---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Of course, this doesn't mean you can redline in summer without getting high heat FAN:ON.
Yet it literally is amazing when you return home that the garage no longer gets steamy hot.
>> "Normal Heat" is the combined function of:
- effective piston heat removal at driving Rpm
- stable engine timings
- minimal hot blow-by gases
The first time I experienced "normal heat" level was with JCM recommendations of 5W-40 Motul. I was in disbelief!!! It lasted a while then heat resumed. I learned something essential then.
This is beyond the the IC-Display gauge registering any changes. Heat is not well tracked or captured because its transferred by the combustion blow-by gases - NO GAUGE ON THAT!! Only oil and water are somewhat measured.
When the whole aluminum engine block is streamed up, the fan gets turned on but hardly satisfies sensors.
This explains why big supersonic fan appears so ineffective even in winter... yes?
Once you understand FAN:ON hardly remove heat, you can go about finding solutions that effectively control heat.
That's where I'm at: driveability with normal heat.
+++ LOL ...
Realize the results of this highly sophisticated cooling system made ineffective by couple factors.
The clue is to CONTROL THE SOURCE.
"Normal Heat" is a function of:
- good engine timings reduced frictions
really hope to feel the diff in positive way from Motul Xcess 5w40 SN
You need to control that blow-by pressure of your. Master Suurya showed you the plastic check valves pipes in your TT PCV system.
That will get your ECU in the mood of much greater engine response. No need to push redline until your engine is normally balanced. You have a 25% penalty from lost compressions compensated by boost.
+++ LOL ...
tomorrow will see if my friend who will service the car have this vacuum tester to do the test suggested from MS also will clean my x2 MAPs too, i do think they might be not so clean as it should as im with non stock intake and when i oil filters it might produce some contaminations too isnt it
(also im sitting already on 132k km.. :/)will keep my feedback in the respective thread for each mod too
- the firewall stayed cool
- engine response stayed consistent
- tranny shifts stayed perfectly seemless
- front struts not bouncy
- HL LED did not cool after stopping
Gotta remove piston heat at normal driving Rpm... not simply above 2500R'
Temp measure are hardly significant because blow-by heat is hardly captured. The best way to control heat is as mentioned earlier.
When FAN stops it's evidence ECU is satisfied by sensor/map computation.
+++ Heat accumulated at driving speed is still there after stopping.
btw recently i heard my HL to run the fan never heard them before, it was raining i think but can't remember and i thought maybe that's why
My transmission temperature highest was 89 and usually stay at 82. Operating temperature is 50 and above I understand but it likes to get up to 82 and stay there, since I got the car so I think that is normal.
They don't actually measure the heat that cause FAN to run in winter.
That's why personally I do not trust numbers I believe are not linked to true engine heat.
The error margin is too wide.
+++ THE PARADOX:
Even though fan + winter driving certainly cool of the radiator it's still ineffective at cooling the engine.
So the fan stays ON ineffective even in winter.
Turn that problem around successfully:
No fan even in 100°F summer with better performance.
Throttle Lag and Heatsoaks damages are all one and the same topic.
Now we have options related to effective pistons spray cooling + sealing.
The one reason not to use 5W-50 is to redline unbalanced engines as-is. It should be safe around 4k.Rpm until rings cleans up.
If you do long trip 2-400km is this the same as to charge with CTEK for 1h AGM setting?
This should happen very easily with ALT-LIN after 15mn driving.
There are reasons this does not happen:
-- One is if the battery was discharged to begin with.
-- Two is if charge circuit is not in good shape.
-- Three a poor main GND strap!
So set your IC Display to show battery sensor info. Then you'll see exactly what is happening live.
There are reasons this does not happen.
So set the IC Display to show battery sensor info. Then you'll see exactly what is happening live.
