C63 AMG (W204) 2008 - 2015
What did you do to your C63 today?
Old Jun 2, 2025 | 04:26 PM
  #401
deadlyvt's Avatar
2010 C63 AMG
Originally Posted by Phil_T
Did you happen to weigh the sunroof when removed? Ive got a brand new standard w204 non sunroof full panel to fit at some point. It would be nice to know how much weight I will be saving before I get round to it in the distant future. I guessed about 22kg with the glass & frame.
where did you get the non sunroof panel from? Wrecked car or ordered one from Mercedes?
Old Jun 2, 2025 | 10:58 PM
  #402
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
IIRC, he cut some Lexan.
Old Jun 3, 2025 | 01:10 AM
  #403
Phil_T's Avatar
C63 AMG Saloon
Originally Posted by Mort
The weight of the sunroof is 75 lbs. according to post #67 in this thread: https://mbworld.org/forums/c63-amg-w...-thread-3.html
May be more information in there if you dig around a bit.
Thanks, Wow just over 10kg more than I thought, good saving from high up on the car.
Bought it new from Mercedes and bought the headlinier too so everything looks OEM.
Old Jun 3, 2025 | 06:21 AM
  #404
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I didn't have the pano. The regular sunroof is about 35lbs.
Old Jun 6, 2025 | 07:02 PM
  #405
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Test fit the passenger RECARO seat today - fits like a glove. I can confirm, W204, W211 and W212 all use the same seat mounting brackets.
Also weighed the factory E63 seat and it came in at 70 lbs. Swapping both seats should net around a total of 70lbs~ weight reduction.
Quick teaser pic.
Old Jun 7, 2025 | 12:55 AM
  #406
Phil_T's Avatar
C63 AMG Saloon
Quick teaser pic.
Looks great, did you use Recaro seat frames or the planted ones? Will you code the errors out or use resistors? Also does the steering column not move now? (As I know it works with the seat)
Old Jun 7, 2025 | 04:25 AM
  #407
DRBC43AMG's Avatar
Those look great. Where did your source the Recaros and the type?
Perhaps it would be worth doing a seperate thread for future reference purposes, if you have the time
Old Jun 7, 2025 | 05:51 AM
  #408
sickSVT's Avatar
Top Answer: 1
Planted mounts with Recaro seat frames and sliders. I'm gonna try to code out the airbag codes with Xentry first, if that doesn't work I'll use resistors. For the steering column I believe there's a small module in the factory driver's seat that I can transfer over to the Recaro mounts to retain adjustability of the steering column.
I ordered everything from @Highline-Autos.com, he's an authorized Recaro vendor and will give you a solid deal.
I'll take some good photos once everything's installed and put together a thread for future reference.
Old Jun 7, 2025 | 09:16 AM
  #409
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Do you have much experience with Xentry? It would be awesome if there's a way to code out full modules. Like the SRS module which I no longer have lol.
Old Jun 7, 2025 | 12:32 PM
  #410
sickSVT's Avatar
Top Answer: 1
Not really, I'm just using Xentry Openport 2.0. It usually points out where the faults are coming from and you can navigate through the menus to disable them.
For more advanced coding you'll probably need the full kit which runs over $1K.
Old Jun 11, 2025 | 11:29 AM
  #411
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
Planted mounts with Recaro seat frames and sliders. I'm gonna try to code out the airbag codes with Xentry first, if that doesn't work I'll use resistors. For the steering column I believe there's a small module in the factory driver's seat that I can transfer over to the Recaro mounts to retain adjustability of the steering column....
Apologies for not knowing, but when you 'code out the airbag codes', does that mean that with these seats your airbags will not deploy in an accident?
Old Jun 11, 2025 | 11:33 AM
  #412
Meeyatch1's Avatar
Just out for a night time drive. (6.5.25)
Nothing crazy. Finally got around to washing and vacuuming it, and then going for a nice night drive on a perfect night.
Old Jun 11, 2025 | 09:54 PM
  #413
sickSVT's Avatar
Top Answer: 1
I was able to successfully code out all of the factory seat SRS systems with Mercedes DAS software and open port 2.0 without any need for resistors.
The airbags will deploy as normal, we're just turning off unused features like passenger weight sensors, side seat airbags, and headrest restraint systems.
Old Jun 12, 2025 | 01:09 AM
  #414
Phil_T's Avatar
C63 AMG Saloon
Great news, next mod for mine is carbon pole positions and I contacted a company a while back who said they do the same to fit the seats then turn off everything thats showing an error.
What did you do in the end to make the steering column still adjustable as you need the seat? Did you just keep the seat module on only plug parts of it going to the column in?
Old Jun 12, 2025 | 01:58 AM
  #415
sickSVT's Avatar
Top Answer: 1
I haven't gotten to the steering column yet but I'm sure it's just the module I have to transfer over and leave it plugged in.
Wanted to tackle the SRS coding first since that's the most trickiest part on these cars. I learned USA spec cars don't really work well with resistors since they use a more complicated 4-pin wire setup, so coding through DAS is the best and cleanest option.
Here's a list of coding options I had to turn off for my E63, definitely find a shop that knows what they're doing.
  • Passenger Seat Occupancy Sensor (WSS)
  • Passenger OCM
  • RoE Existing
  • PAD-Lamp ON at Weight Class 0
  • PAD Switch
  • DAD Switch
  • Thorax Sidebag Passenger Seat
  • Thorax Driver Passenger Seat
  • Passenger Pelvis Airbag
  • Driver Pelvis Airbag
  • Passenger Pelvis Squib Passenger
  • CAH NECK-PRO Headrest (Passenger)
  • CAH NECK-PRO Headrest (Driver)
Old Jun 12, 2025 | 10:47 AM
  #416
Phil_T's Avatar
C63 AMG Saloon
  • Passenger OCM
  • RoE Existing
  • PAD Switch
  • DAD Switch
Let me know how you get on with the column, thanks for the other info will help loads when I get round to them. I have seen some people swap over or buy the smaller seat occupancy pad so it stays in use but I know how hard the seats are to take apart on the c63 😄
Old Jun 13, 2025 | 04:26 PM
  #417
sickSVT's Avatar
Top Answer: 1
Got the driver’s seat installed today. Just waiting on a few bolts to finish securing the seatbelts, and it should be good to go.
I confirmed that the adjustable steering column module is located beneath the factory driver's seat. I removed it and secured it to the carpet with Velcro, and it works as it should.
Old Jun 13, 2025 | 11:25 PM
  #418
Phil_T's Avatar
C63 AMG Saloon
Seats look great & thanks for letting me know. The only difference will be the seat rails/mounts as I found Recaro makes a straight bolt in so no need for the Planted mounts.
Old Jun 13, 2025 | 11:44 PM
  #419
sickSVT's Avatar
Top Answer: 1
the seats sit a lot lower than the factory seats even with the planted mounts, if you're under 6ft it might be an issue with visibility with no planted mounts.
Old Jun 18, 2025 | 11:17 PM
  #420
Phil_T's Avatar
C63 AMG Saloon
After 12 years owning the car since new and the car being highly modified I finally decided to get headers 😄 I went for MBH RHD headers which are currently getting ceramic heat treatment.
Old Jul 5, 2025 | 02:54 PM
  #421
Meeyatch1's Avatar
I have been considering those for my car as well. What is your impression of the build quality?
Old Jul 5, 2025 | 10:48 PM
  #422
Phil_T's Avatar
C63 AMG Saloon
I mean look at the previous pictures, I think the quality speaks for itself, they were definitely worth the wait to be manufactured. Unfortunately they don’t look as good now they have been properly ceramic heat treated but it reduces engine bay temps by 30%, if you could see them when fitted it would be ashame as they look like a piece of art. 😄
Old Jul 6, 2025 | 04:18 AM
  #423
DRBC43AMG's Avatar
Well I guess a 30% decrease in temperatures is worth it compared to shiny components one doesn't really see, except when looking for or on a "show" car
Old Jul 6, 2025 | 05:45 AM
  #424
Phil_T's Avatar
C63 AMG Saloon
Yes which is why I did it, properly done using zirconia not like the cerakote which basically doing nothing for heat.
Old Jul 6, 2025 | 07:29 AM
  #425
svtjocson's Avatar
2010 C63
how much did it cost to do this? Is just the outside treated?
I've been told to cerakote my new headers inside and out but you mentioned ceramic heat treating is better?
