by BLKROKT
Nobody has doubted that people are picking up power here, it's just the inflated baselines that are being questioned. And that subsequently inflates the max whp numbers.
EXACTLY. 12 pages and one month later no one has done anything to explain that or put us one step closer to proof. Im not a disbeliever that it can happen, Im just a disbeliever when no one can even explain that basic item.
Start there, square one, then proceed.
Old Jun 17, 2017 | 03:00 PM
  #278
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
and c'mon player lets be realistic, why would the owner (who ran the dyno with me) of REAL ST an extremely reputable supra shop do anything to inflate my numbers? he can give a rats *** what my car or any mercedes does.
Not to butt in, but I have seen this countless times by all kinds of dyno operators. I was even told by 1 locally that they will put in different correction factors to give out higher numbers to clients who want to see them. To buy a dyno and maintain it and run it is big money, so if they can get someone to their shop and give them numbers they want to see, they will be going back. Go to a dyno that says XXX and then go to another one that says XXXXX. Most people will go to the one that reads higher every time. It happens to the best shops and the worst. Nelson racing motors is the biggest offender, but that is a whole different story all together.
Old Jun 17, 2017 | 03:42 PM
  #279
betrezra's Avatar
C63 507 AMG DA Car #19
Maz - werd!
There is an entire market for tunes and dyno sheets for bench racers....... an entire "niche'"...... which is not all bad. People impress other people with all sorts of things.... fashion, dyno sheets, watches, .. its all good.
Old Jun 17, 2017 | 04:29 PM
  #280
Mazspeed's Avatar
Let me add just one more thing, and I will get off my soap box. I am not disputing the dyno numbers some are seeing. The correction factor and every perimeter may very well be correct. And the reading you get may seem legit.
But here is the problems with using dynos for solving total HP readings. They are all off.
Let's take Dyno Jet for example. One of the best dynos you can buy. From the factory they WILL be off 2 to 3 percent. Now you have to factor in the 2 biggest things that will derail true readings. Installation of the dyno and operator error.
Installing a dyno is a PITA. And it alone can knock off accuracy of the unit in general without anything else being done. So from the factory you can go from 2 to 3 percent off, to 5 or more percent off.
And then you put in the worst offender of accuracy of them all. The human element. All bets are off after that.
I never once used a dyno for HP numbers. I used it as a tool for improvement, ironing out hiccups in RPM graphs and tuning sessions. "How I can best get 5 more hp at 5k RPM at turn 3 at Laguna Seca".
That's what I wanted a dyno for. Not totality of the numbers game because it's not really meant for that and it's not at all accurate for that. I needed and wanted improvement in a real world scenario and that's what a dyno is for.
Now you guys can tell me to F--k off now.
Old Jun 17, 2017 | 05:41 PM
  #281
betrezra's Avatar
Dyno = used to measure delta in performance with changes in engine mods... not relative HP.... only changes.
UNLESS you are selling tunes, or selling parts.
soap-box mode-off
Old Jun 17, 2017 | 05:49 PM
  #282
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
I only use one dyno in my area for my cars. It's probably the lowest reading dyno in a radius of 50km, but I couldn't care. The owner is a friend of mine, and the dyno is well looked after.
I don't care about the maximum number. I just want to see the number go up after doing a mod.
Old Jun 20, 2017 | 11:41 AM
  #283
skratch77's Avatar
2005 E55
Did you Dyno the car yet?
Old Jun 20, 2017 | 12:03 PM
  #284
Ludedude's Avatar
2014 C63 Coupe
^ This. All day long. It's good to establish a baseline then see the relative difference after a mod. That's ALL that matters. The rest is just internet dick measuring.
Old Jun 20, 2017 | 01:16 PM
  #285
NotABaller's Avatar
2012 C63, 2014 E550
Is there a rumble in Temecula going down or nah? https://www.sbnation.com/lookit/2014...ht-kobe-bryant Here is the reference for those of you who don't follow NBA or memes religiously
Old Jun 20, 2017 | 03:43 PM
  #286
604 C63's Avatar
2012 E550 Cabrio
Such a waste, amiright? We could promote the hell outta that card.
Old Jun 26, 2017 | 07:41 AM
  #287
skratch77's Avatar
2005 E55
What happened to the second dyno with all the details?
Old Jun 26, 2017 | 10:42 AM
  #288
arun.6ix's Avatar
C63 AMG Edition 507
I didn't need to re-dyno. Got the information I needed from the first dyno and was provided lots more information on how this was accomplished.
Old Jun 26, 2017 | 10:49 AM
  #289
JimGnitecki's Avatar
2012 Mercedes C63 AMG S
i.e. Could not now reproduce the unicorn result?
Jim G
Old Jun 26, 2017 | 10:54 AM
  #290
skratch77's Avatar
2005 E55
Oh so basically the runs were bull ****!
I mean you were the one who said you made appointments to re Dyno not us lol.
Old Jun 26, 2017 | 11:00 AM
  #291
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Old Jun 26, 2017 | 11:10 AM
  #292
skratch77's Avatar
2005 E55
I wonder what that secret prototype tuning was? Hair dryer on the Dyno sensor?
Old Jun 26, 2017 | 11:16 AM
  #293
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Old Jun 26, 2017 | 12:24 PM
  #294
Infiniti's Avatar
a unicorn tuned p30 e63
I haven't posted up because real st is booked, but when i go back please trust i will post the files up with all run conditions and bla bla, and then when i post better than 120.5 a lot of people will find something else to question or complain about. how does that saying go "he who laughs last" or something like that
Old Jun 26, 2017 | 12:33 PM
  #295
604 C63's Avatar
2012 E550 Cabrio
I'm going to run it on another dyno to see what I see get elsewhere.
I will take it to another dyno and probably to a dragway as well to see if the findings are accurate.
I got an appointment june 12 with EC to re-run so I can get my Air Fuel and also dyno it with 108 octane as well. Let's see what happens...
I will get all that information when I do the re-runs on June 12.
Got re-scheduled for this coming Tuesday. Their Dyno was down when I went in on the 12th.
No idea why all you guys are such skeptics, you should really be busy wiping all that egg off your face and eating crow.
Old Jun 26, 2017 | 05:53 PM
  #296
arun.6ix's Avatar
C63 AMG Edition 507
Yeah I did say all that, what's your point? There was no need to re-run it. I thought there was and after the owner showed me dozens and dozens of the same pulls from different cars with the same power output it was good enough for me. It's so funny you are quoting me, but they got like 50 calls asking for the same tune. Please call them and get it but until then
let me pretend to have 500whp with my so called unicorn, my factory freak I'm good with that. You guys have fun at Atco.
Old Jun 26, 2017 | 06:02 PM
  #297
arun.6ix's Avatar
C63 AMG Edition 507
Bro don't post anything, I have the details but I'm over this **** show with certain people here. They will still find a way to criticize and put you down. If they really want to find out, they can go pay $1100 for the tune and $300 for before and after dyno to get what they want. Then they can sit there and argue with whomever it is that "the dyno pull was adjusted to the their favour."
Old Jun 26, 2017 | 06:11 PM
  #298
I am Jeff's Avatar
Steel Grey Metallic C63!!
It's funny how you posted some unicorn numbers without any supporting dyno information, yet you expected the forum community to praise you on your magical numbers. Let me get this out of the way, your baseline numbers (pre-tune) is extremely inflated. You volunteered to get have your unicorn results re-dyno'd, but backed out after you received some "secretive" dyno operator information.
So yes, we're calling BS on your inflated baseline numbers, which directly leads to inflated inaccurate dyno results.
Old Jun 26, 2017 | 06:17 PM
  #299
skratch77's Avatar
2005 E55
Then why is it so hard to post an uncorrected Dyno sheet or one with the run conditions on it?
Old Jun 26, 2017 | 06:20 PM
  #300
arun.6ix's Avatar
C63 AMG Edition 507
So yes, we're calling BS on your inflated BS lines, which directly leads to inflated inaccurate dyno results.
Cool Bro thanks for the information.
