Weistec supercharger in a 99 e55 amg
Old Dec 23, 2015 | 03:24 PM
1999w210e55amg's Avatar
W210 e55 amg
Okay so I got a weistec supercharger and I'm putting it on my 99 e55 I just wanna know do I have too sleeve the motor or can o just put forged rods and pistons and I'm good to go
Old Dec 23, 2015 | 07:09 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
i would sleeve. If you don't, the ONLY pistons I would use are Kolbenschmidt or Mahle. Both will be super expensive. It's very hard to find someone who knows how to rehone/bore an alusil engine. Sleeving takes all the guess work out of the equation. Not to mention, it will be very durable and probably cheaper in the end.
Old Dec 23, 2015 | 11:07 PM
W210 e55 amg
Yeah but these guys at power house are charging me 6800 to sleeve the motor
Old Dec 24, 2015 | 09:22 AM
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
From my research, and BlownV8 is correct, that's not out of the ballpark of what you should expect to pay to sleeve, and you'd probably STILL come out cheaper than replacing with quality pistons.
Old Jan 3, 2016 | 05:25 PM
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
Wow congrats did you buy a new SC from them!?!!
Old Jan 3, 2016 | 07:15 PM
W210 e55 amg
Yeah I just got it a couple of weeks ago I'm going to make a new post and put up pictures and everything when I'm done with the car right now I'm just waiting for more parts
Old Jan 26, 2016 | 12:58 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
Cool. What are you doing for tuning? Are they going to tune your stock ecu?
Old Jan 27, 2016 | 12:59 PM
W210 e55 amg
That was the plan at first but I'm going to buy a ecu from a 03+ e55 and get it tune that way it's easier and less headaches
Old Jan 27, 2016 | 02:10 PM
cm60k's Avatar
Unfortunate; can't get ECU alone, have to get all Key/EZS/EIS system, for fire-up Authorization via DAS..!
ZAYED,,
Old Jan 27, 2016 | 02:21 PM
W210 e55 amg
ZAYED,,
Yeah I know still less of a headache
Old Jan 27, 2016 | 02:43 PM
cm60k's Avatar
Agreeeeeeeed..
ZAYED,,
Old Jan 27, 2016 | 04:11 PM
Not that simple either. The CAN bus has a different id setup for things like transmission. Shifter, etc. You might be able to use the tcu from the e55 and the shifter. I am not sure if the traction data is the same. Cluster wont work etc. etc. Some ecus can be set for either id structure but I do not know about the 55k.
Old Jan 30, 2016 | 03:13 PM
M3RC3D3SE55AMG's Avatar
Mercedes-Benz E55 AMG (W210)
When I enquired with Weistec (approx 12 months ago) about one of their superchargers for my '00 E55, they told me they didn't have a unit "compatible" with the N/A M113. Obviously that's not the case?
Old Jan 30, 2016 | 03:16 PM
ZAYED,,
Wouldn't he need to change the entire loom of the car for his method to work? Even then it's a big risk?
Old Jan 30, 2016 | 05:27 PM
W210 e55 amg
The N/A 55 engine has to be sleeved and needs forged rods Pistons so it could work so I got the 55k motor think I still don't need to do that I still sleeved the 55k motor got forged rods and Pistons polished the crankshaft got a transmission from a 06 sl65 beefed up the tranny rear end was kept the same just got a quaife lsd got H&R sway bars back and rear kW coilovers an for exhaust system I might take it to a local exhaust shop and get a custom exhaust system so it can look nice with the body kit I got it I want to go dual exhaust just sent it out to get put together pictures coming really soon and hopefully I hit mid 9s that's what I'm aiming for
Old Jan 31, 2016 | 03:05 AM
Your modification list is similar to mine actually. I fitted a Kleemann kit to my car over Weistec however - after being made to feel quite disrespected by Weistec when trying to get any kind of customer service from them, I took my money elsewhere.
The Kleemann supercharger setup I have runs boost levels which are safe enough for the stock N/A block/cylinders/pistons to handle, which I thought made things much simpler. My ECU remap was written by Kleemann too, but rather than sending them the whole unit I found someone local who could load the modified map and tables Kleemann created based on my stock file.
I have discussed the areas of sleeving, piston upgrades, and torque converter/gearbox upgrades with forum member Zayed [Cm60k] in depth too. All of which are on my to-do-list, so I'll be following your work for input, that's for certain.
Just to be clear, you now have an M113K engined W210, and are bolting the Weistec to the M113K block? You're not running an N/A M113?
Old Jan 31, 2016 | 08:26 AM
W210 e55 amg
Yeah I ended up buying a m113k motor to do the weistec set up it was just lest headaches doing the m113k set up
Old Jan 31, 2016 | 09:11 AM
I see! The engine swap was a smart move, you're absolutely right that it saves a lot of work, since the 113K comes with the forged bits etc as standard. I spoke to forum member Zayed (Cm60K) about an engine and transmission swap for my car too - but for now, my N/A M113 with the Kleemann S/C fitted is solid - so I'll continue as is and look at a swap if the requirement ever arises. Zayed did inform me that the transmission and torque converter upgrade would be necessary sooner than an engine swap, simply because with the level of modifications my car runs pushes the stock converter and transmission to its limit.
Old Jan 31, 2016 | 09:22 AM
W210 e55 amg
Yeah that is important to change the torque converter the shifter I didn't get nothing for that what should I get for the shifter
Old Jan 31, 2016 | 09:27 AM
When you say shifter, are you referring to the possibility of paddle shift etc?
Old Jan 31, 2016 | 09:30 AM
W210 e55 amg
Well what were you indicating when u said shifter
Old Jan 31, 2016 | 09:33 AM
W210 e55 amg
And I have a 99 e55 so I don't have Tip Tronic I have the shifter with the 4321 on it and I wanted to upgrade the shifter to the tip tronic one and could I simply change shifter or there's a lot more to it then that
Old Jan 31, 2016 | 10:00 AM
Now I understand.
If you have done the engine and transmission swap, I'm sure that the ECU/TCU and loom modifications required to get everything working would allow you to add the Tiptronic system to you car I assume. You could even look at fitting the steering wheel paddle shift from the W211, but that would be considerably more work, especially ECU/TCU wise. In reference to your current pre-facelift gear-shifter housing (interior), how does it compare size and styling wise to the facelift version, would that be an easy fitment? By this I mean the wood finishing etc around the gear stick itself.
Old Jan 31, 2016 | 10:03 AM
W210 e55 amg
ZAYED,,
Zayed sorry for bothering you but I heard you know a lot about Mercedes so I just got the apr head studs no do I have to remove the cylinder head or can I keep it on and change the head studs
Old Jan 31, 2016 | 10:09 AM
W210 e55 amg
Now I understand.
Yeah if I can put the paddle shifters the tip Tronic shifter I'm going to do it
