Kleemann vs AMS headers
Old Mar 1, 2012 | 10:49 AM
  #51
armaniE55's Avatar
2012 CLS63 AMG
Originally Posted by Schweinhund
The car I really go with is Abalone's E55. Before he supercharged it he only had Kleeman headers, exhaust and an ECU tune. I think he made over 400HP.
That sounds about right... Where is Abalone these days
Old Mar 1, 2012 | 12:04 PM
  #52
Fabio D's Avatar
210 55
Originally Posted by armaniE55
Fabio I told you come to the states and we can race for it
Hahahahahahahaha you are the man! i love the look of your engine bay with this box bro, we can make a deal, you send me your renntech airbox and i send to you a new radiator hose hanger (YOU NEED ONE FOR SURE & I NEED CARBON AND +HP) jajajajajajjaaja
Yeah! what about abalon's car? he have some problems with trans slippage long time ago
Fabio Daniel
Old Mar 1, 2012 | 01:48 PM
  #53
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
His set up is more than 400hp...... i would say at least 500hp. I saw his car in youtube, damn its fast and some fire came out from the exhaust !
Old Mar 1, 2012 | 01:49 PM
  #54
CharlyE500's Avatar
Originally Posted by 503C43 ////AMG
A stock W210 E55 weighs about 3700 lbs. and will run a 13.3 second 1/4 mile. To run a 12 second 1/4 mile you would need to shave 1.3 seconds off of your time, 50 HP will not shave 1.3 seconds off of your time
The first Audi R8 (4.2L V8) was 424 HP, 3600 lbs, and ran a 1/4 mile in 12.5 seconds. Its about 200 lbs heavier but with 24 more horse power and is no where near 11 seconds.
The C63 AMG is 480 HP, 3900 lbs, and runs a 12.4 second 1/4 mile
Check out this link:
http://robrobinette.com/et.htm
The calculator is accurate within a couple tenths, using the calculator and the 3700 lbs + 400 HP you get about a 12.9 second 1/4 mile which sounds pretty accurate.
Like I stated before you would need to be @ 500 HP+ or lose about 700-1000 lbs to get into the 11's.
If thats the case, there are 2 or 3 Stock W211 run 11.8 and it weight 4100Lbs approx. Maybe the extra torque help a lot......
Old Mar 1, 2012 | 02:47 PM
  #55
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Kleemann Supercharger
Check this thing out guys...someone is selling a Kleemann supercharger on the classified....
Old Mar 1, 2012 | 03:02 PM
  #56
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Ridic! with the flames the question was he was running in the 400hp before the SC.
Old Mar 1, 2012 | 03:39 PM
  #57
Schweinhund's Avatar
W210 E55
Now that's a mod.
Old Mar 1, 2012 | 04:05 PM
  #58
JamE55's Avatar
Out Of Control!
This looks like a roots type instead of the original twin screw.
Old Mar 1, 2012 | 06:26 PM
  #59
snooozie's Avatar
the front looking with the pulley...that Kleemann SC...this with the Kleeman headers....woooowwww
Old Mar 3, 2012 | 08:37 PM
  #60
snooozie's Avatar
Loctite 272
Allow me to chime in. Having the AMS pulley myself. Don't be scared the only issue the user will have is what I like to call user error. The andy shop has installed them incorrectly in addition they probably didn't use lock tight and torqued to spec (this is on the install sheet that is provided with the pulley) nor did they probably have it re-torqued after a few thousand miles. We drive these cars hard. I have mine looked at whenever I'm in the Andy shop just for safety check. Just with any mod you will have to keep an eye on it.
You can definitely feel the difference down low and up top. with the headers and the pulley on a NA along with res delete/ high flows /x-pipe you are squeezing whatever HP/TQ AMG left behind. Which is not much... For the money it's not a bad investment as the headers are now $650
I'm pulling the trigger today for the AMS headers then Tune then next project
Armani
I check on the loctite and read up on the numbers....the one to get is loctite 272 the red bottle....
Torque (Break): 200 in lb
Torque (Prevail): 220 in lb
Temp. Range: -65.0 F [Min], 450.0 F [Max]
Fix Cure Time @ Temp.: 30 min @ 77 F
Full Cure Time @ Temp.: 24 h @ 77 F
Chemical Compound: Acrylic
Applications: Thread
Applicable Materials: Most Metals
Curing Method: Anaerobic
Resistance: Air Reference
This stuff is serious. If I apply the 272 and torque the pulley to 180lb (recomended OEM is 150lb) that should hold up as the loctite's breaking point is 200lb.
Old Mar 13, 2012 | 10:53 PM
  #61
dre5373's Avatar
2006 C55, 1995 C36
You will need either 500+ HP OR drop about 1000 lbs to run in the 11's
400 HP @ 3550 lbs = high 12's low 13's
I think well into the 12's are achievable...with Kleemann headers, K&Ns, no cats, dual exhaust and a Eurocharged custom tune I got a 12.79 on worn out street tires. The track prep was pretty decent, but I still couldn't launch at a good RPM without wheelspin through 1st and 2nd. The C55 N/A record is at 12.21 @113 but he went a bit further with removing weight and had drag radials as well. Not a whole lot of difference in weight between the C55 and a W210 55...
Old Mar 13, 2012 | 11:35 PM
  #62
seattlekleeman's Avatar
Birel Shifter,2003 Ferrari ,1992 Mercedes 500E,Superformance Cobra,2005 SL55, 2004 996tt X50 PCCB
Cory Rocks!
++++++++1 for Kleemann, customer service is the bottom line.
Old Mar 14, 2012 | 12:48 AM
  #63
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I agree, 12's are doable but 11's, no way. Not @ 400 hp and 3600+ lbs. Just like you posted, the C55 record is 12.21 WITH weight reduction, the W203 C55 is lighter than the W210 E55 to begin with
W203 C55 = 3550 lbs
W210 E55 = 3700 lbs
Old Apr 28, 2012 | 10:39 PM
  #64
snooozie's Avatar
Guys,
I finally got a chance to install the AMS headers and they came out awesome!! I took some pictures of the finish product as I was not there when my mechanic put them in. The sound at first is the same as when I took it in to the shop but after a few days of driving, the exhaust really sound good. I think, like the x-pipe/delete resonator, over time, the exhaust sound louder. It might take a few weeks to have the ecu adapt to the new headers. I can already feel the grawl of the engine at higher revs...
Attached Thumbnails Kleemann vs AMS headers-ams-pic01.jpg   Kleemann vs AMS headers-ams-pic02.jpg   Kleemann vs AMS headers-ams-pic03.jpg   Kleemann vs AMS headers-ams-pic04.jpg
Old Apr 29, 2012 | 01:16 AM
  #65
W210 E55
Those look great. Should go with a little nitrous to take advantage of their flow capability
Old Apr 29, 2012 | 08:03 AM
  #66
snooozie's Avatar
Thanks! I tried to take the pictures on the headers as best I can. Due to all the other stuff like the hoses and wires kind of makes it difficult to get a nice pic especially the drivers side. I think, as far as I know, these are the only pics showing the installed AMS headers on this forum. I personally have never seen any finish product pictures on the headers. I am very satisfied with the installation and product so far. My next major mod will be replacing the 2nd cats with straight pipes, which will give the "Grawl" of the V8 even louder
Old Apr 30, 2012 | 05:14 PM
  #67
CharlyE500's Avatar
Nice Job ! have you dyno your car yet ?
Old Apr 30, 2012 | 11:03 PM
  #68
snooozie's Avatar
I was thinking about it. http://jannettyracing.com/dragday.shtml here in Waterbury, where I got the headers sand down, can do dyno. I have to get some new plug wires first before doing that. I am ordering some 2.5" stainless pipes to replace the second cats. I just want to enjoy my new mod for now....got to enjoy one mod at a time
Old May 15, 2012 | 02:24 PM
  #69
snooozie's Avatar
I notice in one of the pictures in the W211 forum regarding the OEM exhaust manifold in the 55K engine is the same exact manifold as the NA 55. Just curious, can someone confirm to me that both the manifolds are the same?? For those of you who have both the kompressor and the NA engine, could you check if the manifolds (headers) are the same?
I would imagine its the same headers as the engine is the same M113 right?
Old May 15, 2012 | 02:54 PM
  #70
CharlyE500's Avatar
I think they are the same. I have not check my W210 but from few pix i see in forum, looks the same as my W211. I still have my W211 header in my garage....
Old May 15, 2012 | 07:31 PM
  #71
Fabio D's Avatar
210 55
Nope. not the same.. i have both and is not the same
Fabio Daniel
Old May 15, 2012 | 08:14 PM
  #72
CharlyE500's Avatar
Fabio Daniel
oups..... my bad....
Old May 15, 2012 | 08:55 PM
  #73
snooozie's Avatar
CharlyE500 can you take a picture of you manifolds when you have a chance. I have never really seen one up close of the 55k. You can post it here. I thought they look the same. What is the difference....is it bigger or shape different. I know mine is kind of hollow between the aluminium wrap to the pipe. Just curious.
I can never understand why they took the trouble to wrap the manifold.....maybe to numb out the sound....
Old May 16, 2012 | 01:25 PM
  #74
CharlyE500's Avatar
Let me take a pix later tonight post up tomorrow.
Old May 16, 2012 | 08:33 PM
  #75
W210 E55
Here is something:
https://mbworld.org/forums/w211-amg/...ders-must.html
Telling you, if we can drum up 500 orders, MAC Exhaust in California will make us long tubes for between $400-$700 with good quality materials (not stainless).
