CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Engine mount's - Advice neded!
Old Jan 11, 2020 | 04:41 PM
superveloche's Avatar
2007 SL55 P030, 2005 CL55 AMG
Hello guy's
It's time to change the engine mounts on my CL 55.
Initially i wanted to go for Lemforder mounts but then some people spooked me. They said that after market mounts are just not worth it and have bad quality and i should only opt for original engine mounts.
The big dilema is that the Lemforder mounts are 57$ each and original are 155$ each.
Any of you had expierience with these engine mounts? is there really such a big difference between the OE/OEM's and original mounts?
Any advice would be appriciated
Old Jan 12, 2020 | 10:47 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
If I recall correctly and what I read was true, the MB ones are rebranded Lemforder. Yes, aftermarket engine mounts don't seem to last long.
Old Jan 19, 2020 | 04:33 PM
Welwynnick's Avatar
2006 S600
The thing with engine mounts is you really don't want to do it twice!
Yes, Lemforder are good.
Nick
Old Jan 19, 2020 | 05:07 PM
I ordered for the CL 55 the black series mounts and for my W221 S500 original mercedes ones but now i am sorry i didnt go for the lemforder on the S500.
Although i ordered the Black Series mount for the engine on the CL55, i allready have a Lemforder mount for the transmission. I just hope it wont be an issue going for the black engine mounts with a non black transmission mount.
The black series transmission mount is about 230$
Old Jan 22, 2020 | 03:55 PM
pawraw's Avatar
CL 55 AMG
Low cost mounts
I changed my engine mounts with low cost parts and they seem to work fine ! The biggest improvement I had was the trans mount replacement - totally fixed the vibration at 1500 to 3000 RPM. also a low cost aftermarket part.
Wish I'd replaced the trans mount first as I don't think the engine mounts were bad. If vibration is a problem try the trans mount first as it is really easy to replace.
Old Jan 26, 2020 | 01:16 AM
mguerrero's Avatar
w215 - CL55 w/stage III
Lemforder is fine - I actually just bought Corteco's for all three and they were even less --- I did my trans and like pawraw I noticed a difference even though I didn't think it was out, it had dropped a whole inch or so -- for the motor mounts I'll have to pay to get them done as I have longtube headers and they eliminate any clearance there once was
Old Jan 27, 2020 | 08:17 AM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
The last mounts youll ever need
Old Mar 17, 2020 | 03:19 PM
njbiker2008's Avatar
sl 500 r230
were can i get a set of the mounts you have in the pic? T/K you
Old Mar 17, 2020 | 04:53 PM
SPONSOR
E55 C63
https://www.vrpspeed.com/product/vrppoly/
