Transmission solinoids solved all my problems!
Old Aug 5, 2009 | 10:13 PM
  #76
jturkel's Avatar
02 C32 AMG
Originally Posted by dyno
Mercedes parts cat said that transmissions with number above 04 247135 have Blu Tops as stock
and how do we determine our transmission numbers?
Old Aug 6, 2009 | 04:31 AM
  #77
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
you can ask your MBservice the datasheet of your car VIN
if you don't have access to their part catalogue EPC
.. and you don't want to have a journey under your car
Old Aug 6, 2009 | 05:07 AM
  #78
jturkel's Avatar
02 C32 AMG
not sure if im reading or understanding what you wrote correctly.
you are saying i can ask the MB service people for a datasheet of my car supplying them with my VIN? is there a way i can just type my VIN online somewhere and find out which trans id number i have?
Old Aug 6, 2009 | 07:23 AM
  #79
dyno's Avatar
yes, the printout is one page of ID data concerning your car, including the Trans ID.
Old Aug 6, 2009 | 09:35 AM
  #80
superstar's Avatar
03 R230 SL55 / 94 W124 E500
Ok here is my data card below, now do I have the blue top?
By the way, if anyone wants their data card just type your VIN number and I will be more than happy to post your data in here!
Old Aug 6, 2009 | 11:32 AM
  #81
dyno's Avatar
the deadline number that was given
was for trans 722.643.
now, you are talking about a C55 with trans 722.636 and further ID 06 192403
So, they are different things !
to see if there is a different deadline is necessary to make the same research for your C55 trans on EPC and see what it says about those valves ...
Old Sep 18, 2009 | 01:28 PM
  #82
mikekuriger's Avatar
2010 C63
this is an interesting thread.
I'm thinking of replacing these as well in my C55. I can sometimes feel a tranny delay or slip from 1st to 2nd under full throttle.
I had some problems with the apply lever and 1-2 band in my srt-10 truck after installing my NOS. I would suggest that anyone with trans issues have the bands and possibly apply lever replaced when doing the valves since the valve change is probably just a bandaid fix for the underlying worn bands. I had to replace the valves in my srt-10 also a couple of times when it had a "hunting" problem trying to shift from 1st to 2nd at low speeds
Old Sep 28, 2009 | 05:03 PM
  #83
///AMG4EVER's Avatar
CLS55 Designo 030
Thread resurrection.
I have a pair of blue top solenoid valves if someone is interested. Tried them in my C32 but unfortunately, the valves didn't work. $250 shipped.
Old Oct 13, 2009 | 06:05 PM
  #84
OJPAMG's Avatar
2005 E55 AMG
Originally Posted by jayton41
lol wow nice find bro but im more focused right nnow on turning my 06 c230 ss into a track car...but if i get to my dadz c55 later i think ill hit u up for one of these !!
I will be adding this to my freshen up as well as a shift kit
Old Oct 13, 2009 | 06:08 PM
  #85
MJ50's Avatar
Super Moderator
bone stock E55 AMG
there are two
Old Dec 21, 2010 | 03:41 AM
  #86
ahmad0658's Avatar
Brabus K8 E55 05
Is that the same for E55 2005 ??
Old Mar 15, 2011 | 12:45 PM
  #87
2010 C63
bring back this thread to see if anyone has blue tops for sale
Old Mar 19, 2011 | 05:36 PM
  #88
BrandonS's Avatar
'05 C55
still wondering if this changes the delay in manual from pushing the button to the car starting to shift
Old Mar 12, 2012 | 02:09 PM
  #89
lizardjack's Avatar
Shelby GT500
And why they didn't work for c32?
Old Mar 12, 2012 | 02:36 PM
  #90
xpl0sive's Avatar
CLS55 AMG
as per my data card, my transmission is
Transmission: 722643 06 009956
does that mean it has blue tops stock?
Old Mar 12, 2012 | 08:26 PM
  #91
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Great info!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 12, 2012 | 10:49 PM
  #92
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
I haven't seen a CLS55 without blue tops. I'm about 95% sure you got blue tops already.
Since this thread has been brought back. I will say this. Only because someone may only read the new posts. The blue tops only worked on my slipping trans for a while. It seemed to fix shift slippage from gear to gear. However it only lasted a little bit. I ended up needing new clutch packs.
Other than that, I'm pretty far removed from doing this mod so I forget a few things. IIRC, Its only older 55's that had brown tops. Like most 55 N/A's and maybe up to 2005???? I know that someone who has an older 55 N/A, they will need to do a trans calibration thing with SDS/STAR.
My friend who owns an indy Mercedes service shop did this mod on his 210 E55. He re-calibrated the trans and the car shifts and feels great. So what I do know is, some cars with the old brown tops, will feel jerky down shifts. Meaning, as your car's RPM's will race a bit when you slow down to a stop light or something like that. This can be fixed with STAR, but I have no idea how to do it. Although my friend does.
Old Mar 13, 2012 | 12:47 PM
  #93
xpl0sive's Avatar
CLS55 AMG
good info. I will be doing the EC TCU mod to my CLS, will report back on the shifting
Old Mar 13, 2012 | 08:23 PM
  #94
Dawson718's Avatar
E552004
Is that part # the same for the E55 04
Old Mar 13, 2012 | 11:13 PM
  #95
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just want to make sure before we expose this to a whole new set of guys. The info for years of people experimenting with these is that a few guys that have experimented with valve body and solenoid mods have reported some toasted trannys.
Just word of mouth and I have no proof. Mod at own risk on this one.
Just relaying info that I have heard over the years.
Old guy signing off.
Old Mar 14, 2012 | 12:02 AM
  #96
I haven't checked EPCnet in a while, but I think the brown top part number is now replaced with the blue top part number. I could be wrong.
As the OP'er of this thread (Back in my Hooleyboy days), it now seems as if the title is misleading these days. It did solve my trans slip issues, but only for a short time. It was like a band-aid.
If someone with Brown tops did this mod, I would have the Dealer do it. Or a shop that knows how to calibrate the trans via SDS. Not a shop that says they know how to do it, but a shop that has actually done it with success. I know of one shop in AZ that has done it with success and that Attwood European in AZ. I'm sure there are more out there though.
By biggest gripe was the downshifting causing the motor to rev you where slowing down.
Old Nov 10, 2021 | 06:40 PM
  #97
CDC55AMG's Avatar
CLS55AMG
I was enthusiastic with this possible new mod but seems CLS 55 already have as stock those BLU TOP valves p/n A 240 277 00 98 or new A 240 270 00 89
IIRC as of transmission with numbers ending 247135 Blu Top are stock
i just checked my Trans ID and it is 722643 05 882066
so, if I correctly understand, my last six number is bigger than 247135, meaning that I have those valves already
... indeed I am satisfied enough of my gearbox
but wilder would always be welcomed, especially because we can always set it to Comfort if it's too much
in any case, thanks again Hooley for the great search
... waiting for next discovery
Hello all, I was just wanting to verify that all transmissions under serial number ending in 247135 have brown top solenoids and above are blue top solenoids.
My trans number is 221592 in my 06 CLS 55. I was looking to get a deep trans pan at next service in spring and was looking to change out my solenoids to blue if there were not already. I have TCU Version 1 by Zerocat101 and blue top solenoids are recommended but was looking to get the SLR tune he has which need blue top solenoids. Thanks!
Old Nov 12, 2021 | 12:16 AM
  #98
PieRat's Avatar
CLS55
my 05 cls had blue your 06 will surely. Don't think any cls55 had brown.
Old Oct 1, 2023 | 01:59 PM
  #99
R_hill's Avatar
CL 55 AMG
Hello, just wondering if anyone else could verify that all transmissions under serial number ending in 247135 have brown top solenoids and above are blue top solenoids. I have a 04 CL55 and according to this I have the blue tops.
Thanks!
