Screeching Brakes on the GLC
I got my car back last Wednesday - they addressed all my issues - the radio now works as they replaced the satellite radio control unit - they replaced all brake pads with supposedly new harder pads and added copper paste and brake quiet - they also did a software update for electric power steering control unit to help with the vibration(which I think helped a bit, but more on that in my next post) - they also adjusted the passenger side door strikers to help align the doors and trim - looks better but not perfect - overall I am happy with the service from my dealer.
Thanks for the update. Try cleaning your wiper blades with denatured alcohol. Nothing worked for more than 1 week until I tried the denatured alcohol. They've been running smooth for over 3 months now, and that includes light or heavy rain as well as low or high driving speeds.
Service Manager calls me and finally leveled with me, saying, they really don't know what is causing the problem and he doesn't know if the brake pads are the right fix. He suggested I bring my car in so he could put some new pads on and start an official record of my product problem. (This is important if any of you want to pursue a lemon law action down the road).
So, today I got the car back. Oh, and by the way, the loaner car GLC screeched like crazy too! So far, the brakes don't screech. However, I have zero confidence this is the end of it.
On another note, I am not a MB mechanic but I am a degreed Metallurgical Engineer and worked in material design and product failure analysis of heavy construction equipment for many years, now retired. Anyway, I suspect the problem could just as easily be with the brake rotors as with the brake pads. Was there a material change, heat treat change, etc. Something is going wrong with this wear couple to cause the rotors to wear or create grooves that like to
sing when pressed together...just thinking here. I asked my MB Service Manager if they had considered the rotors in root cause analysis and he quickly said that was not the cause, then backed off and said he didn't know.
So friends, I am filing away my service record and will use them to pursue a lemon law settlement if this isn't fixed. I'll update as the story unfolds.
Trying to narrow down the circumstances. Thanks...
i usually reverse first thing almost 100% of the time so that's usually when i heard it
with temperatures in the 20's would do it them as well as for a little bit when going forward
in all probably no more than 2-3 seconds of loud noise
I had the fix done in March 2017 per LI42.10-P-065628 & LI42.10-P-065058) and the screeching has not returned like it was doing since. Yes, in the coldest days this winter here (temperatures in single digits-teens Fahrenheit), I heard a very short mild squeek when backing up, but nothing like the original problem. Also, I now get brake dust which I did not get with the original brake pads, but I'll take that over the banshee-like screeching. Oh, and I am currently at 16K miles. I THINK that if the problem was going to come back, it would have done so by now.
Looks like other car manuf are having the same issue, but doing a “spin doctor” to educate drivers that’s it’s totally ok to have this annoying noise, as it’s part of the design, characteristic or whatever you want to call it. First time I’ve read or heard of a brake disc being likened to a speaker !
I’ll have to rethink how I judge my Sonos or B&O systems and how hard I can drive them, before braking........ or wearing out the speaker cones.
https://www.motorauthority.com/news/...t-brake-squeal
Enjoy.
One take away is that MB I am told changed pad supplier earlier and as a result brake squeal intensified, possibly cheaper supplier ?
They have reverted to older supplier, with curved ends to minimise squeal.
Hope this video helps understand some of the issues with brake squeal. Reversing and getting squeal not discussed with this presentation.
Enjoy.
When I returned my GLC to M-B service with the noisy brake gripe, the service manager listened patiently, gave me a loaner, called me the next day to tell me they replaced front brake pads, no charge, problem solved.
Noisy brakes on any car - unacceptable, especially an expensive machine such a Benz or Porsche.
I live in Canada and I have a 2017 GLC300 with AMG nigh package. My break squeak after driving for about 5-10mins and it is loud. I get all the symptoms, squeak in reverse and forward. Dealer has tried to fixed it 3 times and still the same problem.
Should and can we start a class action law suit against MB?
