How many of you M275s running on original coilpacks?
So coilpacks are considered a maintenance item on the M275s but how many of you are still running your original coilpacks?
What are you driving habits, oil change intervals, and anything else you can think of that contributes to the longevity of your coilpacks.
The SL65 engine compartment has much less room and requires removing the engine or dropping the subframe to get to the mounts.
One of the differences with the SL65 is that the engine is mounted further back.
In the S & CL, the engine mounts are just in front of the steering rack, but in the SL they're just behind.
Don't know if that makes much difference - its probably down to which type of mounts are fitted: up-facing or down-facing bolts.
Nick
MB Experts have repeatedly stated that in the R230 SL600/65 there is absolutely NO way to access and remove the top bolts on the Engine Mounts without making room.
The Turbos are blocking the access. There are apparently ONLY two ways to replace the engine mounts in the SL600/SL65.
1. Lift the engine up enough (8-10 inches) to have access to the bolts on the engine mounts. This requires removing and disconnecting virtually everything attached to the engine (electrical,cooling,vacuum etc) 12-15 hours for experienced MB techs with tools. Plus plan on breaking some of the dried out plastic fittings, hoses etc. that will need to be replaced.
2. Remove the the complete lower Sub-Frame while supporting the weight of the engine from above. Then remove the mounts from the bottom. They say this takes a little bit less time but because of the size and extreme weight of the Sub-Frame with suspension parts it is more difficult. Two people are required to support and lower/lift the parts.
If I have bad info and someone has figured out a better solution let me know??
The subframe is actually very light - lighter than a single front brake rotor.
Removing the subframe makes access very much better, but its still a difficult job. The upper forward motor mount arm bolts are difficult to access.
Nick
At 96K miles I lost cylinder #11 on the driver's coil pack. I replaced both individual coils on that cylinder, along with the plugs, then drove the car another 1,000 miles and lost ignition on all left bank cylinders. I then installed a brand new left side coil pack.
From what I can tell, I'm at 97K miles on the original right side coil pack. I've thought about changing it, but I might as well see how much longer it will hold together. Maybe the failure rate isn't actually 100%?
