when i play my music too loud the sound quality turns poor. a worker at the mercedes dealership says it’s my amplifier and not a blown out speaker. is there a DIY way i can do to fix this
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,775 Times in 4,764 Posts
Quote:
...."speaker ok but bad Amp".Originally Posted by erickproxy3
it does sound weird!
Usually it's the Amp that fries the speakers.
Are you amplifying a known clean source such as satellite radio as opposition to bootlegged mp3 over Aux input....
Play with the balance and fade controls. If noise is piped everywhere it's the source and if it stays local it's a channel output (SPK/AMP).
Quote:
has this issue been solved?Originally Posted by erickproxy3
CaliBenzDriver
close
- Join DateApr 2019
Quote:
yes, many times.... just need another amp module.Originally Posted by momo a
Try not crank up the sound level too high for too long to avoid cooling issues.
yes, many times.... just need another amp module.Try not crank up the sound level too high for too long to avoid cooling issues.
mine started cutting on when it was a very hot day and I was blasting music and every since then I can’t play the music too loud with strong bass or it’ll cut out. It’s very annoying. I have a 14 model E63 with the B&O. I’m not sure which AMP to replace. Is it the one in the trunk?
CaliBenzDriver
close
- Join DateApr 2019
Quote:
That is good news because your amp only needs "regreasing", it's not fried 👍Originally Posted by momo a
You can easily upgrade the cheapo factory thermal grease that has run down vertically in the main amp. The woofer amplifier is horizontal so thermal paste stays put.
Use good "CPU thermal paste" :
"artic silver" top notch thermal compound
Thanks for the info, I’m going to be sending you a quick pm!
ExploreCaliBenzDriver
close
- Join DateApr 2019
Quote:
This is the HK style...Originally Posted by momo a
two chips bridged into a single channel: white thermal silicone
This module is horizontal, main amp is mounted vertically... oily sauce runs down under heat.
