I THANK WE HAVE A PROBLEM
From my observations, the E63 takes about 5x longer to heat than my M3 did (V8). Both motors have about the same amount of oil to heat, so doubt that is the issue.
I have a 2014 E63S.......if you are looking for specific data/times, etc. let me know. I can start to closely monitor it. I also think it abnormal to take so long for the oil to get to temp, especially in a turbo motor.
it doesn't seem right that a turbo motor is acting this way.
Hopefully somebody here can come up with a solution to this problem.
I also own a air cooled 911 which has ~ 12quart of oil. This motor takes about the same time until oil is at operating temp. That's why I never considered this to be an issue.
Do these engines have an oil/water heat exchanger installed? Maybe it's configured too small?
I still have warranty on the car so I haven't paid much attention to the systems installed.
Would be interesting to find out what the bottleneck may be.
Ed
My previous car was a 2014 M5, also TT V8, and it seemed pretty slow as well although the temp gauge was analog.
My NA cars, including an M156 motor, did seem to heat up quicker. Fastest was an RS5. It was 5 minutes.
I normally start off in comfort mode. Would starting off in S+ mode make it heat up faster since we are using lower gears and higher RPM's?
it sounds like it's "normal" operation for a 14+ to take a long time to warm up, but we have reports saying pre facelift only took 5 minutes to heat up.
Something must of been changed for a reason here
with this newly found flaw they are probably only work $25K in the next few weeks any ways when nada and KBB find out, but being a nice guy i will give each person with a 2014+ e63 $28K to relieve you of these piece of crap cars that lose all the roll races and were engineered by special ed students
(don't take my post too serious, olsen...just poking fun at the terrible situation you're facing)
