E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Old 02-08-2023, 11:17 AM
  #176
ussocom_1's Avatar
2014 E63S
Front driver seat Cushion change & TCU problem
Hi Joe,
I'm following the contents for a long while. Super super helpful! Thank you so much! I would like ask some documents for Front driver seat Cushion chage for my w212 e63s.
Also, I would like to know whether anyone knows the TCU difference betweetn 2014 model year and 2015&2016??
My Vin: WDDHF7GB3EA942116
Thank you so much!!
Winston
Old 02-08-2023, 02:11 PM
  #177
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by ussocom_1
Hi Joe,
Thank you so much!!
Winston
All of the relevant data that I believe is required.. Let me know if you something else. Good luck!
Regards,
Joe
Old 02-17-2023, 01:17 PM
  #178
pkak2023's Avatar
2014 E550 4matic
Hi Joe,
Do you have parts list with the diagram for turbo coolant lines.
My Vin: WDDHF9BB7EA886684
Thank you,
Paul
Old 02-17-2023, 02:17 PM
  #179
Valvestud's Avatar
Originally Posted by pkak2023
Hi Joe,
Thank you,
Paul
See attached. Let me know if you need anything else.
Regards,
Joe
File Type: pdf
SilverE5588 (02-19-2023)
Old 02-17-2023, 02:23 PM
  #180
pkak2023's Avatar
2014 E550 4matic
Perfect, thank you!
Old 03-12-2023, 01:22 AM
  #181
angelglo's Avatar
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
Hey ValveStud,
I see you are the go to for all things M157. Do you happen to have Valve Cover R&R for M157?
Thanks!
4JGDF7EE2DA260733
Old 03-12-2023, 02:56 PM
  #182
Valvestud's Avatar
Originally Posted by angelglo
Hey ValveStud,
Thanks!
4JGDF7EE2DA260733
Attached. There are numerous sub procedures listed, so let me know if you need others.
Regards,
Joe
Old 03-12-2023, 02:58 PM
  #183
Valvestud's Avatar
Hey ValveStud,
Thanks!
4JGDF7EE2DA260733
Regards,
Joe
Old 03-12-2023, 03:50 PM
  #184
angelglo's Avatar
Thanks, Joe, I looked it over and I didn't see the Valve Covers R&R and only saw the intake with the sub procedures.
Old 03-13-2023, 02:08 PM
  #185
Valvestud's Avatar
sorry misread your request. Out of town until late tomorrow. I’ll download and respond then or Wednesday morning.
Old 03-13-2023, 02:53 PM
  #186
angelglo's Avatar
Thanks Joe, No rush and enjoy your time away
Old 03-14-2023, 10:53 AM
  #187
max.gibson's Avatar
2013 Ml63 AMG
Head Gasket Details?
Hey can you find me details for head gasket replacement? I'm about 25% into the job and would appreciate the help. Thanks!
Old 03-15-2023, 04:36 PM
  #188
Valvestud's Avatar
The two procedures are attached for left and right covers. Let mw know what others you need.
Regards,
Joe
Old 03-16-2023, 12:02 AM
  #189
angelglo's Avatar
Thanks Joe. I do have a question though, if you happen to know. at step 9, it says to remove cover at cylinder head. Im assuming to do this, all the items like the oil filter housing, turbo coolant lines, etc need to be removed. Im sure this is part of the subprocedures. I dont think i can remove the front cover bolts and without removing all the associated items in the front of the engine.
I am also assuming there is a torque sequence that is involved in torquing the valve cover. Do you happen to have this? Ive worked on M273 motor before and I remember that it had a torque sequence since both engines valve cover also act as the cam shaft hold down, and bearing surface.
Old 03-17-2023, 04:45 PM
  #190
Valvestud's Avatar
I can provide additional procedures as you need them. Attached is the torquing doc.
Regards,
Joe
Old 03-17-2023, 04:54 PM
  #191
NH_E63's Avatar
2015 E63 AMG S
Hello - Was wondering if I could get the documents to pull the radiator fan out of a 2015 E63 AMG S VIN: WDDHF7GB7FB099162
I'm thinking I'm going to have to pull the bumper, don't want to though LOL
Thanks!!
Old 03-17-2023, 05:15 PM
  #192
Valvestud's Avatar
Thanks!!
Attached is the main procedure. There's lots of stuff associated with the R&R. Let me know which other procedures you need if you decide to move forward.
Regards,
Joe
NH_E63 (03-17-2023)
Old 03-17-2023, 06:36 PM
  #193
NH_E63's Avatar
2015 E63 AMG S
Regards,
Joe
Thank you so much!! Could I get the AR20.40-P-5050EL remove fan unit as well?
Old 03-18-2023, 02:00 PM
  #194
Valvestud's Avatar
Attached.
Regards,
Joe
File Type: pdf
NH_E63 (03-20-2023)
Old 04-08-2023, 07:46 PM
  #195
CZ 75's Avatar
E63 AMG
@Valvestud If not already in this thread, can you share the repair docs for the water pump, thermostat, and coolant lines? Thanks.
Old 04-09-2023, 02:09 PM
  #196
Valvestud's Avatar
See if these get you what you need.
Regards,
Joe
CZ 75 (04-10-2023)
Old 04-10-2023, 01:52 PM
  #197
CZ 75's Avatar
E63 AMG
Regards,
Joe
Thank you!
Old 04-24-2023, 12:23 PM
  #198
CZ 75's Avatar
E63 AMG
Regards,
Joe
@Valvestud
Do you have a document for removing harmonic balancer?
Old 04-24-2023, 12:43 PM
  #199
Valvestud's Avatar
@Valvestud
Attached.
Regards,
Joe
Old 06-08-2023, 09:14 AM
  #200
Jaybird123's Avatar
2014 E550 coupe
Attached.
Regards,
Joe
Joe, do you by chance have a doc on the m278 camshaft adjuster replacement? I have done the swap but need the torque value for the cam adjuster bolt...
Quick Reply: E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
