Can the car Beep when locked?
On all our (other) cars, when you lock the car with the keyfob it beeps once to confirm that it is locked.
On the MB, it flashes 3 times.
Are there any secret settings that can be changed to get it to beep also?
Let me know if you get this to work...
Angelo
Beeps once on open, beeps three times on lock.
You can also increase the volume. I think stock is 30%, mine is increased to 80%. This volume also increases the panic alarm.
$400! Disgusting...definitely trying to rob you in front of your face...on to the next...
Angelo
There was no beep when I bought the car new (Canadian model). The dealership enabled this feature for me a few years ago.
I was reading on another thread about the installation of the SmartTop unit, and on the last page of the instructions there is s Step to "activate the horn for the Chirp function".
Now, I don't have the SmartTop, and am happy to just push the button inside, but I was reading the instructions anyway, just to see how hard a job it would be.
In this step, all you simply do is move a fuse in the engine fuseblock. Normal fuse holders have space for two fuse blades, but the holder for fuse 43 has 3, a left, center and right. OEM supply is installed in 43A (left and center), whereas this instruction tells you to move to 43B (center and right).
So I did this anyway, in the hope that it would be a magic solution to the beep, but naturally didn't work.
I assume that it must be something in the SmartTop that allows it to work?
Is a wiring diagram available that would show what 43A and 43B feeds?
Everything else seems to work just fine in 43B.
Fuse 43 is for the fanfare horn (i.e. vehicle horn, not the ATA siren). I believe the two positions control whether the horn circuit has power with the ignition on or not. In position "a", the circuit only has power with the ignition on, but in position "b", it has power even with the ignition off. I believe the SmartTop sends a CAN bus signal to activate the horn when locking/unlocking, but since the ignition is off, this can only work if fuse 43 is in the B position. If the vehicle is coded to use the ATA siren (as mine is), this has no effect.
I have heard that if you use SDS to code the car for "Netherlands" nationality, all other things will work properly as they do in the USA, but the ATA siren will be activated. Of course that means either buying your own copy of SDS (which I highly recommend for skilled and dedicated DIYers) or paying a dealer to do it (if they even will - some won't perform undocumented coding like that).
If you have a cabriolet, I highly recommend the SmartTop. It makes using the soft top so much better - no more worrying if you have the requisite 23 seconds at the next traffic light, or sitting still in the car holding the button. Also, you get to use the fog lights as DRLs and you get the lock/unlock beep on pre-MY2007's.
How is everybody?
