SL55/63/65/R230 AMG: The Johnson Pump
Old Nov 5, 2012 | 01:06 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
The Johnson Pump
Well guys this is it. Since I fitted this to the 600, not only is the car faster,
everything, kickdown , smoothness and more have all got better, worth every penny even if your not re mapping.
Old Nov 6, 2012 | 05:07 PM
Welwynnick's Avatar
2006 S600
Ever since you said you replaced your SL63 with the SL65, I think its been written in the stars that you'd get a CM30 for that as well.
This reminds me of a question I was going to ask before though:
Which is faster - your tuned S600 or stock SL65?
Cheers, Nick
Old Nov 10, 2012 | 11:40 AM
jobe's Avatar
sl500
can you describe the actual phisical benefits with this pump installed?
this is a water pump, right?
Old Nov 20, 2012 | 03:17 PM
sound 8's Avatar
I can only tell you the difference fitting the CM30 after a re map, and that's
stronger acceleration, doesn't get weaker the harder you drive it, better kick down. At the moment the 600 is marginally quicker particulalrly from the lights
more nimble, the 65 has more grunt further up, bigger turbos perhaps.
Old Nov 21, 2012 | 02:34 AM
crazyfox's Avatar
Which move point A to point B.
what about the bosch 010?
Old Nov 21, 2012 | 07:37 AM
sound 8's Avatar
Is the bosch the standard pump, I have heard they are really improved, but
as far as I am concerned it's Johnson for me.
Old Nov 23, 2012 | 02:08 AM
crazyfox's Avatar
thanks bro. one more question tho. shall i go the complete set with evosport or buy a johnson and EX from EC? pls educated me .
Ben
Old Nov 23, 2012 | 02:37 AM
overZealous1's Avatar
sl55 amg
here is the one i found. basically the same thing everyone else is selling, just not rebranded. http://www.ebay.com/itm/ALUMINUM-BAR...f06671&vxp=mtr
do a search for the pump too. could wrap up both pieces for under $250.
Old Nov 23, 2012 | 04:36 AM
crazyfox's Avatar
thanks again!
Old Nov 30, 2012 | 09:30 AM
sound 8's Avatar
The Johnson is a straight swap with the standard unit, labour would be about
1 hour, it still surprises me when I boot it It might be worth having your oils changed at the same time. My SL65 is going in Monday for Johnson
pump to be fitted plus back axle, gearbox and engine oil and filter change.
If your plugs are old it might be worth changing them as well.
And then the re map......
