Bulletins 207 coupe & 212 sedan
https://mbworld.org/forums/e-class-w...-bulletin.html
Not aware of any bulletin request switch block (upper control panel) be replaced under warranty. EPC documents original UPC installed at production is replaced.
Does anyone know if there has been an update to this issue yet? Have they found a cause / solution?
I have to spend $2500 on new DPF for my Bluetec, what comes with over >2 months wait for rebuild to come from Germany.
I have MI showing DPF replaced 60k miles ago , so something is very wrong with this situation and having "the brick" occupying my garage for 2 months is not making me happy. Even I am happy with it when it drives
Seems only PZEV vehicles do have 10 years/150,000 miles warranty on emission parts.
Mine is ULEV and looks like 250 Bluetec was never PZEV.
Funny to observe maze of laws. What was in past called "California smog requirements" now is observed in 7 (?) states and the number keeps growing.
Meaning in any calendar year you can have E class build with at least 4 different smog requirements.
Service Campaign 2017120010 AUG18 – 2017 & 2018 213, 253 (GLC) front air suspension struts may not meet current production specifications, dealer will replace. Approximately 1,339 vehicles affected.
LI46.35-P-068762 SEPT18 – 213 up to VIN A048221 scraping or squeaking noises when steering from lock to lock, replace electric steering.
Thanks for all the info on this thread. I have a W212 E63 with 59000kms and extended motorplan till 2020.
Can you help,with the data sheet for this car, here is the Vin WDD2120742A63829.
What are the key TSBs I should be looking out for?
thank you
WDD2120742A638291
Recall Campaign 2018120012 DEC18 – 2010 & 2011 212, 164, 251 Takata front driver side airbag, dealer will replace the front driver-side airbag on the affected vehicles. Approximately 24,602 vehicles affected.
I recently bought a 2014 E350 4matic in October and it has a rubbing/grinding noise that comes from the right front end when I back up, I thought it was a clearance issue with the tires but my husband says the tire isn't touching anything when I turn. It has gradually gotten worse over the past 2 months so I'm not sure what it could be from. Do you have any ideas on what it could be from? Also could you please get the data card from my vin: WDDHF8JB7EA981175.
Thank you sooooooo much!
Thank you very much for the courtesy!
Bill
