---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old Jan 15, 2025 | 06:47 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by JettaRed
I was hoping that too, but there is a heat shield in the way as the turbo is close to the wheel well on the inside.
darn turbo....
There's a straight shot for non-turbo!
passenger wheel well access
passenger wheel well access to ALT rear end
Old Jan 15, 2025 | 07:16 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
I’m still unable to perform this mod due to the curious second wire on my alt plug! 2015 e63s sedan.
Old Jan 15, 2025 | 07:22 PM
W205C43PFL's Avatar
No. It's a different type of connector, a little bigger. But only a single wire.
Thank you, so does the plug just come off when you pull and no locking tab like the CPS?
Old Jan 15, 2025 | 07:24 PM
W205C43PFL's Avatar
I should. But it's kinda protected where it is, as you can see from my pristine engine bay! Seriously, I don't think it will get dirty, but if I knew that parts to get, I would cap them off. I don't think I can get in there with a heat gun or torch and some shrink tubing.
True true, might not be a problem just leaving it exposed but if you really want to, maybe electrical tape will be the alternative to shrink tubbing?
Old Jan 15, 2025 | 07:25 PM
W205C43PFL's Avatar
I was able to on the C350, just not the SL. I guess it really depends on how much room you have in the engine bay. The connector is toward the bottom of the alternator, but facing the wheel well, away from the engine. If you have room to reach, maybe you can get it from the top. I just don't know how much room the turbo takes up on that side. I could reach and feel it from the top; I just couldn't get a screwdriver down there to pop that little gray latching clip and my thumbnail wasn't strong enough.
Thanks for the pointers, yikes another of those locking pin plugs, this should be fun : )
Old Jan 15, 2025 | 07:29 PM
JettaRed's Avatar
Veteran: Army
Yes, there is a locking tab. That's what I meant.
Going at it from the bottom, I used a stubby flat tip screwdriver to pop the locking tab up. It still required some wriggling and pushing the connector (not the tab) in a little to pull it off. I think I just needed to break it loose a bit.
Old Jan 15, 2025 | 07:32 PM
  #32
JettaRed's Avatar
Veteran: Army
That is curious. I wonder if looking at a wiring diagram would help figure it out. PM me (or post here) your VIN and I will try to find it in the WIS.
Old Jan 15, 2025 | 07:34 PM
  #33
W205C43PFL's Avatar
darn turbo....
https://cimg5.ibsrv.net/gimg/www.mbw...06e5c80055.jpg
Wow that picture looks like a dream to me, I never hated the turbo as much in my life
Old Jan 15, 2025 | 07:36 PM
  #34
W205C43PFL's Avatar
nice
Old Jan 15, 2025 | 07:37 PM
  #35
W205C43PFL's Avatar
Thank you, I understand now.
Old Jan 15, 2025 | 07:59 PM
  #36
Manny_c450's Avatar
C450
OK, just got done unplugging the SL400 alternator (it got to a balmy 27°F today). I will be going out in a little while to see how she drives. I will report back.
Did you end up driving the SL400? How was the experience with it unplugged?
Old Jan 15, 2025 | 08:10 PM
  #37
JettaRed's Avatar
Veteran: Army
Yes, I did. Seemed pretty much normal, though shifting was a little smoother and it seemed a little more responsive in higher gears without downshifting. That's noticeable because I tried both Sport and Agility modes, and Agility (a.k.a., Sport+) usually downshifts if I even think about it. This was a couple of short drives, maybe 25 miles total. I will need to try in E mode and see if I notice a difference.
Old Jan 15, 2025 | 08:11 PM
  #38
workaround for TURBO FRIENDS
Lets see what's special abou his alternator schematic...
> THINKING CAP :
wait a minute... we always find plan B's for our friends...
Unplug BATT LIN sensor (aka. Hyundai Batt sensor) should disable Bosch ECU variable voltage feature.
It also will disables IC showing batt sensor... so you'll want to use a 12V plug-in phone charger that shows voltage or your OBD-II scanner to display SAM Voltage live data!
Old Jan 15, 2025 | 08:14 PM
  #39
Manny_c450's Avatar
C450
cool, I guess you will leave the ALT IN left unplugged on both cars and won't be reconnecting them ever..
Old Jan 15, 2025 | 08:15 PM
  #40
JettaRed's Avatar
Veteran: Army
@Jaybird123 here is the wiring diagram for an E63 (212.277). It shows a single wire going from the alternator to the ECU. With your specific car model, I could make sure I am looking at the correct diagram.
EDIT: Also note that the single LIN wire is BLUE (BU). The connector in @Jaybird123 photo shows an orange and white wires. Maybe that is a picture of the wrong connector. I can't find two wires like that in any of the schematics.
Old Jan 15, 2025 | 08:23 PM
  #41
INSTANT JOY... UP FOR TESTING
> THINKING CAP :
It also will disables IC showing batt sensor... so you'll want to use a phone charger that shows voltage or your OBSIO Scanner to display SAM Voltage live data!
this could be a quick PLAN-B to get stable voltage...
BATT Sensor unplugged
Somebody with ALT-LIN still plugged in can try and confirm 5mn quicky
ECU will still talk to ALT-LIN but should no longer play the [12.6V to 14.9V] chaos game.
The "drained by driving" below 12.0V bug may till be active because ECU can still mis-control ALT-LIN while it is plugged in.
I can not test this scenario with my ALT-LIN being disconnected...
Old Jan 15, 2025 | 08:28 PM
  #42
W205C43PFL's Avatar
> THINKING CAP :
this could be a ticket for stable voltage...
https://cimg1.ibsrv.net/gimg/www.mbw...6d6153a52e.jpg
ECU will still talk to ALT-LIN but should no longer play the 12.6V to 14.9V games.
The "drained by driving" below 12.0V bug may till be active because ECU can control ALT-LIN while plugged in.
Interesting, life will be way easier if that can achieve the same thing, as I remember forum members been unplugging that just to disable auto start/stop, no one reported how it changed the vehicle's drive though like transmission shift logic or acceleration. https://mbworld.org/forums/c-class-w...tart-stop.html
Old Jan 15, 2025 | 08:30 PM
  #43
W205C43PFL's Avatar
The main change they reported unplugging that is higher idle. So very interesting if this does the same thing as unplugging the LIN.
Old Jan 15, 2025 | 08:32 PM
  #44
CORD CUTTING...
Here is the way to cut wire inside ECU connector:
pin blu wire
Con-M Pin-45 blu wire: snap !
If you solder a toggle switch you can enable/disable ALT-LIN to remove related ECU Fault on demand.
Old Jan 15, 2025 | 08:45 PM
  #45
ALT-LIN vs. BATT-LIN
Call it ALT-LIN and BATT-LIN as they are both LIN Buses single wire.
Give it a shot you'll know quickly what voltage regulation is like with BATT-LIN out.
Try heavy electric loads combination (Rear Defrost + HL + Seat Heaters + wipers + AC Fan + ...)
I favor ALT-LIN to disable standard yoyo that lets engine/tranny adapt to stable timings.
The target is zero swing.
+++ Three Plan-B's:
-B1- Pull ALT-LIN...
-B2- Cut ALT-LIN...
-B3- Pull BATT-LIN...
​Where there's a will, there's a way!
Old Jan 15, 2025 | 09:06 PM
  #46
VOLTAGE MONITOR...
easy way to keep an eye on chassis 12V-DC
This does USB Charger plus monitor
Very useful to monitor voltage without BATT-LIN disconnected.
Voltages witnessed at different branches of prefuse box are slightly lower due to drop-voltage.
  #47
W205C43PFL's Avatar
I favor ALT-LIN to disable ECU standard yoyo.
I still think ALT-LIN is the better way to go....
Old Jan 15, 2025 | 09:10 PM
  #48
OPEN OPTIONS...
me too!
you can test one method then the other to accommodate your constraints.
Besides BATT-LIN will be a different fault in a different module: the Rear-SAM.
> Combination offer flexible options :
SMOG Test : ECU fault free while ALT-LIN plugged back and BATT-LIN pulled temporarily (once tested to be suitable).
Old Jan 15, 2025 | 09:25 PM
  #49
W205C43PFL's Avatar
me too!
you can test one method then the other to accommodate freezing weather constraints.
Options offer good flexibility....
SMOG Test : ECU fault free while ALT-LIN plugged back and BATT-LIN pulled temporarily.
True, good to have options. Sticking with ALT-LIN problem is my back will complain at me I will see what can I do or if I can figure out how to do it from the top ill post it and share but if not I will need to just go from the bottom.
Old Jan 15, 2025 | 09:26 PM
  #50
W205C43PFL's Avatar
me too!
Options offer open flexibility....
Thanks for bringing this mod to the attention of us forum members, these quality of life improvements are nice to have : )
