Code Scanner
What are you guys using?
https://www.amazon.com/LAUNCH-Merced...84&sr=8-5&th=1
Tell them if they are not willing to help, you will go to a different dealership for future service needs. (Unless you have a good relationship with your SA though, then don't say this.)
believe their website is: Cars often.de
Good luck.
Nonetheless, having made my "fortunes" in embedded hardware and software, I would advise continuing to look for a code scanner for the W214. There are a number of possible reasons for the list of issues the technician noted. It could be software only, but it could also be an intermittent hardware issue. I would continue to monitor for errors. At the least, it will give you information that will either be re-assuring (no errors, all good!) or will give you discussion points (errors, but no warning light yet) to cover with the service advisor.
A little more detail... The theme through the diagnostics write-up was communication issue related. In product development, once the hardware is shipped it is very expensive to fix a hardware design or manufacturing defect. For this reason, the hardware is (should be) capable of being "modified/adjusted/tuned" by software. This is particularly important in communication components because they are susceptible to noise that may not have been anticipated and/or tested for in development. We can compensate with simple things like reducing the communication rate (talk loud and slow!) or, more often, pre-compensation/equalization and other techniques to deal with these problems, if they arise. So, a software update may have compensated/corrected the communication problems, but it may also have just restarted the parade of errors that will lead to another warning light.
The electrical engineer said "I'm sure we have a dead battery".
The chemical engineer said "I'm sure we bought some bad gas".
The mechanical engineer said "I'm sure the timing chain broke".
The software engineer said "Everybody get out of the car, count to 10, and then change seats".
