Courtesy light in extertal door handle
Has anyone any experience with repairing /replacing the light on the external door handle ?
Rear door light stopped working.
Haven't done it on a GLC yet but on a 205 or 213 you have to remove the door card, then the carrier plate that holds everything, then the handle and latch assembly, then you can replace the LED light. Horrible design. Also, once you replace one, they often don't match in color to the others, so you end up changing all 4 to make them look the same.
It should be covered under warranty. LED technology should last thousands upon thousands of on/off operation. There is no excuse for no warranty coverage.
I'm inclined to agree with you....and in the last hour I have noticed that the 'eyebrow ' light along with the tail light on the right hand side have switched themselves on while the car is parked!
Now need to search for this issue and see if a solution has been found! !
