OFSSET PICTURES&SET UP THREAD
Old Mar 6, 2020 | 07:39 PM
  #126
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
Full CF kit installed
Carbonfiber Front lip n side skirts rims getting done in Copper Chrome n gloss black
Grill n Kit done
Old May 31, 2020 | 01:00 PM
  #127
Citybuild122's Avatar
2013 E550 Coupe Designo Edition, 2012 E350 Coupe, 2014 C63, 2018 GLC 300
Originally Posted by Turbo MB 550C
Here is my setup:Velocity Motoring VMR 721 wheels
F: 19x8.5 ET35 235/40-19 Michelin Pilot Super Sport
R: 19x9.5 ET 45 265/35-19
Schrader 28214 TMPS sensors
No rubbing with stock suspension even with taller tires to reduce fender gap. Had good luck with VMR wheels on my Audi S4 so decided to give them a try on the E550. MB wheel caps do not fit these wheels so I bought some MB logo wheel center cap stickers off Ebay to cover the supplied wheel caps.
Very happy with this setup. Handling, tracking and grip all improved over OE wheels and tires.
Has anyone else been able to run a 235/40/19 up front?
F: 8.5 ET30
R 9.5 ET45
Running 285/35/19 in the back and it looks like a 235/40/19 is the only way to maintain the 3% diameter rule.
Old Aug 22, 2020 | 01:21 AM
  #128
chopsticksonly's Avatar
E550C
Considering 2 sets of wheels - wondering if it'll fit stock suspension
front 18x8.5 +42 235/40/18
rear 18x10 +34 285/30/18
front 19x8.5 +38 245/35/19
rear 19x9.5 +44 275/30/19
Please let me know if there are better size tires I should consider with either options
Old Aug 22, 2020 | 01:59 AM
  #129
the first set will definitely work. I ran 235/40/19 and 283/35/19.
the second set will work but will require about a 20mm spacer up front. Don’t see any problems with the rear tire.
Old Aug 22, 2020 | 02:14 AM
  #130
Dnasty's Avatar
2010 e550 coupe
Originally Posted by pattyt
W205 C63s OEM wheels installed
Front - 19x8.5 et 38
Rear - 19x9.5 et 56
Front - Mich PS4 245/35r19 no spacer (needs maybe a 5mm)
Rear - Mich PS4 275/30r19 with 15mm spacer
Very nice fitment did you lower this? Also did you ever end up running the spacer in the front .. if so does it rub?
Old Aug 22, 2020 | 11:05 AM
  #131
E550C
Thanks for your quick reply!
For the set that will need 20mm spacer, is that for the 18" or 19"?
These sizing are for volk te37 wheels. 18" are SAGA, 19" are m-spec. Which set do you think will be easier to resell? I've always wanted a set of these wheels, and I'm thinking of pulling the trigger but a big consideration is resale as well. It would be a non-issue if they were 5x114.3, but sadly our cars run 5x112
Old Aug 22, 2020 | 11:49 PM
  #132
That's for the 19s. I went ahead and checked your tire sizes for you, and the second set will be perfect in terms of rolling diameter. Our cars require that the front and rear tires be within a 3% difference in rolling diameter. I didn't know about this when first modifying my wheels, and it basically sent the car into limp mode because of the speed sensors. The first set is a 2.8% difference. It's very close, but shouldn't be a problem. I was running a 2.7% difference at one point with no problems.
Old Aug 23, 2020 | 08:05 PM
  #133
E550C
Just a few questions - The front 19" is +38, wouldn't a 20mm spacer make it +18 which would be super aggressive? I also just took a look at the thread and seems like a lot of people are running 19x8.5 fronts with +35-+40. Also, the first set only has the rear tire change and it appears to be 1.19%. Could you clarify how you got 2.8%? Just want to make sure I am not misunderstanding.
Secondly, the 3% rule, is that the total difference? I calculated that:
front 19x8.5 +38 245/35/19 has -1.36%
rear 19x9.5 +44 275/30/19 has -1.84%
Since they're both negative, wouldn't the difference between the wheels simply be 0.48% which is way under the 3% threshold.
Thanks!
Old Aug 23, 2020 | 09:38 PM
  #134
Thanks!
First, I ran a 235/40/19 et43 with a 15mm spacer. It would not even fit on the car without the spacer. That would make it 28et. If I have a major bump the tire will occasionally hit the strut. You're adding another 10mm in width, which I assume will extend 5mm towards the strut, and 5mm towards the fender. You would 100% need a 10mm spacer just to even have it fit on the car, then 5mm to counteract the extra width you added, and another 5mm to get it farther away from the strut. 20mm spacer.
The 3% rule is in regards to the diameter of the tire. The first set, which is 235/40/18 and 285/30/18 has a diameter difference of 2.8 percent. 235's have a diameter of 25.4" and the 285s have a diameter of 24.7
The second set has a difference 1.2%, but I believe you thought I meant the 2.8% was for the 19's, but it's for the 18s.
Old Aug 24, 2020 | 12:14 AM
  #135
Stevie101's Avatar
2009 C207
Thanks!
I'm running 34.5 ET 19*8.5 with 235/35 in the front and it is flush. My rears are 48 ET 19*9.5 265/30, these could brought flush with a 10mm spacer.
As for the percentages, I can't comment suffice to say I experienced no error messages when the newbies were mounted.
Old Aug 24, 2020 | 12:36 AM
  #136
I'm surprised you were able to mount them. my 43 ET would literally not mount because of the strut without spacers.
You wouldn't have gotten an error message, your tires only have a 0.8% difference.
Old Oct 4, 2020 | 03:20 AM
  #137
Dnasty's Avatar
2010 e550 coupe
Rear - 19x9.5 et 56
How did you lower it and how much drop? Exactly the height I want mine and i'm running the same size wheels and tires.
Old Oct 5, 2020 | 04:34 PM
  #138
Neko 1's Avatar
2015 E400 coupe
Here's my 2015 E400 With Rennen CSL 3s Front 19 x 8.5 et35 245/35/19 Rear 19 x 9.5 et38 275/30/19 I have Amg Sport Pkg with factory 10mm lowered suspension <--- Fyi.
Old Oct 5, 2020 | 06:42 PM
  #139
Dnasty's Avatar
2010 e550 coupe
On the 19" setup that so many are using with 8.5 front and 9.5 rear wondering if you can go 10mm wider front and back on the tires or will it rub? Meaning 245/35 19 to 255/35 19 and rear 275/30 19 to 285/30 19. I currently have 19" vertini wheels 8.5" width front et33 and rear 9.5" width et38. Was hoping to get a little bit better ride, fuller tire look and more rim protection.
Old Oct 19, 2020 | 01:53 AM
  #140
PhuongNguyen's Avatar
2013 E550 coupe
Wheels
Heck I’m still trying to figure out if I will get 19s or 20s. I know 19s have more rubber and will protect better against potholes. But 20s look so nice. I will probably drop on bilstein b14s.
Old Oct 20, 2020 | 03:51 PM
  #141
pattyt's Avatar
Here for my Uncles 2004 E270
Lowered on H&R springs. I don't recall what the drop was, but it's just on the springs.
Spacers are installed in the rear to bring the tire flush with fender. I have a slight amount of rub between fender and tire, you can just see the marks on the tire from the contact. Literally would need 1mm more clearance to be OK.
Old Oct 20, 2020 | 03:52 PM
  #142
pattyt's Avatar
Yes lowered on H&R springs.
I didn't end up running a spacer in the front. I may consider adding a 3mm or 5mm in the future to help space it out just slightly more.
Old Oct 20, 2020 | 04:31 PM
  #143
Dnasty's Avatar
2010 e550 coupe
Another member has almost the same exact setup as you but with spacers on the rear springs like you mentioned. It would be great if they made springs for this car that did not lower the rear as much as this seems to be an issue. Does your car have the sport suspension?
Old Oct 23, 2020 | 08:11 PM
  #144
Bailey5's Avatar
w207
need opinion
please looking to slap on a set of wheels amd heres the specs
front 19x8.5 et 32 looking to run 245/40/19
rear 19x9.5 et 41 looking to run either 275/40/19 or 275/35/19
need opinion if either those rear tires will be ok within the 3% range .
thank u all in advance.
Old Oct 23, 2020 | 08:34 PM
  #145
Dnasty's Avatar
2010 e550 coupe
The spacers you mentioned are for the wheels and not the rear springs correct?
Old Oct 23, 2020 | 08:38 PM
  #146
Siegmann's Avatar
10-second E550
For the tires, 40 ratio is too big.. 35 is much better.
As for the percentage difference, just an FYI, I've exceeded 5% without issues (RWD).
Old Oct 25, 2020 | 06:42 PM
  #147
Bailey5's Avatar
w207
40 profile
looking to have a more comfy ride lol
Old Mar 18, 2021 | 02:53 PM
  #148
m1l3n's Avatar
2013 C300 4Matic
I want to buy Mandrus Miglia wheels for my e550 coupe and even though ive read this thread up and down for the "optimal flush offset", it appears 8.5" +35 front and 9.5" +45 seems to be optimal.
How would 8.5" +32et front and 9.5" +48et rear fit? Would the fronts protrude out of the wheel wells? I'm looking for a flush to slightly less than flush look
Old Mar 18, 2021 | 04:48 PM
  #149
Stevie101's Avatar
2009 C207
My fronts are on 8.5 with a 34.5 ET and on 235 tyres, and this is flush for my C207
Old Mar 18, 2021 | 08:44 PM
  #150
Bailey5's Avatar
w207
so
so I tried the 245/40 and that was not a good ride at all for me so I got 235/35/19 In the front and the car rides beautifully and perfect offset I feel. still running 275/30/19 and there perfect im happy with look and ride comfort and wheel gap.
