SL/R231: PPI Report on 2014 shows issues
I'm looking at a 2014, Matte gray, white leather, 47k miles. Sport package, driver assist, B&O (rare I think). Asking $47k. There are some issues from the PPI. Here's the bigger issues:
Oil Leak at the Front Covers (valve covers) $1800
Cam Sensors leaking into the engine harness - $380
Cracked Wheel (how much is an OEM wheel?)
Air intake tubes cracking $195
And some of the usual maint - wipers, trans oil, engine air filters, brake fluid,
Impact blem, quarter sized on rear bumper - $1300
Only 1 key
Is this usual for that age car? Given the list, not sure it's worth $46k.
Thanks!
Only 1 key
Thanks!
That estimate is for cam sensor replacement only.
Sometimes the whole wiring harness may need replacement, especially if the oil made it down to the O2 sensors or even ECU!
Replacing wiring harness usually involves taking the engine out of car 😕
There is an “isolation” harness fix (for leaking magnets: see pic below too). It goes between your cam magnet and wiring harness. It’s a sort of sacrificial harness. So if the cam mhagnet leaks the oil is supposed to get trapped in that “jumper” harness.
it’s a well documented issue do a search for: oil harness cam sensor, and you can read all the horror stories. This is just one:
https://mbworld.org/forums/e-class-w...r-leaking.html
I recommend everyone I know with that style cam sensors to install the sacrificial harness kit. (To clarify: this kit is only for magnets you’ll need to replace cam sensors but they are easy to access )
https://www.fcpeuro.com/products/mer...des-2711500156
Be very careful,
IMHO that car is too expensive with those issues.
Was it ID'd and fixed after a R231 MY or is it likely to affect all R231s 2013 through 2020?
Is the fcpeuro.com/products/mer...des-2711500156 a preemptive fix or a fix after the failure found?
https://mbworld.org/forums/w212-amg/...rness-ecu.html
https://mbworld.org/forums/gl-class-...ion-wires.html
There’s no real correlation and appears random. It’s unclear if the design has been changed, but usually when they are replaced they won’t leak again. Now in 5-7 years or so, I guess we’ll know for sure…
BTW that is a Mercedes’ factory “fix” with an MBZ part number, not an FCP part. So they, Mercedes, obviously knows the issue exists. 🤨
I have them on my car too, just in case, but I still check the connectors every oil change
I would still keep an eye on any car before late 2016 to 2017 when it appears they moved to the latest revised part number.
It can affect ANY engine that uses that cam sensor. M278 is well documented, but there are others, M276 etc… If you search, you’ll find plenty of horror stories.
It is mostly preemptive. but can be used to save a harness if the oil can be cleaned out and hasn’t gotten too far. You still need to replace leaking cam sensors.
Unfortunately any engine that uses that cam sensor design including, M157, M276, M278 can all suffer the same fate.
I would keep an eye on it, especially on a car with over 30k miles. The the sacrificial harness kit is cheap insurance.
Will do, thanks. I have my last service before my CPO extension expires in June so I'll have my dealer look over the car carefully. I should mention cam sensor oil leak as the issue?
Access to the harness isn’t bad once you have top covers off.
see locations in pic
How can those with facelift (2017 and newer) tell if we have the newly designed cam sensors?
Is there a PN to reference or something on the build sheet that I/we can have our MB tech check?
pls advise.
TX !
To do the repair properly you need : (4 qty ) 2769051000 (Sensors) and (4 qty) 2761560790 (Magnets)
The magnets on your car should have markings. If they are the newer part numbers chances are the sensors are newest version too.
Here’s a car I recently did with leaking cam sensors. 2013 sl550 in the 45,000 miles range. (bottom 4 pictures)
The connectors at the bottom cam sensors were soaked with oil on both sides 😟
The cam sensors & magnets are the older style.
The sensors are out and you can see the placement (circled in red) It should be similar on m276
There are camshaft control valve magnetic solenoids and camshaft position sensors. The camshaft sensors are more prone to leaking. Especially the bottom ones.
Access isn’t bad once you remove air ducts and covers (M278 pictured)
