I need a little more info as to what you actually want to address. Attached below are the exploded views of the major components of the front drive. Please take a look and let me know what you're looking for, and I can then provide WIS docs. Also, I prefer you provide VIN so that I provide most accurate data. The data attached is from my 2014.
Thanks,
Joe
It’s been about 2 years lol but now I need to replace the seal for the front diff pinion gear. Any info on the removal process. Thanks
Is it possible you can proved me the parts list for left valve cover. I want to make sure I'm using the correct bolts that go under the oil separator. I know the 21 bolts but a bit confused of what the bolts are under the breather
Car is a 2015 e63s.
Is it possible for you to identify part from attached picture? If not, I need more info as to where to focus. The valve cover is only referenced as an assembly with the cylinder head. No separate part seems to be identifiable.
Is it possible for you to identify pert from attached picture? If not, I need more info as to where to focus. The valve cover is only referenced as an assembly with the cylinder head. No separate part seems to be identifiable.
Regards,
Joe
thank you. The attachme t is not providing part number for the bolts to hold down valve cover. My strugle continues lol. Appreciate you taking your time. Thanks
Perhaps I'm confused. In your original request it appeared you already knew the part for the cover bolts and needed something else. The part for the 21 bolts is A1139900222.
awesome. Now i just need the part number of the 2 bolts that go under the oil seperator.
almosy there. Thank you much. The part circleds sits on left valve cover. Under that there is 2 screws/ bolts that hold down valve cover. Thats the screws im looking for.
there is 21 that go on valve cover plus and addition 2 under this oil seperator
So not on the picture from before? I've added the parts listing to it.
Can I get a parts list for the charge pipes. Please. I'm almost done
As always with Mercedes, their terminology of parts and those of us in the US, don't match up. I need more description of what pipes you're referring to, as the EPC system comes back with a myriad of possibilities.
