E55 higher mileage reliability?
Im looking at a 2005 right now with 91k on the clock. It had some work done at 30k, receipts from the shop, no major repairs on carfax, so I’m sold, but I have literally zero experience with these cars. I studied Audi S4s for a LONG time, so I know the ins and outs of them, but with a third child, that backseat just wasn’t working. I’ve done some research on the car, and the drivetrain seems to be pretty much bulletproof, but I’m wondering what specific things I should be looking for when I go to check out the car.
From the owner’s description “Has an evosport stage 2 performance kit which was installed by original owner at about 30k miles which includes shorty headers, 80mm crank pulley, plugs/wires, and a tune. Its a proven setup with excellent reliability rated at 580hp”. Is this a known setup? Any issues with it that have been found out over the years?
im prepared to take on the increased fuel costs (this is a weekend toy anyway, I have a company car for day to day stuff) and I’m fully aware what routine maintenance (plugs and wires, pads and rotors, etc), but I really need an expert to tell me where things would have gone wrong by now, what to look for in reference to a shoddy repair of said issue, and when my next major maintenance issue is going to pop up (car is at 91k right now)
Any help would be much appreciated.
If the guy looks like he maintains his car, and the car is clean, and you have a good reason to believe it- go for it.
Those are mild mods.
Ways to mod this car: crank pulley or supercharger pulley size change, bigger injectors, mids or long tube headers, cat delete, converting to e85, loads of cooling stuff, and people build their engines to handle more boost.
They also make aftermarket superchargers for them. That's it. So an 80mm pulley, tune, and shorty headers isn't anything crazy but it will add some power over stock.
I've mainly been looking at German stuff due to the country's reputation for engineering and build quality. The S4s are rock solid through 200k (minus a potential huge pitfall, but hey) so I'm assuming the AMGs are the same way. I read about the E63s having a potential pitfall, so I wanted to do some more research on the 55s.
Thanks for the response
Things to verify, inspect, and maintain as necessary:
https://mbworld.org/forums/w211-amg/...ml#post7169029
In the comment about SBC actuations in the above post, you should also verify estimated SBC pump life remaining and pre-tensioning reservoir pressure:
https://mbworld.org/forums/w211-amg/...ml#post7394078
One of the weakest, if not the weakest point IMO, on the E55 can be mitigated with a few dollars and an hour of your time:
https://mbworld.org/forums/w211-amg/...tenance-2.html
In my opinion, by 100,000 miles the front end will have at least one bad ball joint and or bushing. In my case, I had two or three of each (need to look at maintenance records) plus a bad bushing in the rear. It's a great car and should last for a very long time so long as she gets plenty of TLC. If you swap out air springs or perform major suspension work, plan on recalibrating the air suspension; not particularly hard so long as STAR is available.
Stereo and navigation are dated; options are available but I'll leave that for the audio heads.
I'm going on four years of ownership and 70,000 miles of driving. It's been frustrating at times but I'd do it again.
I got some more pictures of the car (engine bay, undercarriage) and everything looks clean, no oil or spots that look like they've been bathing in oil for years .I think I'm gonna go buy this puppy. Prettiest blue color I've ever seen on a car.
Mine has 95k now (bought it with 81k 3 years ago) and waterpump failure, front strut were the only two things that could have stranded me. Fortunately both failed literally 1 block from my home and the other (strut) blew its seal as I was in my garage working on my other car, and heard the pop/hiss, and saw the car dropping. Beyond that, its one of the best cars Ive ever owned from a comfort/styling/power combo. And I'd NEVER remove the air suspension. It is a great handling/comfort tradeoff aspect, provides really level handling/cornering, and its easy to work on.
Generally a 2005 E55 is considered to be a very reliable car for a car of its vintage. As already mentioned above, the E55 with the M113K engine and the 5 speed transmission is a very reliable machine.
An E63, in my opinion is an overall better driving/handling vehicle (better steering feel, brake feel, more precise transmission) but the M156 engine seems to have headbolt issues, various leaks, oil leaks, coolant leaks, and higher fuel consumption than the M113K engine which generally have very few leaks (rear main seal, that's about it).
However, E63s don't have SBC (computerized brake system) expiry components which are expensive to replace.
My biggest concerns about your example is how the car was maintained and how the modifications were done. Were high quality parts used? Were they installed by a reputable and experienced installer? If the car passes the VMI (vehicle master inquiry) at a dealer, all the required work was done on time, then I'd say it's likely to be a very good car.
90K miles is fairly low on these cars. Still an engine with plenty of life. Many owners here are over 100K miles (I'd say most), and a few are over 200K miles or nearly. There are a handful of known cars over 300K miles and a well known car with 400K miles.
There are a few minor cosmetic issues, which are to be expected of any car that has been used, but overall, it is a very nice example. The car has EvoSport pullies and headers. Granted, they are no longer in business, but I really don't think that is a concern. Personally, the color just wasn't calling my name, so I was going back and forth in my head on it. But I can confidently say rest assured, as that is a nice, nice car, and honest seller.
Hope this helps,
-Chris
The E55 and E63 both have their issues. Generally, if you want to mod go with an E55 and if you're going to stay mostly stock go for an E63. My biggest gripe with my E63 is the slow as **** 7 speed it has in it.
At least go drive some E63s and see how you feel about them. Most people on here own E55s so they're going to tell you that they're better cars. I love my E63 and would not consider getting an E55.
Hope this helps,
-Chris
E63 is definitely the nicer car to drive.
k.
