Square setup on wheels?
Is anyone on here running 4 rear wheels on their E55? I was thinking 275/35/18 all the way around would work on the E55. The wells in the front look like they can accommodate that. Also if you are running or know of someone running that setup please post up and share.
Regards
Amir
Regards
Amir
Received 1,488 Likes
This place is a joke.
I am working on something similar. The rear wheels fit fine up front with the 265/35/18. You could even fit a 275 I think depending on the brand of tire. I am going to run the 9" replicas up front and custom widened 10" replicas in the rear.
Can you run a 275 tire on the E55 rear ? All stock ride height, stock suspension etc.
Mine are the factory 265s, want to run a slightly wider tire in rear. 285 would probably rub, I'd think..? 275 would be best bet, no?
I have 285 rear and no rub. If u want to play safe go with 275
Thanks guys.
CharlyE500 - are you on stock suspension, ride height etc. all stock? I would LOVE to run 285s in the rear on stock wheels, but I'm afraid of rubbing. You don't get any rubbing at all, even on turns and looping on ramps?
OP - sorry for thread hijack, man..
Sorry I wasn't clear enough on this. What I mean is the SL rear wheels are 9.5" vs the E55 rear @ 9" This means you don't have a square setup, but more to my point, although you are running the same size tires all the way around, your rear tires are more stretched on the rims now than the fronts, and makes the rear tires look smaller than the fronts.
