Lowered front end today in 15 minutes
https://mbworld.org/forums/showthrea...threadid=43817
Lowered just the front end of my E500 today. Was REAL easy, taking about 15 minutes and eight small washers. Front end came down about 1 inch. Still can't do the rear on the E without airmatic adjustment, but this about evens out the front and rear tire/fender gap. More detail and some pictures on the E55 site. I would highly recommend it to anyone looking to reduce the gap up front. It really is so easy, and you can adjust depending on how many washers, or how low you adjust the bracket. Here is the link to the E55 site...
nice pics, i thought i saw your car by costco in carmel mtn a month ago, where do you live again in SD? and how much was the kit, nice look man, thanks
I live in PQ. There really is no "kit" to buy. I used the OEM brackets, and just added 4 small washers to each side. Very easy, just 30 minutes and about $1.00 worth of washers. Still trying to figure out the rear on the E. I don't think there is a way, other than adjusting the airmatic. If anyone has any other ideas, pls post. Here is a pretty fuzzy picture of the washers installed on the bracket...
Peter
Great job EPower. Any chance you can do a DIY for this? I can't tell in the pics WHERE the brackets are.. and where the washers are. Too fuzzy. Did you have to remove a tire to access it?
Peter
Here is a where to look for the bracket...
Here is a closer view inside the wheelwell...
And this is the fuzzy picture with the washers installed...
Also, how's the Air-intake mod you did?? I haven't heard very much after your original post with the pix.
Peter
I have no desire to "slam" my car - just take out the US-spec adjustment. Do you think the rear needs adjustment, or OK from the factory?
Thanks E!! I will give that a shot this weekend... gotta get a jack and the washers. Any particular size??
Peter
As for the intake mods, it works great! I am still waiting for the guys at Powerchips to finish their programming to remove the top speed limiter on my car because they have also re-tuned the ECU for more response, and I will get the ECU remapped for both at the same time. The intake mods will be even more effective when the ECU is again retuned.
Someone else posted about the rear being on the rear roll (I think they meant sway) bar. I have removed the rear wheel, but can't find anything. I am going to put it up on a rack at a buddy's shop this week to take a look, but I have heard that the rear does not have the same type of adjustment bracket as the front on the E series...too bad.
Intake materials...
Installed heat shield...
Epower where you can buy this washer? is it sold in kragen or something like that? thx
The $2000 lowering module is history for MBWorld members. Long live washers!!!!!!!!!!!!!!!!
.. but the rear still hasn't been figured out yet right?
no kidding man
someone said that you can lower it by moving a part on the rear, he did 2 inches, it should be in this thread
http://www.mbusalearning.com/w211elearning/sas/pg21.htm
Thanks to tbone for giving us the scoop on the rear sensor. There is only one, located on the rear sway bar. I even found a description and good diagram of it on the mbusalearning web site I think all of us have looked in the past couple of weeks. Here is the exact reference to the diagram...
Bottom line is this, for the cost of a few washers and maybe a total of 1.5 hours of your time, even someone who has very little mechanical experience can lower your E to where it looks much more natural of a ride. Not the stock 4x4 look, or the slammed down look either...
Another note for people trying it out. You have to constantly adjust the height of the car. Meaning, when you lower the front, the rear will raise. When you lower the rear, the front will raise. When you lower the left, the right will raise, etc.
It takes a while to fine tune it and get it all even. I suggest a ruler.
