CLK 230K H&R too low ride. Help Please!!!
Subscribe
Dec 18, 2015 | 08:43 AM
Hi Guys,
I have a very strange problem with my car. I ordered H&R Springs from Germany with 40mm drop all around specifically for W208 230K Coupe. The car literally became extremely low and front tires will hit fender and inner lining and the exhaust hits speed bumps. Its not drivable. Rear Tires hit inner lining as well on high bumps.
I added a 1 inch rubber on top of the front spring pad which is a PAD#4, and the rear springs have Pad#2.
My Wheel and Tires are:
Front: 18x8.5 ET35 Wheel + 225/40/18
Rear: 18x9.5 ET35 Wheel + 245/40/18
I am not sure what is wrong.
Also what is the standard height of the car. How to measure it.
I didnt want the drop to be bad, just wanted better handling as my old oem springs are old and car was not even on all sides therefore changed to H&R Springs.
Please advise.
CLK 230K H&R too low ride. Help Please!!!-clk-front.jpg   CLK 230K H&R too low ride. Help Please!!!-clk-back.jpg
Reply 0
Dec 18, 2015 | 09:27 AM
Post this in the W208 forum for your car. Not that many people read this forum. This forum is mostly just to say "hi".
Reply 0
Dec 18, 2015 | 09:37 AM
Thanks Yindey,
My Bad. Im new to this.
Reply 0
Dec 18, 2015 | 02:16 PM
Strange, H&R springs are generally a fairly minor drop. You ordered their standard Sport springs and not their Supersport right?
Reply 0
Dec 18, 2015 | 02:25 PM
Yes H&R sport springs with ABE. 40mm drop all sides. Part number is 29749 for w208 coupe. The color is blue.
Reply 0
Dec 19, 2015 | 06:40 AM
moved to W208 forum...
Reply 0
Feb 25, 2016 | 01:46 AM
the super sports are designed to get really low, probably need to use a better shock as well to keep the bounce under control. I used Koni shocks and they seem to work really well.
Reply 0
Feb 25, 2016 | 06:11 AM
To me your car looks great !
You have done the same as me to adjust the height by adding or removing the spring pads. The max pad is no.5, to get my height just right, I had to cut the top of the old pad and sat this on top of the new spring pad .
Reply 0
Explore
Feb 25, 2016 | 02:11 PM
Sounds like you are still using stock shocks, just H&R springs? It's possible your stock shocks blew out. If you just did springs, then the new springs aren't supporting the weight as much as the old ones did. So the new load on the stock shocks could have caused them to fail.
I had the sport cup kit (springs and shocks) and the front shocks failed when the car was stolen (guess he drove it like he stole it). My tires were rubbing the fender exactly like yours is. I replaced the shocks with Bilsteins up front and my ride height went back to normal with the fender about a centimeter off the tire. So check your shocks.
Reply 0
Feb 26, 2016 | 04:53 AM
If it dosent rub it doesnt fit !
Reply 0
Subscribe
Currently Active Users (1)
