DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
I like the factory look, the 10" unit looks tacked on. (for some reason manufactures think we like that, hear me M-B!!)
My wife has Factory Android Auto/Carplay in her car and she doesn't like my system because it's not touch screen, the knob is a bit confusing. If you use it everyday then it's not a big deal.
Unit looks identical to the new units but for far less, ordered one will see if it's for real
Thanks for an amazingly informative thread.
The sight issues I have are 90% of the time it loads in night mode and can not change it to day mode. And when you use the left steering wheel controls it moves the CarPlay menu. Also if you want to use the car radio you lose the sound from CarPlay as it needs to be on aux to get the sound. I use a radio app which is ok as long as you have cellular connection. Hope this helps.
I just saw, that the BMW version got an update with OEM BT Call option : https://f30.bimmerpost.com/forums/sh...postcount=4358
Do you think it is possible to port this over ? I allready asked RoadTop on there Whatsapp chat, sadly they seem a bit "locked up" on further updating the thing (they are ok with fixing, but not adding functionality it seems).
Maybe if we all ask them, they will listen ?
Just to add to the discussion : My sound doesnt work without the MMI Aux plugged in (which is not so bad, as I had to unmount everythig for the roadtop unit and so not much had to be changed...
Maybe if we all ask them, they will listen ?.
Also, it's already possible to use the native MB bluetooth for calls with CarPlay (I don't know about Android Auto) if the phone is also connected to MB bluetooth and you do this:
https://mbworld.org/forums/e-class-w...ml#post8129703
The downside of the work-around is it tells the phone to try to use a bluetooth headset all the time. It could be an issue if you have another BT headset paired with the phone when not in the car.
Problem for me is that there is a smartwatch on my wrist all day and a OBD2 Module for drive logs (because of work), so messing up bluetooth is a bit of a pain...
It would be great to decompile both firmwares / make a custom one (if even possible) but apart from theoretical knowledge, I sadly wouldn't be able to do much...
A partially fit audio cable could easily explain the issue, especially if its left vs right speakers (the signal is stereo L &R). Unfortunately, if that's the case then I think the first step is to verify that the Joyeauto audio cable is fully seated at both ends.
If the cable is fully seated then it's something else. Examples: bad audio cable, harness wiring problem, or the Joyeauto unit itself.
FWIW, the only email I had for Joyeauto was sales@joyeauto.com and they responded fairly quickly considering the time zone difference.
After I installed mine I also noticed an email for tech support: tec@joyeauto.com.
The setup went virtually identical to the behavior of my Road Top unit, and was in all respects much improved. I tried to mess up the connection and reconnect to CarPlay several times and it all worked flawlessly, unlike some the 'quirks' I'd sometimes see with the Joyeauto unit. It will take some more testing and playing around with it, but if the initial impression holds I'd say it's a major improvement to one of the relatively weaker aspects of the Joyeauto unit compared to the newer units.
I'm looking forward to playing with it some more before making any firm conclusions.
(Note that I'm also on iOS 14 Beta.)
Is there a detailed set of instructions for this newer version via a manual or video that I can pass on to the installer? Any other specific instructions I should let him know about? Should I get him to install the USB to the centre console for better quality I assume?
https://www.mercedescla.org/threads/...015-cla.40239/
I didn’t run any cables into the arm rest as per cadetdrivr.
Space is a bit more limited for the cable harness in the CLA so just have patience. There is a small void below the head unit which you need to tuck as much of cable into before you can get the head unit back into place.
Assuming it is an active port, it depends on how the Firestick implements DRM. If it ends at the Firestick then it should work fine. One way to check is to connect one of the cheap HDMI-USB video capture cards (on Amazon for ~20) to a computer, fire up OBS (a free OS video capture program that is awesome) and see if it can record video and sound then you should be good to go if the Joyeauto interface supports HDMI.
Anyways, my 360 surround issues are now fixed. So far it’s working 100% after I updated to MCU 20.7.16.18 firmware. New unit also shipped with MCU 20.4.30.17 as did my original.
However, the difference is my new unit has CUST Version: v2.1.0.8.lt.m4_2
My old unit with the problems shipped with CUST Version: v2.1.0.6.lt.m2
Both are HW: BENZ2.
So I’m not sure what the cust versions mean but that might have been the issue for me. I still think it was just defective hardware since it sometimes worked and sometimes didn’t.
The old unit also doesn’t turn on when it’s super hot inside the car.. it’s been 100+F several days in a row here in California and it has been consistently starting up with a black screen. After 10 minutes of AC blasting and cabin cooling down, the screen comes back. Or after several restarts by holding down back button.
Anyway, tomorrow is another 105+F weather, I will see if this new unit has any issues with the heat. Also, the user manual has about 6 more pages and new pictures than the old manual.
My 360 camera runs when I hit reverse, but when I go back to D it will go back to the AA screen, road top not offering new firmware to fix it.
Also in AA Google maps, are you able to move the map around using the controls? I can only zoom in and out
(In carplay that function works)
I am able to move the Apple map with the knob’s directional buttons vía CarPlay. I don’t know about Android Auto, since I don’t have an Android phone.
Correct, as of now RoadTop does not have a fix for cars with factory 360 camera when transitioning to D gear. Some other models claim it works for them 100%. I’ve had two RoadTop units and both are the same scenario. Not sure if it’s some setting in my Head Unit that is different or something..
Anyway, high cabin temps still cause a black screen for me for until cabin cools enough.
