If you have nitrous feedback please enlighten me
Old Feb 16, 2010 | 06:02 PM
Adsonic's Avatar
05 E55, 96 Caprice SS with T-56, 97 Wrangler with an LS2 & TH350
I searched the forum about nitrous but couldn't find more details, so I opened this thread hoping to collect some feedback about it.
Please note that I know:
It's a hand built engine
Nitrous will increase the wear and tear on the engine
Cost of the motor
Going with a bigger pulley is better
Now that we put that out of the way, let's get down to business. I'm all for pushing the envelope a little bit, and I feel a 100hp wet shot wouldn't need retarding the timing or a special tune (as long as it's nicely tuned for the S/C).
I'm thinking of going with a fogger kit, and use the steering shift buttons to arm and spray (manually).
Please let me know what you think.
P.S: I saw this thread, great info
https://mbworld.org/forums/w211-amg/...o-numbers.html
Old Feb 16, 2010 | 06:39 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
Call eurocharged. They've messed with nitrous I believe.
Old Feb 16, 2010 | 06:45 PM
Max.H's Avatar
E55
Cost of the motor
Hey Adsonic,
I will try my best to answer your questions about nitrous.
1. Hand built engine or not doesn't make a significant difference when you spray on it.
2. Yes and No. It's all how safely the car is ran on the spray and or how often it's used. If you're running the engine too lean then you can cause damage of course. Make sure you have the proper fuel enrichment. At a certain point you will need to upgrade to a secondary fuel pump. So you should ask someone who has done it first.
http://www.youtube.com/watch?v=ujsTZduMZAQ (This guy should know)
3. Going with a bigger pulley is not better in terms of power increase. A properly tuned 100 shot of spray should eclipse a pulley and tune. It should give you massive increase in hp and ridiculous amount of tq. Don't be surprised to see another 90-100+ lbs of tq and like immediately after pressing the button. It will have both you and the car giggling.
4. You should be Ok with a 100 shot. I'm pretty sure people have sprayed more then that on our cars. 100 shot is really the average for any decent v8 anyway. Great thing about nitrous is the cooling properties as well as the increase in power.
5. I would look into going a step or 2 colder on the plugs and make sure you run good fuel. Then let the beast out of the cage!
6. Fogger kit is a good idea. Make sure and place the nozzle as close to the throttle body as possible. Near the y splitter would be a good idea.
7. I usually don't like buttons. You better make sure you let go of that button before you lift the throttle or you can backfire and bend the throttle plate and cause other damage. Ive used the full throttle button with an on off toggle switch to arm the system. They also have several new fail safes in place. Nitrous tuning has come a long way.
8. I think its awesome and it's not for everyone. But, I'm sure you already knew that.
Old Feb 17, 2010 | 06:00 AM
Adsonic's Avatar
Just put it out there for those who might protest doing so with an engine that was build will so much love
Already messaged him asking for little feedback
Was looking at this then decided to stop as I don't have an idea where to find the TPS, RPM or the 1st gear lock.
Progressive Nitrous controller
The PROGRESSIVE NITROUS MINI-CONTROLLER combines the functions of our 2-STAGE TPS AND RPM WINDOW SWITCH and our HIGH CURRENT SOLENOID DRIVER all into one very compact module. It can progressively drive two channels, each with a 40 amp load capacity (continuous duty). The device also supports low-voltage OEM, V10 or 3 cylinder TACH signals without the need for additional adapters. It works with most OEM throttle position sensors including most drive-by-wire vehicles. This device also includes FJO's "real curve" ramp which allows you to create a progressive curve instead of just a ramp, and the ramp can be either time based or RPM based. All this and only the size of a spark plug box.
Old Feb 17, 2010 | 09:01 AM
Adsonic's Avatar
I sent them a PM back in Dec asking about their stage 3 package and weather they're planning on offering any Christmas discount. But they didn't reply. Tried replying to their thread about the package but again no luck.
I doubt they would reply now on a project that might require them to send more than an e-mail or two
Old Feb 17, 2010 | 05:33 PM
Max.H's Avatar
E55
Those are nice. Do it!
Old Feb 20, 2010 | 04:05 PM
Adsonic's Avatar
What would be the ideal activation / deactivation RPM. I was thinking of 3800 / 6000
Also, anyone knows which wire is the RPM signal from the engine’s ignition?
Old Feb 20, 2010 | 04:29 PM
sneakyneon's Avatar
Bicycle
I don't have a nitrous set on an E55 so by no means would I say I'm an expert on the matter.
I be hesitant to spray fuel and nitrous through the supercharger into the intercooler. I'd look for a spot post intercooler.
Also if your goals are 100hp you might consider looking at a dry kit, The stock afrs are pretty rich and would support a fair amount nitrous safely.
Of course you should know that a wideband should be standard equipment for a nitrous car. I'd look into the zedtronix unit. they have it were you can turn off/on a 12v source if a preset limit is met, So basically if the car runs lean it can turn off the nitrous.
Lastly if you really want to pull out all the stops and build a top shelf nitrous set up look into a direct port nitrous fogger set up. I would consider the safest way to run nitrous in the 55k. With the way our surge tanks are set up I would be worried about the last 2 cylinders (7&8) drawing in more of the mix than say first 2(1&2)
Good luck
Old Feb 20, 2010 | 04:32 PM
sneakyneon's Avatar
Bicycle
the rpm is read at any of the coils, there is 3 wire lead going in to it, I had 2 splice 2 of the 3 befor I wound the right one Just make sure and set up what ever is reading the rpm as a single cylinder.
Old Feb 20, 2010 | 04:46 PM
Adsonic's Avatar
I'll most likely be working with these :
ZEX V8 Wet Nitrous Kit for Fuel Injection Engines #82023
ZEX NITROUS TRACTION CONTROL WINDOW SWITCH #82085
Maybe a 75hp shot before going to 100hp
I was hoping to tap directly into the ECM harness for the stealth factor.
Old Feb 20, 2010 | 05:38 PM
sneakyneon's Avatar
Bicycle
You'll never see the tap at the coil cause the air box sits on top of them.
An idea of direct port on a slightly older intake
Old Feb 20, 2010 | 06:26 PM
Luke_M's Avatar
I would try emailing eurocharged directly or call them on Monday. They've always been great about emailing me back. Maybe they just didn't see the treads you replied to. Who knows. Just sayin
Old Feb 20, 2010 | 07:24 PM
Adsonic's Avatar
Direct Port, it looks like I can easily fine tune each cylinder that way ... maybe little safer too than going with only a fogger in the TB.
But not sure the gains from this are worth the trouble seeing that we're only talking about 100hp shot.
I'll PM them on this project and see what they think.
Old Feb 20, 2010 | 07:46 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Rflow and I shot it the ole fashioned way......hard switch controls on and off and she works great.
You can literally wire in a wet shot with nozzle under the airbox shooting right into the TB and NOONE will be able to see it.
Naked eye looking down on open hood.
Did get a touch of lean spike upon hitting the switch (using tailpipe wideband) which scared me enough to not go much further using on regular basis. Think it was draining the fuel rail/dropping pressure and car was stuggling to recover for a split sec. Wasn't that big a deal so it depends on how much you are gonna use it.
Itallion Stallion was shooting his car non stop without trouble. Thinking he had it hooked up the horn or something.
Check with him for more info.
Rflow and I were hitting 150shot and maybe a touch more
Old Feb 20, 2010 | 08:06 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
whoaa I never knew you messed with nitrous. PM me some details please !!!
Old Feb 21, 2010 | 12:12 AM
mikeevo's Avatar
2005 Silver E55
Supercharged and Turbo cars love nitrous, great cooling factor with even small shots. we had someone down here in East Texas busting low elevens with just a 50 shot and a Tune. I believe it was a dry shot. should be fine at that low level. I run NOS on my shelby cobra and setup my friends supercharged C6, I think its a great power adder and have never lost an engine. its almost always the greed factor , if 50 shot is good , then 150 is better and then 200 is a must and then PPPOOOWWW. 0 hp. so dont get greedy and have fun. We have shot in front of the intercooler and behind the intercooler and right in front of the TB. all seem to work well on different cars, some wet and some dry. I will agree the direct port is the best method but this is usually high HP shots like 200 plus or even staged setup where you start with 100shot then go to 200 or 250 shot once your down the track. Ooh I could go on and on. almost always worth at least 1 sec in the 1/4 if you dont have traction issues. 150 shot on a 96 TA Ws6 with mild mod cut off over 1 sec and that was with wheels spinning thur the first 100 ft , with 60ft times at 1.9 -2.0 , never ran slicks the rear end wouldnt take it. just some info.
Old Feb 21, 2010 | 09:53 AM
Adsonic's Avatar
Would this happen with a 100hp shot?
Also,
1- Do I need to worry about the timing?
2- what would be the ideal activation / deactivation RPM? I want to play it safe here.
Old Feb 21, 2010 | 06:19 PM
Luke_M's Avatar
Jakpro1,
PM me some info on your Nitrous setup to if you don't mind. I never knew you had it. Would like to have it just for the very occasional use
Old Feb 21, 2010 | 09:52 PM
mikeevo's Avatar
2005 Silver E55
[quote=Adsonic;3949977] Would this happen with a 100hp shot?
Not likely on a 100hp shot. just check with a wideband once or twice if your worried. Dyno shop can check or borrow one.
Also,
No timing issues needed. and as for activation. either pedal switch most come with this , or momentary activation switch button type or has some have mentioned you can set it up on the horn. if you spend some more dough you buy the RPM switches. Usually start at 3500 to 6000 rpm. MSD has pill switch you can even change by 100 rpm increments.
Old Feb 21, 2010 | 10:45 PM
Adsonic's Avatar
Yes I would be going with an RPM switch, but I was wondering about the RPM that activate the system and the RPM that deactivate it
