SOLVED - Engine rattle on startup, timing chain rattle on low rpm driving
Old Nov 29, 2024 | 12:21 PM
Bertie_'s Avatar
GLK350, SL500 (R230), E55 (w210)
How: Disconnected the low-pressure oil pump solenoid on my m276 (2013 GLK 350)...
Solved:
- Engine rattle on startup (when hot)
- Low rpm rattle when driving around town
+ And the engine feels more responsive and smoother
I'll report back if any fuel economy change, but regardless I am leaving it unplugged. The engine feels much healthier and just like it should from the factory...
Pretty shocking, wanted to share. I was thinking about upgrade the timing chain tensioners... not anymore.
More info:
https://mbworld.org/forums/w212-amg/...solenoids.html
Old Nov 29, 2024 | 12:31 PM
W205C43PFL's Avatar
Solved:
More info:
Old Nov 29, 2024 | 02:11 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Interesting concept. Another case where chasing tiny incremental improvements in gas mileage (to meet CAFE standards) causes MUCH bigger problems than it solves.
My only question is, is there a similar (bad) system on the M272 engine? It seems to be devoid of most of the issues of the later version engines, and of course, the GLK never had an issue with the balance shaft problem since that was sorted by 2008...
Old Nov 29, 2024 | 02:20 PM
Bertie_'s Avatar
The m276 has TSB's on startup rattle for pre-2014 models
I had the symptoms and my engine falls within the "replace timing chain tensioner and check valve"
Deactivating this low-pressure solenoid just fixed it
Old Nov 29, 2024 | 02:40 PM
Mmr1's Avatar
2013 glk 350
How did you figure it out? The oil pump is mechanical right, how can it be controlled ? Where is the sensor ? I have a 13 with some noise.
Old Nov 29, 2024 | 02:45 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Hmmm. There are folks with 2014+ reporting the same
What about this example (I may have misunderstood the diff):
https://mbworld.org/forums/glk-class...-rattle-2.html
There's an old saying, "only time will tell". 🙂
Where's confident evidence this works for others IN THE LONG TERM?? Doing this disconnect "fix" may alleviate the noise, but not the underlying issue
Old Nov 29, 2024 | 03:01 PM
Bertie_'s Avatar
I just read this: https://mbworld.org/forums/w212-amg/...solenoids.html
and made a decision for myself
Running at "normal" oil pressure has solved these problems for me
Old Nov 29, 2024 | 03:02 PM
Bertie_'s Avatar
Time will tell... the chain tension and VVT are all oil pressure driven
Car is running great and I'm happy
Will provide an update if I ever notice symptoms return
Until then, I'm happy to be running "normal" oil pressure
Old Nov 29, 2024 | 04:19 PM
habbyguy's Avatar
2011 GLK 350 4Matic
From everything I read, it sure seems like a safe and sensible "modification". Basically all you're doing is to eliminate the "low oil pressure operation" of the engine under certain conditions. And given the issues that the M276 has with oiling, that can only be a good thing (IMHO, YMMV).
Old Nov 29, 2024 | 04:25 PM
W205C43PFL's Avatar
FWIW these are the benefits I had when I first unplugged it: https://mbworld.org/forums/w212-amg/...ml#post8963720
Different vehicle but same engine.
Here is the survey (linked in the big thread) of people with different models and engines unplugged: https://forms.office.com/Pages/Analy...g1Mkw1WkJVNS4u
Old Nov 29, 2024 | 04:29 PM
Mmr1's Avatar
2013 glk 350
How do I unplug sensor 2013 Glk 350
Old Nov 29, 2024 | 04:51 PM
habbyguy's Avatar
2011 GLK 350 4Matic
The linked threads (very long) do show diagrams of the location of the sensor. Looks like it's just to the right (car's right) of the crankshaft pulley, and reached from underneath (only). There are photos and diagrams showing the location.
Old Nov 29, 2024 | 05:10 PM
W205C43PFL's Avatar
This is correct, depending on if you have 4MATIC or not, you might be able to do it from the top here are some helpful links I gathered: https://mbworld.org/forums/c450-c43-...ml#post8979570
Old Nov 29, 2024 | 08:59 PM
Mmr1's Avatar
2013 glk 350
I guess the low pressure is so pressure is kept low when motor is cold to not over pressure if you drive hard. Does this go bad?
Old Nov 29, 2024 | 09:53 PM
Bertie_'s Avatar
I think it's entirely a fuel economy thing
Low pressure is ~25psi, "normal" pressure is ~55psi
Old Nov 29, 2024 | 09:54 PM
Bertie_'s Avatar
If you go from underneath, after removing the underbody panels, it is very easy to access.
Old Nov 30, 2024 | 11:23 AM
W205C43PFL's Avatar
Please see the big thread: https://mbworld.org/forums/w212-amg/...enoids-96.html
Old Jan 15, 2025 | 10:02 AM
Bertie_'s Avatar
Update: Car runs great.
No noticeable difference to fuel economy.
No rattle noises on startup and more responsive acceleration at low RPMs
Old Jan 15, 2025 | 10:22 AM
Mmr1's Avatar
2013 glk 350
This is why I want to measure oil pressure , I have same noise , it’s gone when warmed up but how much damage has been done already? Probably an expensive amount
Old Jan 15, 2025 | 10:46 AM
calder-cay's Avatar
And this quote from Post #15 in this thread:
====> Low pressure is ~25psi, "normal" pressure is ~55psi <====
Hey, @Bertie_ ... so, since you know you're getting 25psi and 55psi, why not provide the tools / parts and the steps required to determine the engine oil pressure, since other folks out here are trying to get the psi (?).
Old Jan 15, 2025 | 11:16 AM
W205C43PFL's Avatar
Beautiful glad you are enjoying the mod.
Old Jan 15, 2025 | 02:58 PM
andreigbs's Avatar
GLK 250
Does this "mod" result in any perpetual warning light(s) on the dash? Just curious, since I don't have a gasser.
Old Jan 15, 2025 | 04:00 PM
W205C43PFL's Avatar
nope only a soft code. CEL only on model year 2019 and + MBs as well as most S-Class vehicles.
Old Jan 16, 2025 | 05:30 PM
W205C43PFL's Avatar
OP, here is something else (yes, another mod) you could consider as well, I want to do it but my connector is weird, maybe yours is more normal and you can enjoy it instead: https://mbworld.org/forums/mercedes-...s-voltage.html
Old Jul 10, 2025 | 09:31 AM
gbm's Avatar
gbm
2013 C350 AMG Sport+, 2006 ML320
I have a C350 2013 (M276) with startup rattle as well, and my engine also falls under the "replace chain tensioner and install check valve" category.
Might try this mod, since it fixed the startup rattle for you.
You still haven't replaced chain tensioners and installed check valve, right?
Another suggestion I got from a retired Mercedes mechanic was to try thicker motor oil.
