My car feels unstable on the highway..
Old Jul 14, 2007 | 09:58 AM
AMG Rider's Avatar
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
it has been bothering me for about a month...
it feels like wheels are playing separately and i could definately
feel the vibration..i was racing my friend's M6 and my friend who was watching us behind (RS4) even told me my car was shaking pretty bad and got worse when i hit my brakes...
I asked my friends when we got off the exit and they told to get an alignment and balance...should it fix my problem? if you guys have any other thoughts, it would be great~
btw, im running with 19' HREs and my car is dropped with Renntech module..
Thanks...i hope its not something major~~
Old Jul 14, 2007 | 10:48 AM
OzE55's Avatar
2003 E55
how wide are the rear tyres? Are they rubbing? Get a balance and alignment, soon.
Old Jul 14, 2007 | 11:05 AM
WayneE's Avatar
'72 Suburban
Checked tire pressure?
Changing ride height affects alignment/handling. Changing wheel/tire height/width will affect handling/stability/tendancy to follow ruts in road.
- verify proper tire pressures
- verify alignment specs (toe specifically will affect stability)
- verify all lugs are torqued properly (to address vibe)
- verify balance on wheels (to address vibe)
Shouldn't be too difficult to track down the problem.
Old Jul 14, 2007 | 12:03 PM
AMG Rider's Avatar
Thanks..i would definately check those...
Old Jul 14, 2007 | 12:08 PM
SleeperX's Avatar
E55
Hey bro,
Definitely get that checked out and DO NOT RACE OR GO AT HIGH SPEEDS.
It could be you lug nuts. Make sure they are tight and all of them are there. Get your tires balance and aligned.. Do you hear any signs that the wheels could be rubbing when you are driving.
Old Jul 14, 2007 | 12:40 PM
MiamiAMG's Avatar
C63
Originally Posted by SleeperX
Hey bro,
Old Jul 14, 2007 | 03:32 PM
AMG Rider's Avatar
Hey bro,
it only rubs when i go over bumps..But, i just raised my car up lil bit this morning, so it shouldnt rub at all...after what happened on the way to Captree meet, i've been checking my lug nuts everyday..lol
i also made an appointment next week to get my tires balanced and aligned...
thanks for helping me out~
Old Jul 14, 2007 | 03:34 PM
AMG Rider's Avatar
Hey bro,
also, the guy who messed up my rim got me new lug nuts...what are the right size lug nuts for our cars?
thanks~
Old Jul 14, 2007 | 09:22 PM
OzE55's Avatar
2003 E55
Go and jack up one wheel now and check its loose. I assume if the lug bolts are too long they wont hold the wheel tight against the hub. Take one out and see if its the same length as the old ones. Then get professional help.
This could be dangerous, no matter what speed you're doing, if a wheel is loose.
Old Jul 14, 2007 | 09:54 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Are all tires the same all around? If you use different tires front and back, it could be it....
I replaced the rear tires (rear Dunlop Direzza & front Potenza S03) before I sold my W210. The way the car behaved at 80+mph was scary.... It felt the tires were about to come loose...
Old Jul 14, 2007 | 09:55 PM
ROCKETW19's Avatar
06 EuroElites E55
i had the same issue. take your car to the dealer and have them align it your toe is outta wack. make sure you set the renn lowering mod to the height you are gonna keep it at first. the dealer is around $300-$350 but they have the best 4 wheel machine around.
Old Jul 16, 2007 | 06:20 AM
AMG Rider's Avatar
Ill go look into those~but, there is very little chance that the guy gave me the wrong lug nuts~Thanx~
Old Jul 16, 2007 | 06:23 AM
F_Porsche's Avatar
i like to ride my bike
the bearing
my dad had a similar problem on his E. On the autobahn it would get
really noisy at higher speeds. As soon as he moved the steering wheel
it was gone. The problem was the bearing, the mechanic said a really
rare problem!! But he had it twice up front.
Check your lug nuts, get the up and see if you can easily shake the
wheel. My dad said, in the air it be like falling off by itself.
AMG Rider's Avatar
I was goin to take it to RPM racing, but i guess not...also, i didnt know that the 4 wheel alignment is $300-350...little expensive, but if it will fix my car, i wont regret it for sure since my car scares the **** out of me these days~ Thank you~
Old Jul 16, 2007 | 07:51 AM
OzE55's Avatar
2003 E55
Another thought. Check, carefully, that all the tyres are mounted in the correct direction. Many tyres are directional and if the wheels are swapped (from side to side) accidentally or the tyres mounted on the wrong side it might vibrate as the car goes faster. The tyres should have directional arrows on the sidewalls.
Old Jul 16, 2007 | 11:10 AM
AMG Rider's Avatar
just dropped my car off at the dealer..should hear from them soon..for now, i told them to align and balance my car...but, the guy told he would look into steering rack~i hope its steering rack, so i could get 06+ steering rack for free...and alignment at the same time...lol
Old Jul 16, 2007 | 11:41 AM
MiamiAMG's Avatar
C63
Cool. Keep us updated on what they find!
Old Jul 16, 2007 | 11:43 AM
BenzoManNY's Avatar
E63, SL 550 Sport,C63 Coupe On the Way!!
My e63 was delivered this way and is going in WED. I just took a weekend trip 500 miles and it was vibrating and drifting 3 hours both directions i hated it. I have stock wheels and tires. Car drifts all over the road and pulls to the right on certain roads. I am requesting 4 new tires, possibly wheels may be bent but it was delivered this way.
I could not enjoy my drive one bit above 50MPH because of this.
Old Jul 16, 2007 | 11:56 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Your car is SLAMMED on big wheels. My first guess would be either a bad tie rod, bad alignment, or bad wheel bearing. One of those is the culprit.
Old Aug 13, 2024 | 05:01 PM
E55amg01's Avatar
E55AMG
hello i have a problem with my stability
my car goes like a boat on high speed on full throtle it goes like a suv left right its very unstable especialy on smooth bumps on the highway
but only on full throtle when i go smooth on gas no issue
please help
i cheked the alingaments and everything its allright
even when i dont turn off the esp the esp keps pulsing from 100-170kmh
what is wrong maybe the airmatic?
i have to say that this problem came when i fully rebuilded my engine the front car bridge was down with the engine and transsmision
Old Aug 16, 2024 | 03:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
freeplay control list
My first guess would be either a bad...:
  • loose tie rods (inner/outer)
  • (bad wheel alignment)
  • loose wheel bearing
To that list we can add a few more cheap parts:
  • control arms
  • STRUT BEARINGS!
  • stabilizer links (front + back)
  • ball joints *.*
It's pretty simple... everything must go!
Once you replace one part, the freeplay moves over to next. German rubber formulation goes softbat 10Yr mark.
> TRIVIA...
What is the rubber bushing that NEVER EVER gets a rest ??
The strut mount!
They hold the 100% of chassis weight divided between front/rear wheels 24x7.
Old Aug 17, 2024 | 11:08 AM
E55amg01's Avatar
E55AMG
  • control arms
  • STRUT BEARINGS!
  • ball joints *.*
> TRIVIA...
The strut mount!
Bro belive me that everything you are saying here its cheked from firs to last im doubting on the struts i need to get those cheked but i dont know the car feels very solid on low speed the problem its only when im on full throtle wavy road and hard braking…and in all this situations the car pulls me left to right…so for example when i want to overpass a car on hard acceleration or a wavy road i turn the steering left and the moment i want to go right the steering goes right but the car feels like its going left again and makes mee to move the foot from gas and the esp keeps blinking to 180kmh on full throtle for no reaso cuz i have tried before on rain and the esp blinked only on 130kmh and this is on rain now its 39 celsius degre outside
Old Aug 17, 2024 | 04:11 PM
When you add more stress factors such as full throttle on a 4-Matic : then every suspension rubber has to be perfectly tight to keep straight.
The list I wrote above is for the front axle, repeat for rear axle with a "control arm kit" to begin with.
Don't sweat it... here is where you can use parts canon until 100% complete.
​​​​​​If the ride height was altered the position of the steering rack is no longer neutral. This makes toe unstable.
