SL/R230: BCM alternatives
BCM alternatives
As my BCM finally got toasted, I have been searching for replacements and see prices going north of $1000.! This not even warrant that the replacement will burn again...! So, I have been looking at BCM alternatives and know that some of the members of this forum have been in the same boat too.
After looking at equivalent year models such as the W220 or S class, these vehicles have as many accessories as the R230 and use only one battery, so I wonder why the R230 couldn't function with one battery with higher amp/hr rating. Looking at the electrical diagram, this could be accomplished by joining the 30 and 3a connection points..! Any thoughts on this? What would happen with the BCM other inputs???
Another option is maintaining the two batteries and use a VSR (Voltage sensing relay) which are used on many applications using two batteries? The same question about the BCM inputs appears with this option.!
please let me know your takeouts on this!
Making a system that will manage the two batteries is very easy.
However the BCM has advanced features, one of which is emergency backup for the consumer battery to enable the car to be safely driven or brought to a stop (keeps SBC powered)
However the biggest issue is the car will forever show multiple alarms and warnings with RED battery warning on all the time.
It is possible you may also be stuck with "consumers offline" message and no power to roof, radio AC etc.
At the moment the only practical solution is a used BCM.
marko69 (06-22-2024)
q0rsq,
I certainly agree with you....there must be inside that box connections for powering different systems, the task will be finding the locations of the connections to distribute the power where it is necessary....looks to me that I am doomed and need to shell $$$$$ for a used unit!
Gene, that was a lucky event.....mine was operating normal and just when I arrived home got the battery red light and started smelling something burning! At that time mine was toasted..!
q0rsq,
They will probably looking for messages like "battery voltage is good" before enabling them to work.
Might be worth contacting mercedes indicating that this safety critical part, with a known failure mode, should be made available again before someone gets seriously hurt.
I petitioned Mercedes UK already.
Probably won't achieve much, but is all we can do!
eLmacko,
On the contrary you can be just like me. My BCM has been dead for over 4 year now. I have no interest in checking the prefuses or K57(whatever it's called). All I do know is DAS does not communicate with the module. My front battery does not charge.
I drive a few times a month. That means I hook up my CTEK once a month to my front battery, let it charge up and not have a care in the world.
Das Geld, you have to do what you have to do before biting the bullet...!
This morning I connected what is left of the BCM, with the K75 in, K57 out. Tied the front battery connections together away from the BCM and took the car for a drive. The red battery light stays on, the check engine light too. Radio is off. Windows, AC, Ok. Car drives fine..! Left the BCM lid off to check is anything is heating up...none at the time of my return!
In the meantime I will get a smart DC-DC charger and connect it from the Auxiliary battery poles to the front battery pole, this will maintain the front battery charged at al time..! These chargers will monitor the starter battery charge and will cut it off or trickle charge when is full, giving a break to the alternator!
I will keep researching and doing test trials before I commit to spend $$$$ in a BCM replacement.!
I wonder what is the difference between the A230-540-1045 and the A230-540-0945..! Also, wonder if the R-230 is the only vehicle using these BCMs or a better two battery interface!
gOrsq, seems like the W221 had BCM issues since there were recalls on their system. I have been studying the W211 and W221 systems since both of these models has dual battery system. Probably exchanging some connections and their BCM could resolve the R230 issues....!
Yes, very interesting. If they use the same CANBUS communications, then would be easy to integrate into a working solution. It cant be used for a direct replacement, as not enough power to charge a starter battery, but it could probably be used to control an external charging system.
They are plentiful and very cheap (I can see one for £40 in the UK).
So the question is do they use the same CANBUS instructions as a 230 does? I cant see any reason they wouldn't, but may not implement all the instructions.
I may dig out some more information and see what similarities there are.
Edit.
The function of the W211 system is a little different. It shuts down consumers in two stages to protect the charge on the rear battery if it is low. This is just like the R230, but it doesn't bring in the front battery to help boost the rear.
However this is a minor issue, and could be resolved quite easily if required.
It only uses the front battery as a limp home battery or to power the SBC in case engine is not running and rear battery has failed . I think this is the same as the 230.
Charging is done via another module which connects the two batteries together for charging.
Edit.
gOrsq,
My friend, we may be up to something here...I got one of these W221 BCM from the junkyard out of an E450. If you can trace the circuits and see what could be connected to it would be awesome..!
BTW, I am trying to get good pictures or schematic of the R230 BCM, do you by chance have any? Or a BCM where you can take high resolution pictures? I will try to rebuild mine in the burnt zone if I could get enough info on it!
Looking forward to a solution,
El Macko!
El Macko!
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
This would be very interesting. Makes sense why they got rid of the dual system on the 09+ W221 S classes.
gOrsq, do you have available a "complete schematic like the one attached for the N82-1?
Also, found a board with very detailed connections schematic and wonder if anyone has a similar for the A-230-540-1045 board.
Will be helpful also to find a similar schematic for the W211 or W221..! Also attaching a great info on reading Benz schematics!
