Brake Squeal
Thanks!
My dealer says I need to change them out, even though the warning light has not come on yet. I complained about squeaking at very low speeds so that is why they said I need to change them (brakes like 3mm left and rotors are at min).
They are charging like $416 for parts and $242 for labor.
Thanks in advance!
P-B-42.10/51e Front brakes squeal/grinding noise will install modified parts inclusive of pressure retaining springs, dampers, and pads.
P-B-42.10/79 Front/rear brakes squeal will replace all pads. https://mbworld.org/forums/clk-class-w209/213473-brake-squeal.html
If the mechanic puts anti-squeal paste on the back of the pads, they’ll quiet down. That’s assuming they’ve been bedded in properly, but since brake juddering/pedal vibration hasn’t been mentioned, I’ll assume they’re just noisy.
Let me qualify the paste comment. If they PROPERLY apply paste, they’ll quiet down. If the paste hasn’t cured before they put the pads on, it’ll squeeze out and you’ll get squeal. When I do my brakes (and I just did mine last month) I put the paste on the back of the pads before I pull out my floor jack. That way I know the paste has had time to set up.
Thanks in advance for your help!
http://www.autopartswarehouse.com/se...294967027+9183
The reason they denied to fix it under the SB is that the brakes are only covered for 12mos. I've had the car for much longer than 12mos although, I did complain about the problem within that time frame.
I believe they applied the paste to address the squeak before but eventually the noise comes back.
Any other ideas on how I should approach this with them?
P-B-42.10/79 Front/rear brakes squeal will replace all pads. https://mbworld.org/forums/showthread.php?t=213473
I was denied at RAY CATENA Mercedes in New Jersey. The service guy told me there are no bulletins for brake pads on any MB except the upgraded pads on an E63 and there is no way Mercedes would fix them under warranty. Pads have never been a warrantied part.
I have been telling my service guy about htis for 7,000 miles. He said there is nothing they can do unless I want to pay for the replacement and then tried to sell me rotors....HA!
Understand, the complaint should be “repair brake squeal” not replace brake pads under warranty. Furthermore, if there is a misunderstanding common sense should lead the SA to pull up a copy of the DTB before comment or denial.
(1) As mentioned previously, MBUSA covers brake pads and rotors under warranty for the first 12 months/12000 miles no questions asked. If any SA tells you different, the dealership is misinformed.
(2) MBUSA DTB P-B-42.10/79 released 9/20/07 unquestionably covers brake squeal during the initial factory warranty period 48 months/50000 miles period! By no means does it automatically cover brake pads (i.e.: normal wear/no squeal) however, pad replacement is specifically recommended as a solution if the brake paste application process fails to resolve the squeal regardless of pad wear.
If it was documented that you complained about brake squeal previously (i.e.: invoice) they must adhere to MBUSA policy and follow the procedure outlined in this DTB to resolve your brake squeal complaint. In addition, note the only time the rotors can potentially cause squeal is when they are warped or heavily scored.
Thanks for all the 411. I am going to another MB service center this week and I will let you know what happens. The SA I have been dealing with has been very opposed to repair the squeal I've had. He even referenced the last time I was in and said "wow, you came in a while ago for this same problem. That was 6k miles ago. That has got to get annoying". Can you believe that crap?
It was him I saw on the previous visit.
Anyway, I will let you know what happens. Thank you - seriously. Great information
Do you work for MB?
-Chris
I was also told if the brake pad is less than 50% worn, they will not replace the pads under warranty due to brake squeal. I will have to purchase new pads.
If the pads have 50% or more unworn pad left, they will replace the pads due to MBUSA DTB P-B-42.10/79 to repair squeal.
I have less than 50% of the pads left..........of course.
Ahh well. I am switching to another brake pad anyway to reduce brake dust.
Thanks again for all the 411.
