Dealer won't cover blind spot assist problem
I got a Blind Spot Assist Inoperative message the other day, and sure enough, the red warning triangles failed to light up when they should have - both sides - so I took it into the dealer first chance and here's the invoice, verbatim:
"... Performed quick test. Faults in both rear radar sensors with communication to right front door module. Fault in RF door module for output for lamp of blind spot assist warning. Removed RF mirror glass to check wiring. Found excessive resistance in warning LED. Removed and replaced glass housing with integrated LED to remedy."
The dealer, saying that it is a glass problem and glass is not covered under warranty, charged me $415. But it looks to me from this description that the problem is in the sensors and wiring, which are under warranty; the glass is merely where the warning LEDs reside. There is no internal or external (as in collision) damage to any of these parts.
I haven't seen the actual assembly and if I did I might change my mind, but so far it looks pretty clear to me that it is an electrical problem and should be covered under warranty.
What say you? I'd like to hear from some knowledgeable people before I take it to MBUSA. Thanks
This is nonsense and indicates a bad dealer. That's like saying your battery isn't covered because it has water in it, and water is not covered by the warranty.
The part that failed (component with integrated blind spot LED) is covered by the warranty. If they push back, get a detailed written statement (demand it if you are forced to) from the dealer's warranty manager explaining why they declined to honor the warranty on this specific part. Then escalate to MBUSA for an apology and reimbursement.
ChinaBob (10-10-2018)
2019 GLC300 4matic
I anin't "Knowledgeable" about MB,. I have owned my MY2019 GLC300 for 3 days
But here's what the warranty says in the ITEMS NOT COVERED section:
DAMAGE TO GLASS: Glass breakage or scratches are not covered unless positive physical proof of a manufacturing defect can be established.
Your description doesn't mention your glass being broken or scratched so I don't understand why your.vehicle's operational failure is not covered.
Keep pushing back/fighting.
This should have been covered. I would escalate to the service director at the dealership as well as MBUSA.
Got a call from the dealership this morning. They agree that it should be covered under warranty but MBUSA won't budge so the dealer is reimbursing me for it out of pocket.
I wonder if it had anything to do with the negative review I gave the dealer over this issue on dealerrater.com? Hmmmmm
2019 GLC300 4matic
Good for you!!
But scary that the dealer says MBUSA won't pay? I have owned a MY2019 for only 7 days and was thinking about buying the extended warranty. I read I can buy it within 30 days of purchase. Now I'm not sure I want to deal with MBUSA for an additional three years....
One further note on this that might have made a difference, though it shouldn't have.
I drive a lot of miles and intentionally bought a CPO because of the unlimited-mileage CPO warranty, which, at least in this instance, reads exactly the same as the new car warranty. The car has almost 62,000 miles on it and this was my first claim under CPO. They didn't say so, but they may have balked because of the high mileage. If that's the case, they're going to have to get used to it. I also bought the 2-year extension, which means that it's under warranty until January of 2024, by which time the car will have over 200,000 miles on it.
I'm not a warranty admin, so I'm not sure where the policies are laid out, I just know we have to check every time that something is covered before assuming it will be under warranty just because it has CPO or extended warranty, where with the original 4/50, as long as it isn't outside influence damage, it's covered.
ChinaBob (10-13-2018)
Hard to say, but we run coverage on everything that is failed on a CPO car. Things like light sources, trim, almost always are not covered on CPO. There are also different levels of CPO, Base, Total, and then there's ELW you purchase, they go from lowest to highest coverage it seems.
Can you say more about "different levels of CPO, Base, Total" and "ELW ... they go from lowest to highest coverage"? In both cases I got the MB warranties. The CPO is automatic when you buy a (slightly) used car from an authorized MB dealer; the extended warranty also came though the dealer. In other words, it is not a 3rd party warranty.
This seems to be confirmed by my Mercedes Me app and the MBUSA website which show my
Warranty Information: Active thru Jan 3, 2024 or 999,999 miles
With copy of dealer Repair Order - or Service Invoice - in hand - regular business hours call Mercedes Customer Care (800) 367-6372 - calmly lay out the facts to them - will take the information from you - then they will start a 2nd channel back to dealer management to get this resolved.
Thanks for the info - this is helpful. It looks like I may be facing closer scrutiny on warranty claims from now on.
