Brake question
Thanks all
Being as you are in Ocala, call Will Tucker at Tucker Motorsports. 352-361-8463.
I would be happy to assist in any way you may need (I am NE side). Did your brake lamp come on (from a worn sensor)?
Yep, could be if you did not have the rotors faced. Could have glazed the new pads. Could be a few things.
Thanks all
No, you don't have to change rotors when you change pads. The rotors need to be measured and checked for runout, but in most cases rotors outlast at least one set of pads.
The perforations in the rotors are not drilled, they're cast in, eliminating the stress riser component, so yes they can be turned, to a specified limit.
I don't think Mercedes rotors are prone to warpage like BMW has been in their past.
Finally, if squealing is your main concern, first try doing a good bedding-in process. Odds are good that that will fix your squeal.
So they aren't drilled rotors? I thought they were this whole time.
When you say bedding-in, what do you mean exactly?
