real fander gap issue
Old Oct 7, 2008 | 05:49 PM
J56BP's Avatar
2002 CLK 430
hey all
here we go, i have 19's lowered H&R with #3 pads (real).
issue: real passenger side (right lol) center of hub to fander 14'
real driver side center of hub to fander 13' 1/4 WTF?
so there is 3/4' gap diff....tire/fander
plz don't tell me coz empty gas tank (2gal)
anyclue ???? some 1
thnx
Old Oct 7, 2008 | 06:51 PM
gregory13lil's Avatar
2000 CLK430
1st of all not to be an *** or anything but it took me quite a while to decipher your message so...
I dont think the gap difference would be caused by an almost empty fuel tank. Are you the original owner? Was the car ever involved in an accident?
I am almost tempted to check mine as well to see if I have the same gap difference?????
Greg
Old Oct 7, 2008 | 07:33 PM
CLK FAN's Avatar
2000 CLK 3.2
I have the same problem and so do many other people.
Our cars are not perfect and neither are many other cars for that matter. That's why they sell different size spring pads so you can adjust to your needs. Don't trip potato chip just get a smaller spring pad for the side that sits higher or do the opposite for the other side to even the car out. That's what I did and that's what I would suggest to all others who find themselves over analyzing the fact that their car is not even after a suspension switch.
Old Oct 7, 2008 | 08:25 PM
2000 CLK430
Hmmmm GOOD INFO!!
Old Oct 8, 2008 | 04:17 AM
J56BP's Avatar
2002 CLK 430
thanx i figured thats what i need.
also do you have real camber kit on urs? coz mine real right side tilts in negative camber, eats the inside wall of tire bad. its funny the left real its ok.
to fix it i need k-mac kit, anything alse would help?
advice plz
Old Oct 8, 2008 | 10:20 AM
CLK FAN's Avatar
2000 CLK 3.2
use the camber kit and get the bigger pad for the side that sags because I'm sure the side that sags is the one that has the most negative camber.
Old Oct 8, 2008 | 11:48 AM
CurYousGee's Avatar
2000 CLK 430
Greg
i guess "real" is actually "rear" and fander is "fender"
Old Oct 9, 2008 | 03:28 AM
J56BP's Avatar
2002 CLK 430
very good
Old Oct 9, 2008 | 03:32 AM
J56BP's Avatar
2002 CLK 430
right rear same side with bigger gap has negative camber, so i'll go #1 pad
i guess just stay with #3 on the the left rear/maybe get #2
thanx for ur info
Old Oct 9, 2008 | 08:57 AM
deyainrdy4ds's Avatar
w208
i think my passenger side actually sits lower...it looks the same to the eye on both sides but the rubbin is always so much worse on the passenger side :-(.....it rubbed away all the letters on the tires where it says michelin lol...and it rubs on the inside pretty bad too....i shouldnt have went with the 35 sidewall...
Old Oct 9, 2008 | 03:11 PM
JYOO's Avatar
W205 C43 AMG
Hey, They are not ready for this what size rear tire are you running?
Old Oct 26, 2008 | 07:40 AM
J56BP's Avatar
2002 CLK 430
thanx for ur info
well thats what i just did.. changed out #3 to #1.....guess what it did not drop...WTF is going on? so i have left #3 driver rear side-#1 right rear but fender gap still bigger here...omfg
anyclue why (it could be cuz i need camber kit) no way just give up...lol
Old Oct 27, 2008 | 02:25 PM
benzo4me's Avatar
2000 CLK430
I have 2000 CLK430. Does anyone know what are the original pad number? I called MB and they told me depending the color of the dots painted on the spring. Told them mine is red and they said it's 2103210384 which is #3 I think.
Old Oct 27, 2008 | 02:53 PM
benzo4me's Avatar
2000 CLK430
Usually when a car came from factory, are front and rear pads the same size?
Old Oct 27, 2008 | 02:56 PM
benzo4me's Avatar
2000 CLK430
Usually when a car came from factory, are front and rear pads size the same (i.e. all #2, all #3, etc.)?
Old Oct 28, 2008 | 02:13 PM
falls profet's Avatar
"real"= rear?? Are you Asian? JK with you man.
You may want to make sure your springs are installed correctly. When I had mine done, we didn't exactly get the rear, passenger side in right the first time. It set higer than all the others because we didn't have the spring turned just right on the swing arm. That may be your problem. Even though the spring is in, doesn't mean it is necessarily correct.
That's what I'm thinking...
Old Oct 29, 2008 | 09:45 AM
benzo4me's Avatar
2000 CLK430
Do all 4 pads have to be the same size? My mechanic accidently mixed them up. The height of the car is not much different at all. Is that ok to leave it like that or should they be the same size? Also my car is pulling right an left, would this cause the problem? Also would inner tierod cause the car to pull right and left?
