W221 ANDROID touchscreen...
Old Feb 15, 2023 | 02:39 AM
  #676
johnksss's Avatar
2011 S550 / 2001 S430 - RIP
Originally Posted by Basso1001
I am waiting what the vendor is gone do. Because there are no schematics there is little you can do with these things if they don't work. I also saw yesterday that it's disturbing the Can in the car. When i build it back to normal i had multiple Can problems and i had to disconnect the batterie for them to recover.
So i think there is something wrong in the harness they supplied.
Well that part is to be expected as you're trying to operate parts of the system that are not functioning thus giving errors. Usually using a code scanner to clear codes is better than disconnecting the battery. Preferably a dealer level scanner.
Old Feb 15, 2023 | 07:02 AM
  #677
Basso1001's Avatar
CL500 C216
I have Xentry and a dedicated scanner, but what i meant was that after taking out the new system and building back the original i could not get it online in the bus. It works again and the errors are gone now. Still nothing from the vendor so maybe i waisted 500 euro's there....
Old Feb 15, 2023 | 11:11 AM
  #678
johnksss's Avatar
Ah, got it. Now that is weird then.
Old Feb 19, 2023 | 02:19 PM
  #679
vervuurt's Avatar
CL550 AMG package
Hey GUYS I need help.
I'm installing the android radio.
But suspension controls are not functioning. Weird thing the radio came with 1 wire plug, that connect to the 3 wire plug of the car where normally suspension controls are. Also 1 cable does not go anywhere? Can you help me?
I have attached pictures via wetransfer link:
https://we.tl/t-jB2WIZl6Fv
Old Feb 19, 2023 | 03:43 PM
  #680
johnksss's Avatar
I already spoke on this a few post up....
https://mbworld.org/forums/s-class-w...ml#post8718930
Old Feb 19, 2023 | 03:51 PM
  #681
Basso1001's Avatar
CL500 C216
Thats the only thing that works at my system, it's a 3 wire plug called lin.
Old Feb 24, 2023 | 02:52 AM
  #682
Basso1001's Avatar
CL500 C216
Still busy with the vendor. I think at my system that the lvds box is not working. Problem is that there are no schematics for the android screen so you cannot do any measurements on the wiring. But it looks like the original plug which goes into the lvds box doesnt have any output and i think thaths the one who switches the new screen on in comand mode.
So now i am lokking to buy a new lvds box, but i cannot find them cheap anywhere....
Old Feb 24, 2023 | 03:54 AM
  #683
johnksss's Avatar
So now I am looking to buy a new lvds box, but i cannot find them cheap anywhere....
Now that does make sense..... Someone earlier in this thread had to fold the cable over to get it to work.
Old Feb 24, 2023 | 07:16 AM
  #684
vervuurt's Avatar
CL550 AMG package
I actually got it to work. It was indeed the LIN cable but this one only had 1 pink cable. Managed to get my suspension to work.
Old Feb 24, 2023 | 07:17 AM
  #685
vervuurt's Avatar
CL550 AMG package
Do you have a picture of your lvds box?
Old Feb 24, 2023 | 09:03 AM
  #686
Basso1001's Avatar
CL500 C216
Yes i have...
Old Feb 24, 2023 | 09:08 AM
  #687
vervuurt's Avatar
CL550 AMG package
Yes i have...
My LVDS was different indeed. It had the NTG 3.0 and NTG 3.5 option. Is your OEM unit 3.0 or 3.5?
Old Feb 24, 2023 | 09:14 AM
  #688
Basso1001's Avatar
CL500 C216
Yes mine is 3.0, i think this one is universal for 3.0 till 4.5. If you have the higher ntg you just remove the box and plug into the green plug.
Where did you buy your android radio? I have this one:
https://nl.aliexpress.com/item/10050...yAdapt=glo2nld
Old Mar 1, 2023 | 04:24 PM
  #689
CQHall's Avatar
W222 AMG S63
edit: I figured it out.
Old Mar 3, 2023 | 12:27 PM
  #690
Basso1001's Avatar
CL500 C216
i found something, in my car is a device from Caraudiosystems in Germany which is made for looking dvd or tv when you drive. This thing is connected in the Can Bus line of the car. When i install the new android system there is no connection to the car.
The android unit doesn't see when i power up the car. Today i had the same situation when i put the original system back after attempt 5 to put in the new unit. Turns out that the Caraudiosystems device had a loose wire.
Now i am thinking that i first have to remove the device from Caraudiosystems as it sits in the Can line an is the last unit which has an 120 ohm end resistor. That is probably why the new unit doesn't work in the Can line.
I will try it next week as the temperature is below zero and for me to cold to work outside...
Old Mar 4, 2023 | 08:58 AM
  #691
Basso1001's Avatar
CL500 C216
Finally i have a picture on the new system, but the next problem is here. The original system gives a picture and i can adjust the heating and everything only the original radio does not work and the cd player doesn't also. I can choose the cd player and it says disk loading but nothing happens.
I think its one of the parameters of the new system but i have to ask the vendor as there is no manual of them with the android.
Old Mar 8, 2023 | 06:37 PM
  #692
Rringer327's Avatar
2010 Mercedes S550
Esp buttons
Originally Posted by amgs63dxb
Hey guys, I am new to this.
I have this same exact screen, how do I get that little arrow to appear? On my bottom left there is no arrow at all
Old Mar 8, 2023 | 06:41 PM
  #693
vervuurt's Avatar
CL550 AMG package
Did you select the correct version? What do you have NTG 3.0 or 3.5?
Old Mar 8, 2023 | 07:33 PM
  #694
Rringer327's Avatar
2010 Mercedes S550
Esp buttons
It says protocol type 3.5. if that helps
Old Mar 8, 2023 | 07:39 PM
  #695
vervuurt's Avatar
CL550 AMG package
Which one does your car have?
Old Mar 8, 2023 | 08:56 PM
  #696
johnksss's Avatar
did you plug in the single lin wire?
Old Mar 10, 2023 | 12:42 AM
  #697
Rringer327's Avatar
2010 Mercedes S550
​​​​​​NTG 3.5. With the 4 pin. I used to have the arrow at the bottom of the screen there. To show the esp buttons, But now it's not there anymore
Old Mar 10, 2023 | 01:16 AM
  #698
johnksss's Avatar
nvm.... sorry.
Old Mar 10, 2023 | 01:18 AM
  #699
Rringer327's Avatar
2010 Mercedes S550
Ummm, no. the single lin wire that is for your controls to work.
Unlabeled (1 Pin) like in the picture. That has to be plugged into the factory 3 pin cable coming from the car.
If all that is plugged in correctly then it's something to do with the software settings.
Yes everything is hooked up. I just can't see that little arrow anymore
Old Mar 10, 2023 | 01:21 AM
  #700
johnksss's Avatar
Can you take a picture of your screen and post it right now?
And a picture of your default screen showing the original factory screen.
Thanks.
