***Official Wheel/tire/stance Fitment Thread***
Old Sep 29, 2011 | 07:53 AM
  #226
ld.Scorpion's Avatar
MB CLK w209 320 V6
Thaks !!!
Looks everything good. Time will show =)
Old Oct 3, 2011 | 12:57 PM
  #227
Jamesbbh's Avatar
2006 Facelift CLK500 Cab-
Originally Posted by 2MCHCAR
Thanks Kev!
I took my angle grinder and I found that panel you mentioned. I also ground away at the fender in the front, no rubbing now! Just to remind everyone, my rear et is 25 (wheel et 35 - 10mm spacer), I'm not lowered, and I'm using Michelin Pilot Super Sport 275/30/19 tire.
Some pics!
I'm going to have to do this at some point just for piece of mind. Did you paint or clearcoat the ground down area? If not, it will start to rust and no one likes that on a MB Just sand the bare area good and feather around it - mask off EVERYTHING around it even if you don't think overspray will get on it (it will)-wipe down with mineral spirits and rattle can some clearcoat or paint or both on there and you'll be set.
Old Oct 3, 2011 | 12:59 PM
  #228
Jamesbbh's Avatar
Originally Posted by Louie D
My new Wheel/tire/stance
Out of commission for 3 week seems likes it been longer but only has been one.
Koni adjustable coming in 3 weeks away
Wheels re chromed in Black chrome and ever 3 weeks away along with other parts that can be seen.
Eibach Springs here
Calipers cleaned and painted with Dupli-color Silver with new pads.
New back tires here BF Goodrich.
I'm really liking that silver caliper paint, are you going to get a replacement MB sticker to go on there?
Old Oct 6, 2011 | 01:56 PM
  #229
mozilla1984's Avatar
clk500 2003
hello
i buyed a mercedes clk500
is it possible tot take et45 wheels on it?
size 18 5x112 et55 8.5j
thanks
Old Oct 6, 2011 | 02:05 PM
  #230
www.usarim.com's Avatar
Former Vendor of MBWorld
Mercedes Benz AMG
what year is the CLK500
Old Oct 6, 2011 | 02:06 PM
  #231
clk500 2003
its a 2003 model.
one of the first new look model
et is 45 not 55
Old Oct 6, 2011 | 02:33 PM
  #232
Mercedes Benz AMG
spec is
2003 Mercedes
CLK Class
Bolt Pattern: 5x112
Center Bore: 66.56
Hardware:12x1.50 Bolt
Offset:
Front: 32-35mm
Rear: 32-38mm
Old Oct 6, 2011 | 02:35 PM
  #233
Mercedes Benz AMG
to run ET45 you would need spacers to clear the calipers
Old Oct 6, 2011 | 02:42 PM
  #234
clk500 2003
ok i thougt it was needed.
is 10 mm enough ?
i get my car in 10 days.
the tire can i use 235 40 r18 or can i go some wider 245 ??
thanks for your help...
Old Oct 6, 2011 | 02:47 PM
  #235
Mercedes Benz AMG
spec is 225/40r18 and 255/35r18 staggered you can run non staggered 235/40r18 but I wouldnt go any bigger
Also spacers 10 should be plenty you can go 12 if you want to fill up the wheel well a little more you will need longer lug bolts though and make sure the spacers are hub centric otherwise you will get vibrations.
Old Oct 6, 2011 | 03:17 PM
  #236
clk500 2003
i take 225 for better steering.
with 10 mm space . can i use the stock bolts or need i larger ones.
here a photo http://a8.sphotos.ak.fbcdn.net/hphot...85982009_n.jpg
Old Oct 6, 2011 | 04:21 PM
  #237
Mercedes Benz AMG
you will need longer lugs when you run the 10mm spacers
Old Oct 7, 2011 | 09:13 PM
  #238
Bimmer-2-Benz's Avatar
CLK500
Originally Posted by Mka77
Wheels and tires should be fine with none of the above.
The bolts should be the m12x1.5 ball seat type. As far as the wheels go you need to look at one of the OEM wheels and one of the aftermarket wheels down in the lug bolt holes to make certain the seats look the same. Some aftermarket wheels do use cone seat.
You should be able to use the same length bolt front and back.
The length of the bolt you will have to determine yourself by measuring how much is sticking out the back of the aftermarket wheel. No more than 3/4-7/8"
Color of bolt is your choice. Dacromet coated is OEM
So the bolts and wheel locks finally arrived. However, when I tried to mount my front rims today the silver center hub (looks like a cap) was pushing my center cap off. My rims have these weird center caps that are thick and are held on by screws. The rear rims mount on perfectly because the rear hub doesn't have the protruding silver colored center hub like the fronts... is the hub different on the front because of the AMG calipers that come on the CLK 500?
Can the protruding silver colored centre hub on the fronts be taken off because it looks like some sort of cap? Will spacers in the front solve my problem?
The front rims mount on fine if I take the center cap off. Someone please tell me what I need to do... I'm so depressed right now cuz I feel so lost
Old Oct 9, 2011 | 06:00 PM
  #239
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Any Forgestar F14 owners past or present?
I am considering new wheels for next summer. At first I really didn't care much for the F14's, but now I believe they are my likely choice.
I know Wes (Dyno) has a set, but has anyone else ran them?
Good place to purchase from?
Should I order them custom built or buy off the rack?
Thoughts?
Old Oct 10, 2011 | 06:06 PM
  #240
ahmadk's Avatar
2011 E550 Sedan
Thoughts?
they're nice. But I didn't like them in silver, I say go with the same color as Dyno's
Old Oct 10, 2011 | 10:27 PM
  #241
Cabanclk550's Avatar
clk550
clk550
wheels: lexani's 20x8 in the front and 20x9.5 in the rear
tires: Falken sport 245/30/20 in the front and 285/25/20 in the rear.
spacers: only in the front but unkown size ( the wheel place just put them on)
suspension: stock. I need advice on the suspension, Please help! my car is in need of a drop but idk what i should do
Old Oct 10, 2011 | 10:30 PM
  #242
ahmadk's Avatar
2011 E550 Sedan
Originally Posted by Cabanclk550
clk550
I've never seen 20's on a clk... But pics would be nice
Old Oct 10, 2011 | 10:33 PM
  #243
clk550
ill post pics soon. im new to this thread so i gotta figure out how to upload pics lol.
Old Oct 10, 2011 | 10:35 PM
  #244
ahmadk's Avatar
2011 E550 Sedan
You. Can upload them directly to the site or to flikr or imageshack or any other site and copy-paste the link of the pic here
Old Oct 10, 2011 | 10:40 PM
  #245
clk550
heres from the back, its a good view of the rims
Attached Thumbnails ***Official Wheel/tire/stance Fitment Thread***-225166_10100725923230873_5235985_68619964_5384699_n.jpg
Old Oct 10, 2011 | 10:43 PM
  #246
ahmadk's Avatar
2011 E550 Sedan
A pic from the side would be better.. Cozz from here it doesn't look like it need lowering or maybe just a bit
Edit: I just saw it on my laptop... I think your car will look good with eibach pro kit IMO
Old Oct 20, 2011 | 01:10 PM
  #247
marandod's Avatar
clk w209 200komp
Wheels: AMG Style III replica wheels 18x8.5 Front 18x9.5 Rear ET35 all around
Tires: Sunny SN39700 225/40/18 Front - 255/35/18 Rear
Spacers: None
Suspension: Original
No issues with this setup
Old Oct 21, 2011 | 12:52 AM
  #248
ahmadk's Avatar
2011 E550 Sedan
this style in 18 looks nice
Old Oct 25, 2011 | 02:51 AM
  #249
marandod's Avatar
clk w209 200komp
thanks, other pics:
http://img819.imageshack.us/i/dscf1011pw.jpg
http://img10.imageshack.us/i/dscf1012v.jpg
http://img37.imageshack.us/i/dscf1013i.jpg
http://img189.imageshack.us/i/dscf1016a.jpg
http://img683.imageshack.us/i/dscf1018y.jpg
http://img834.imageshack.us/i/dscf1020bn.jpg
http://img853.imageshack.us/i/dscf1021bh.jpg
http://img52.imageshack.us/i/dscf1022b.jpg
http://img542.imageshack.us/i/dscf1023.jpg
http://img27.imageshack.us/i/dscf1024n.jpg
http://img853.imageshack.us/i/dscf1025y.jpg
Old Oct 25, 2011 | 06:57 PM
  #250
AMGY's Avatar
2004 CLK 55
Originally Posted by ld.Scorpion
Thaks !!!
I like the Kleeman wheels and the color
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
