Sponsored by: CARiD
And I thought only software has bugs
Old May 19, 2025 | 01:59 AM
S-Prihadi's Avatar
Sharing..............
How in the hell can this dude enter my completely sealed LED type tailight ?
Must be since 2013 ( made in Europe tailight ) and only yesterday it migrated to a visible location ????
Can dry dead bug look so good for 11 years ????
My tailight is LED and totally sealed.
This type :
The blackie foam is only to seal light towards car body opening so water can not enter car body.
I think this is the bug species
https://keys.lucidcentral.org/keys/v...s/adoretus.htm
Old May 19, 2025 | 05:03 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
I guess it's like the fancy open LED headlights
"open concept" LOL
bugs welcomed
your hairy bug looks more tropical than central European.
Google search can likely put a name on the type and region
Old May 19, 2025 | 10:05 AM
DFWdude's Avatar
2016 E350 Sport
I need to search your older posts to see how many times you've removed that taillight from your car.
Old May 19, 2025 | 10:12 AM
S-Prihadi's Avatar
Only once Senor
Old May 19, 2025 | 01:12 PM
superswiss's Avatar
2019 C63CS
There must be an opening somewhere. On a side note, software bugs are called bugs because of an incident in 1947 where a moth caused an electrical fault in the Harvard Mark II computer, so what you have here is an original bug....haha!
Old May 19, 2025 | 06:57 PM
W205C43PFL's Avatar
Does it also have something to with how the word "bug me" started?
Old May 19, 2025 | 06:58 PM
W205C43PFL's Avatar
OP, you are not alone, more common than you think:
https://mbworld.org/forums/c-class-w...tailights.html
https://mbworld.org/forums/c-class-w...il-lights.html
https://mbworld.org/forums/e-class-w...t-housing.html
Old May 19, 2025 | 07:00 PM
W205C43PFL's Avatar
Here is more:
https://mbworld.org/forums/e-class-w...taillight.html
https://mbworld.org/forums/c219/2980...ear-light.html
Related but also not related, here is something cool: https://www.thesun.co.uk/news/319407...oldfish-in-it/
Old May 19, 2025 | 07:04 PM
superswiss's Avatar
2019 C63CS
Similar I guess. This is what Google AI has to say about that.
The slang phrase "bug me" means "to annoy or irritate" and is likely derived from the literal meaning of "bug" as an insect. Just as insects can be annoying, the act of bugging someone is to bother or pester them. The phrase gained further popularity in 1995 with the teen movie Clueless, where the character Cher uses the term "totally buggin'". ​​​​​​​
Old May 19, 2025 | 07:10 PM
GOOGLE HAS EYES
creepy crawler...
creepy crawler... juicy
Old May 19, 2025 | 07:36 PM
W205C43PFL's Avatar
Uh oh, things are getting creepier.
Old May 19, 2025 | 07:41 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
My '05 E320 had, from the day I bought it in '14, a rather long legged spider in the taillight.
I hate spiders.
I left it there.
It's likely still there today.
Old May 19, 2025 | 07:46 PM
superswiss's Avatar
2019 C63CS
Yeah, tiny insects have a way to find their way into anything it seems. In one of my previous cars I had a bug that found its way into the third brake light and made it its final resting place.
Old May 19, 2025 | 09:27 PM
W205C43PFL's Avatar
Did you ever figured out where they got in from or perhaps didn't bother?
Old May 19, 2025 | 10:09 PM
superswiss's Avatar
2019 C63CS
Nope. I didn't bother.
Old May 19, 2025 | 10:46 PM
W205C43PFL's Avatar
I thought so, it probably wasn't worth the time.
Old May 19, 2025 | 11:58 PM
S-Prihadi's Avatar
THANK YOU ALL OF YOU GUYS
I took a closer look at my old photos, DANG, the rear tail light is not 100% sealed like front LED 641.
I think I know what happened.
I been spending some days at my friend's private marina and at times due to my working gear in the trunk, I kept my trunk door open like 30 minutes or more.
Where I parked, it is close to some trees. I even got bird poo on my car paint work.
That is how the bug got in, must be., now that I know the rear LED assy is not 100% sealed.
This is the first time I actually carry lots of work gear inside my trunk and have it open for that long.....DUGGGHHH !!!!!
I will tear the hairy liner down and replace my Bilstein B6 to B4 while at it and get some fumigation smoke cannister. or use my ozone machine.
What an experience. Good thing it is not cockroach, I have phobia to cockroach.....YUCK !!!
Old May 20, 2025 | 09:10 AM
W205C43PFL's Avatar
Woah you found it! Mystery solved.
Old May 20, 2025 | 09:39 AM
S-Prihadi's Avatar
Well, the bug has to have body squeeze capability like octopus.
The vent slits are very small, I HIGHLY doubt the bug can enter ............ I inspected the tailight some hours ago. So intrusion mystery still need solving
I relocated the bug to most left side.
I dare not shake bug into tailight interior, because if it is not dried up, its blood or liquid or juice..... can cause short circuit.
I
I ozone-ded my trunk. 400 gram per hour x 2 unit. For 30 minutes.
I turned ON my HVAC blower only ( engine OFF ) to create a bit of positive pressure using FRESH AIR flap open.
First it was 3 bar speed, later I set to 1 bar. 3 bar too much air loss to the sides of rear bumper auto vents.
Only need approx 13 amps ( 1 bar fan speed) and 0.5 amp is for battery charging. I love this Riden superb power supply.
Wet wipe my entire trunk floor and vacuum it too.
Blackie stuff is 3M sound deadening mat/pad.
https://www.3m.com/3M/en_US/p/d/b40068137/
Old May 20, 2025 | 09:49 AM
DFWdude's Avatar
2016 E350 Sport
If you are not going to remove the insect (as others have done), then I'd give it a name and move along... I like "Swat"
Old May 20, 2025 | 09:58 AM
S-Prihadi's Avatar
S.W.A.T it is then , since no way I can remove it. Tailight is glued dead by MB.
Old May 20, 2025 | 10:01 AM
DFWdude's Avatar
2016 E350 Sport
OK, good. SWAT (the bug) it is.
Old May 20, 2025 | 10:11 AM
W205C43PFL's Avatar
https://cimg1.ibsrv.net/gimg/www.mbw...9c9915ea31.jpg
Ihttps://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/1720x950/f1_71cb811d45ea80f0567473b22d8ec75b7b7d2ee2.jpg
https://cimg1.ibsrv.net/gimg/www.mbw...e671aad111.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...649de22add.jpg
https://cimg0.ibsrv.net/gimg/www.mbw...9ec6afd536.jpg
https://cimg9.ibsrv.net/gimg/www.mbw...6450c9789b.jpg
https://cimg0.ibsrv.net/gimg/www.mbw...1bcfaff887.jpg
https://cimg3.ibsrv.net/gimg/www.mbw...ae656e6f15.jpg
https://cimg5.ibsrv.net/gimg/www.mbw...09e8cfba48.jpg
https://cimg9.ibsrv.net/gimg/www.mbw...a4c58701ee.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...ce4dfb4d3a.jpg
https://cimg1.ibsrv.net/gimg/www.mbw...3f9df86115.jpg
Perhaps we can um... uh... shake it off (out)?
