Skipping Wipers
On the way to Dallas it was raining quite hard, and I could not run my wipers in automatic mode, they were terrible; getting stuck up top, chattering on the way down - overall doing a very poor job removing water from the windshield.
So when I got back, I cleaned the windshield and wipers again (the wipers look OK in terms of wear) but took it a step further and polished with 3M glass polish and my PC XP, then applied McKee's 37 glass coating to it. Water beads right up.
Now it's raining again, and I'm still having the same issues. What. the. heck. is going on? I've got nothing left in my toolbox to try, short of replacing wiper blades. I have an appointment with the dealer now, and they seemed to think the motors typically are a culprit (confirmed wiper blades were replaced in December). Based on previous searches for other C Class cars, the general population either A) Has no issues whatsoever or B) Experiences the same horrible performance I do and seemingly they fixed it by replacing the windshield. I don't know why replacing the windshield would be needed when you can just clean away anything that's on it.
Does anyone have thoughts on this?
The car was 8 times at two different dealerships. They replaced wipers, wiper arms, motors, polished the windshield and still no luck..
Right now I'm asking MBUSA to buy the car back...
I’m giving Mercedes one chance to fix this before I have someone use a ceramic coating on the windshield. If that doesn’t fix it, I’ve no idea what will.
I know that any hydrophobic coatings on your windshield aren’t going to help your wiper blades since they will effectively be rubbing across a unceasingly dry surface. Regardless, unfortunately it happens.
The issue is the crappy wipers MB is using, but there's not often a good alternative, so you have to ensure the glass is very clean. Every one I've cleaned hasn't come back, but it's a bit of work to do it right.
Look at remedy C, the intensive cleaner it refers to is what you need. There is a WIS document that describes the process, those I can't download. But basically, you clean the car with glass cleaner first, then apply the intensive cleaner like a wax, put on heavy, let dry, buff off. If there's heavy deposits, it may take multiple applications, you will see it when applying it in my experience.
There is a special tool for it.
Dave
****ty problem but my dealer has been easy to work with and seems genuinely concerned about fixing my issue.
Interestingly, they gave me a C300 loaner for some other service work and it rained...and the wipers on the loaner skipped like crazy. WTF Mercedes! This is seriously disheartening and makes me upset and not want to get another Mercedes...I buy my cars to drive.
The only thing that works for me is glass wax and only for a while them it starts skipping again.
They tried the gauge to see that the angle was correct but it looks like MB just engineered a bad design and have not fixed it after 4 years. WTF MB
I’m at a loss, I am pretty sure the OEM wipers suck but there aren’t many options out there. I really am about to just have my windshield coated with a ceramic coating...I know Mercedes says not to but I think wipers should work without skipping, don’t you?
