SL/R230: Oil Change for 2004 SL500
I just purchased a 2004 SL500 and would like to do an oil change. Does someone have instructions on what to use to drain the oil and how to change the oil filter. This is my first Mercedes (B/4 I had Jaguars) and I would like to cahnge the oil my self. What is the recomended weight for the oil?
John
John
The process is essentially the same as with the SL55 except the SL500 uses "just" 7.9 quarts of oil. More info here: https://mbworld.org/forums/sl55-amg-...hange-diy.html
I just did the oil change on my '03, and it turned out to be easier and more pleasant than most cars. No need to go under the car or get messy. The oil is simply suctioned via the dipstick orifice, and there is no need to insert a tube into the dipstick -- only to make a good seal. I measured about 7 liters of used oil collected into my vacuum pump. The filter is a breeze to do as well. I used expensive oil, but then saw the same weight Mobil-1 at Wal-Mart much cheaper. You can get a nice pump at most Marine supply stores, like West Marine for instance, since boats are usually serviced the same way.
IS IT THIS ONE
04 SL55 AMG
Using a pump, how do you make sure you get all the oil out of both the front and rear portions of the oil pan (the front axle splits the oil pan into front and rear sections). To my knowledge, the only real way to make sure is to go underneath and drain each using both drain plugs.
I bought 1 for my BMW before and used it once then i threw it away.
I used it when the car wasn't too hot so the oil could move easier. In the end when there was no much oil, I could hear the pump started sucking air. It sounds just like when we finish zipping a glass of pepsi with a straw. If we have a hard time zipping every drop out of the glass, I think there is noway that thing could do a greater job than draining so i dumped it. It was a cool experience though.
John
John
Do you get slow (or even very slow) throttle response while cruising at 20-35 mph then brake a bit or just remove your foot from accelerator and then slightly accelerate and seem to seem damn this car is supposed to be a lot more powerful than it is then u feel power is back?#
Its like car loses ppower for half a second and then is fine (rpm goes up slowly from 1000 to 2000 then its fine after thaT..
I appreciate your feedback
04 SL55 AMG
I did a .pdf DIY write up at the following link for my SL55... should be similar, just less oil I think.
https://mbworld.org/forums/sl55-amg-...hange-how.html
04 SL55 AMG
tmerhebi, have you tried resetting your the car's adaptive accelerator response as per this thread:
https://mbworld.org/forums/sl55-amg-...ecu-reset.html
cleaned injectors and willl change fuel filter and spark plugs on monday.. will keep you posted but do u think it might be tranny TCU or valve body?
WTF?
No - this is at the back of the engine. Newer Mercedes SL do not have an engine oil dipstick - you use the command System to check oil.
I'd say photo was for the Transmission. Should be a red plug with a seal on it, so only a real Mercedes mechanic can check that transmission oil.
Putting 9 qts of engine oil in your transmission will be a VERY expensive mistake.
MBworld Guru
mistake.
mistake.
jdub907 (02-05-2019)
The above method also only apparently extracts 7 litres of oil, whereas using another tube pushed all the way down seems to enable 9 litres (about 8 quarts) to be extracted. All of which suggests the dipstick tube does not extend all the way to the bottom and so a separate tube should be inserted and pushed all the way down.
Or is there something I'm missing here?
I use a mighty vac 10qt version and insert the tube into the dipstick hole all the way until it stops and it sucks the oil out in about 5 mins, needs to be hot and you need to crack the oil filter open a few turns so it drains as well, and it shows on the side of the vac that virtually all of the oil is out. I change the filter while it’s draining. I have been using the vac method for years and it is definitely the way to go. I use Mobil 1 but I’m certain any synthetic will do. The key to high mileage cars without engine issues is the filters, some filter and some are just a giant oil plug, don’t go cheap on your filters. The MB OE filter is a nice filter. On my jeeps and range rovers that I’ve taken past 500K miles I use Bosch or K&N oil filters and change the oil once a year (averaging 40K miles, at least, per year). I was arguing with a Land Rover service manager where he implied that I was crazy to only change my oil once a year. I ended the argument by asking him to show me another Range Rover in his service bay or used lot that had 485K miles on it.
Leej (04-13-2020)
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
Is there not a lot of hassle using a suction pump?
I have always changed the oil on my cars with the engine up to operating temperature and i always use the drain plug so i am sure i get all the old oil out
I always change the oil filter when changing the oil
I also only use Mobile 1 oil. First because i know this is quality oil and the fact that i get a 45 percent discount on Mobil oils also helps
Leej (04-13-2020)
