C63 AMG (W204) 2008 - 2015
Urgently need advise (loud rattling engine noise)
Old Mar 25, 2019 | 11:30 PM
Tj63's Avatar
C63 w204
Has anyone ever had this horrible noise before and knows what the problem is?
Lifters have been replaced, the engine has compression and oil is running as well.
Old Mar 26, 2019 | 12:33 AM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
https://m.youtube.com/watch?v=sIATHQ-C9jM
wow yeah def sounds horrible but upper valve train related from the sound. I want to say cam adjuster, but that is very loud. Does it ever go away? What is the year and miles? Only coming from that side?
Old Mar 26, 2019 | 12:41 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Rod knock. Sorry.
Old Mar 26, 2019 | 12:52 AM
Tj63's Avatar
C63 w204
It gets more quiet after some time and it seems to come only from that side. 2009 with 144000km.
A specialist who worked on that car before said actuators. He replaced left exhaust and right intake actuators on that car a while back.
Old Mar 26, 2019 | 01:28 AM
deadlyvt's Avatar
2010 C63 AMG
Does sound terrible and more like a rod knock but hard to tell from the video
Old Mar 26, 2019 | 01:30 AM
Tj63's Avatar
C63 w204
Rod knock would get louder though with the engine warming up and not the other way round or am I mistaken?
Old Mar 26, 2019 | 01:38 AM
Tj63's Avatar
C63 w204
Forgot to mention that a compression test was done and turned out it has full compression
Old Mar 26, 2019 | 03:56 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Sounds like the engine in this vid:
The bloke did not respond to the comments.
Maybe the flaps in the intake manifold failed. One member experienced this and reported very loud knocking.
EDIT: https://mbworld.org/forums/c63-amg-w...2007-ml63.html
Good luck.
Old Mar 26, 2019 | 10:02 AM
Celicasaur's Avatar
W212 - E63 AMG
Rod knock for sure.....sad times
Old Mar 27, 2019 | 05:32 PM
Tj63's Avatar
C63 w204
So my mechanic just sent me these photos of the oil filter...
Old Mar 27, 2019 | 05:59 PM
Celicasaur's Avatar
W212 - E63 AMG
What's that brown looking thing in the middle that looks like a spiders leg got chopped off?
It doesn't look great with those little specs though....do they catch on a magnet?
I guess if you want to rule out all doubt, get your mechanic to pull the sump and wiggle the big ends of the rods....you'll have your answer if it's rod knock or anything else less sinister.
Old Mar 27, 2019 | 06:02 PM
Tj63's Avatar
C63 w204
Thanks, I'll ask him to check
Old Mar 27, 2019 | 06:18 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Looks like stripper glitter (metal bearing flecks)
Old Mar 27, 2019 | 06:47 PM
alyqc's Avatar
C63 AMG 2009
Your have a lot of metal chip in your oil filter (cop color) this kind of metal come from bearing (like rod bearing or crankbearing) ...
stop driving the car and remove the engine and remove oil pan to see what happen on rod bearing or crank...
really sad time ...
Old Mar 27, 2019 | 07:15 PM
SatelliteMan's Avatar
2009 C63 AMG Sedan
That's a horrible sound. Rods. I feel bad reading this.
Old Mar 27, 2019 | 08:16 PM
America's Avatar
14 C63, 15 Ghibli, 03 Duramax
Looks like copper, if so has to be bearings.
Old Mar 30, 2019 | 12:17 PM
Ludedude's Avatar
2014 C63 Coupe
Bearings. Yep.
Old Mar 30, 2019 | 11:14 PM
BiturboSF's Avatar
E63 M157
That's crazy, was there any other noise or symptoms prior to this? I get a continuous rattle or tick sometimes during low rpms, if I drive next to a wall I can hear it but can't make out what it is
Old Apr 2, 2019 | 10:38 PM
kb24forlife24's Avatar
None for now
What year C63 is that?
Old Apr 3, 2019 | 08:12 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
2009 with 144000km..
It's a 2009.
