Oil pump solenoids
Rating: Thread Rating: 9 votes, 4.33 average.
Old 03-23-2024, 05:16 PM
  #1326
Rickman30's Avatar
2014 Mercedes-Benz E350
Main diagnostics was factory defective crankshaft was showing forging crack at 2000 Mi only.
The only negative comment I heard was:
Q: Can we replace this engine?
"We got 3x used engines and they were all junk".
Oil8ng would not help this hard fault.
For everyone else, viscosity would help soft cushion a fluid film on bearings.
We keep looking at oil related nightmares...
the best solution maybe a mix of :
approved additives package + viscosity
- Best of both protections wins:
mix a little of xW-50 in approved xW-40
makes approved xW42
Obvious simple fix
The crank was probably damaged in wreck or by the hack that did the original work. I've seen some really spectacular stuff being next door to a body shop and doing work for them.
The main thing is, a Mercedes Dealer did the same level of work as any Mexican VW repair...shop.
This is the level of people inhabiting MB service departments working on cars is beyond their capabilities and causing insult to injury at the customers expense.
And that's what scares me about my engine. "Take it to the dealer, they said, they know what they're doing, they said, it'll be great, they said". Making same exact noise $3700 later, as if they did nothing at all.
Want to know why Rick doesn't even consider owning an AMG, check them parts prices. My Base model is more than adequate.
The following 3 users liked this post by Rickman30:
CaliBenzDriver (03-23-2024), JettaRed (03-23-2024), OldManAndHisCar (03-23-2024)
Old 03-27-2024, 05:04 AM
  #1327
CaliBenzDriver's Avatar
Received 3,369 Likes on 2,241 Posts
MY'14 W212 M276 3.5NA @55kMi
OMG... FAN'S STOPPED!
Originally Posted by TomZVB
Variable volume oil pump used on GM's Gen V LT1 - Great video showing how the variable stage oil pump works. This is pretty much how our pumps work. A key point is made about oil demand and fuel economy. Difference is that this pump runs off the end of the crankshaft vs chain on ours.
Enjoy!
https://www.youtube.com/watch?v=G2ZZT8cumLk
It looks like Chevy's new design decision is working out - Here is the burned pump solenoid.The amazing part is good ppl are fixing this lucky fault to regain original ( low) pressure.
Meanwhile MOD2.1 and 3.0 are being hatched.
Today for the very first time, I drove back home and MY ENGINE FAN WAS OFF !! - Never ever happened even once since new!
I have a pretty good idea what was causing that
I popped the engine hood to physically see big fan was not spinning after driving at operating temperature. Any one else would have guessed a fan problem.
Less electrical load is truly saving gasoline energy. "Regen 14.9V" is only useful on drained battery.
LUBRICATING PISTONS DOES CANCEL HOT FRICTIONS.
Old 03-27-2024, 07:10 AM
  #1328
JettaRed's Avatar
Received 1,601 Likes on 1,194 Posts
@CaliBenzDriver you should get the AMG IC mod from @BenzNinja which will display the coolant, oil, and tranny temps simultaneously and you can view specific temps and not rely on anecdotal input.
AMG Instrument Cluster Display
Old 03-27-2024, 08:47 AM
  #1329
S-Prihadi's Avatar
Received 4,393 Likes on 2,575 Posts
This I been wondering. Is above IC photo from your SL400 Jet ? If so...........
Only AMG M157 engine has engine oil temperature data, because it uses the special oil level sensor which is also an engine oil temperature sensor, see post # 1,290
So , if an engine is not M157, where the hell does that engine oil temperature data come from ? Regardless the IC is converted AMG version, no sensor means no data, unless it is the
calculated data like how M276.8 or .9 ECM is doing for calculation, but then Xentry can't even see such data as no such sensor exist.
Tranny oil temp is easy, because there is a sensor for that in tranny.
CaliBenzDriver (03-27-2024)
Old 03-27-2024, 08:55 AM
  #1330
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
So is adding trans temp available for an older (2014) AMG ? . I am 200 miles into change from 0w-40 to 5w-40 and the time from fast idle to normal idle is about the same.
Old 03-27-2024, 09:11 AM
  #1331
JettaRed's Avatar
Yes, it’s from my SL400. I’m not home at the moment, but when I get back I will check for oil temp in the live data. I don’t know how it is determined, but the AMG section in the SL Operator’s Manual shows oil and tranny temp (I think). @BenzNinja is the best person to answer your questions.
Old 03-27-2024, 09:20 AM
  #1332
JettaRed's Avatar
That’s a question for @BenzNinja
Old 03-27-2024, 09:23 AM
  #1333
S-Prihadi's Avatar
Oky doky, I will ask BenzNinja.
However, since I know every sensors on M276.8** , what you are seeing is a calculated data base on a temperature model made by MB
MB speaks of how important the oil temperature and pressure is for the VVT to work properly, yet those 2 sensors are UnObtainium grade for almost all MB engines of last 12 years.
The following 2 users liked this post by S-Prihadi:
CaliBenzDriver (03-27-2024), Rickman30 (03-30-2024)
Old 03-27-2024, 09:28 AM
  #1334
BDC90's Avatar
when I did the trans fluid awhile back I got the temp readout from an iCarsoft so there must be some way .
Old 03-27-2024, 11:26 AM
  #1335
JettaRed's Avatar
There probably is, I just can't confirm. I'm thinking of having the AMG menu added to my C350. If I do, I will confirm.
Old 03-27-2024, 11:39 AM
  #1336
JettaRed's Avatar
Very interesting. Since I can't access the Engine Module with my LAUNCH scanner other than to read and clear codes, I could not get to the live data for it. So, I used my iCarsoft scanner.
I took the picture of the iCarsoft temperature readings and immediately followed with the IC display.
105°C=221°F (coolant) and 96°C=204.8°F (oil). So, the oil temp reading matched (204.8°F vs. 205°F), while the coolant readings were off a bit. Hmmmm, wonder why?
Old 03-27-2024, 01:36 PM
  #1337
calculated input data
We know the Coolant Temp display are doctored by the ECU.
Surya demonstrated the working of what he called the "liar gauge" or the idiot gauge because it tells stories instead of reality.
In fact this data translation is made to hide crazy stuff happening to coolant spikes with smoking oil.
So gauge display is not too useful between the calculated value and the translated one
Regardless these limitations are no problem... I use anecdotal inputs to bridge gaps. My logic is similar to the ECU firmware: I use what data are available!
extrapolated sensor data
Master Surya's WIS document above explains how the Bosch logic extrapolates numbers from limited sensor count.
You don't need to trust my word, MB firmware engineers say so themselves. Numbers are approximated and that's all right to understand the results we get.
>> Realize also that this Translation Logic Needs To Adapt To MOD Conditions... don't be surprised that everything is NOT "unplug and play".
The state of the art ECU firmware just need the right conditions to spin everything right.
I am one to say we've got what we need: coolant temp sensor. The best way to use this data.... is the way Papa Surya does it!
picture tells a thousand words: cold unsprayed oil at driving RPM... amazing?
Now do you understand how oil gets burned into vapors by dry pistons?
I wish we had a "viscosity sensor" but since viscosity is affected by so many variables, a pressure sensors would be more useful.
> GAUGE READING...
Ppl who have true OIL TEMP displayed on MOD2.1 can see oil temp quickly climbing up to coolant temp then pushing coolant further up as pistons get spray-cooled above ~1500.RPM
This instrument cluster shows you A to Z...
  • the piston heat being transferred
  • into engine oil by pistons squirters
  • then transfered into coolant by heat exchanger
  • then out through the heated-Tstat
  • into big radiator
  • where supersonic fan no longer needs to spin.
-- On MOD1. Oil temp only goes up above 2500.RPM.... so I researched why and came up with $5 fix to provide normal heat management.
People have been looking at these gauges, blown up engines, melted pistons, cooked CPS, black oil... and did nothing about it until Papa Surya and I started kicking the tires - The rest is history as you know it
> Whole 9-yards:
What do these have in common:
  • 8/6x Piston sprayers
  • 4x VVT gears
  • 3x Chain tensioners
  • 1x Solenoid valve
These hydraulic components rely on normal oil VISCOSITY to perform well.
The advanced dry-lubing option can now be disabled with experimental MOD2.1x.
-- It saves energy by reducing frictions and not spinning powerful fan.
-- It allows ECU to dish out massive torque with GDI multi-shots injection from 900.RPM
-- It switches extreme trapped heat with regulated engine temperatures.
-- Oil sealed pistons reduce blow-by to better than new
> HOW TO MIX MOD2.1x:
Get ready to get your hands dirty....
Your mix formulation (forum link) is based on your own judgement.
I suggest to play with 3 or 4kMi old oil... if you screw up, dump clean and start fresh oil.
TIP: gradually increase viscosity by 100ml steps over 500.Mi distance until engine fan stops.
Samsung screen capture of formulaMELTED PISTON CROWN (Solenoid on diesel ....)
Act early.... MOD can not help damaged engines.
juanmor40 (03-27-2024)
Old 03-27-2024, 06:03 PM
  #1338
JettaRed's Avatar
Wish I could read the micro-text. But i did add about 500ml to my C350 after sucking that much out with an electric fluid pump. I haven't had a chance to drive it yet to detect any differences -- it's the wife's car.
Old 03-27-2024, 06:14 PM
  #1339
loaded ready to zoom
JR: quick... pretend you go buy some milk or bread at the store !!!
What oil base do you have:
  1. mileage/color ?
  2. grade ?
500ml is a big shot. It a good medicine anyway. Tranny gonna be a little weird with sudden drastic improvement but ok.
​​​​​​The accelerator is so touchy wife complains I heart her neck peeling off the green light.
MOD2.1 swaps extreme heat for extreme brakes. Super strong touchy brake pedal !!
"brake HOLD" sensing more consistent too!!
Distronic Plus accelerator/brakes now smooth.
IT'S ALL CANDY
juanmor40 (03-28-2024)
Old 03-27-2024, 06:21 PM
  #1340
JettaRed's Avatar
  1. mileage/color ?
  2. grade ?
Mobil 1 0W40 with Cera Tek added, with maybe 700 miles. The color is light brown, probably due to the Cera Tek. I added about ½ liter of the 15W-50. This is for my M276 NA engine.
Old 03-27-2024, 06:30 PM
  #1341
ECU Learning Mob1 mix: POWER ON TAP!
Great! Your 700Mi oil is in low mileage condition.
-- Go drive 25Mi around town for now to train the new base RPM parameters. Freeway possible but not part of quick retraining.
-- Notice BIG torque showing up and becoming consistent as low as 900.RPM and above
-- You'll notice Gear 1 - 2 - 3 gradually getting extended into higher RPM like normal gears.
-- Witness engine developing new torque and tranny learning to use it.
-- Let's see how soon the big fan is no longer needed with good cooling...
-- Finally pay attention to idle sound switching over to sound like GDI diesel
> How old are Tensioners, what mileage?
+++ MP3 sound file of GDI idling +++
Smoooooth flat RPM from well regulated pressures.
No butterflying around idle RPM.
No rattlesnaking sound
(muted but noisy 1x HPFP lobes, well lubed)
Thanks for BOSCH unrivaled technology.
File Type: mp3
Old 03-28-2024, 08:19 AM
  #1342
S-Prihadi's Avatar
Cali,
I have a bit of un-happy news for your engine valve train by sound of it. It is much louder than mine.
TO NOTE :
AA. I know you have more mileage than mine. Mine now only 40,000KM.
BB. I believe you drive very polite and does not do much above 3,500 RPM.
So before oil solenoid defeat, a polite driver won't get much oil towards the valve train compared to guys like me doing higher RPM for gear change,
sometimes I force it to MANUAL mode so I can maintain 4,000 RPM.
I traced your engine sound clicking frequency.
I initially thought it was the 3 fuel lobes of HP pump camshaft's, but its frequency occurrence seems to indicate valve lifters, probably exhaust ones, the ones always working the hardest.
Approx 31 HZ, that is a fast one.
I am comparing yours to mine at video below :
I have reduced loudness level of your audio to get near the same by VU ( volume unit ) meter to mine.
I am sure your lifter is fine in terms of its current specification, but not as quiet as mine.
If you see video time 1:25 where my engine oil has gone hot at 94C, my engine valve train is actually more quiet than at cold oil 29.7C.
Old 03-28-2024, 08:46 AM
  #1343
TomZVB's Avatar
R231 SL 63
Guys, I’m not sure I’d start messing around with custom making your own oil viscosity. These oils are chemically blended - this is an areas where more harm than good can happen. Sure, if you were in a pinch and changing the oil soon, I wouldn’t worry about it, but as a long term solution, I wouldn’t do it.
I have an oil change coming up and I’m leaning toward Driven DI40 because it’s all-inclusive in terms of an additive package that will help support aluminum bores, Mobil 15w50 with Ceratec isn’t out of the question either (much less expensive) and would allow me to keep one oil type/viscosity on-hand versus many (I use Mobil 15w50 in my 509 boat engines as well as my 496 Suburban).
kevm14 (04-07-2024)
Old 03-28-2024, 10:53 AM
  #1344
JettaRed's Avatar
@TomZVB good point. I think the problem, from what I have read, is that mixing different BRANDS is not advised (see link below). However, I may have gone too much and think I will drain a quart and add 0W-40 back in until I do another oil change with 5W-40.
https://mechanics.stackexchange.com/a/60894
Old 03-28-2024, 11:02 AM
  #1345
Cifdig's Avatar
2007 e350 sport. 2010 350 4matic sport. Worlds first W212 E63R self built.
Been using 5w50 for over 6 years now on stock and fully built. Actually 8 years, the pendemic killed my time frame. 750 plus wheel hp on stock setup. And 1,k hp daily driven. Using 3500-4k miles intervals with oil changes. I do check walls every time I change plugs just to see if anything is standing out, or if a cylinder looks on the wet side with oil blow by. Happy to report neither.
Recently on my cousins cls 63 big turbo built engine, he was running 0-40 mobile. We noticed he would have oil consumption requiring a quart of oil between oil changes and when driven hard sometimes more. Compressor blades had some oil residue which is common with blow by from hot thin oil that breaks down easy flowing through the pcv. But since switching to 5w50. These issues have almost stopped. I say almost because it's slightly consuming oil but it's not showing other then slightly lower level. I think it's being used during hard WOT pulls. Also After cleaning compressor blades we now keep an eye on them and see no oil residue buildup, no cold start oil blow by, oil temps much more stable and so far it's been 4 oil changes since switching to 5w50 and no additional oil has been needed between oil changes. My point is you don't need to give it much thought to step away from 0w40.
TomZVB (03-29-2024)
Old 03-28-2024, 11:48 AM
  #1346
diesel idle
Cali,
TO NOTE :
https://youtu.be/Lf4lcZ7i1ms
Master Surya, thank you for analyzing the frequency distribution
My special diesel idle sounds pretty weird like something is knocking until the ECU switches in and out of this injection mode.
That's why I posted it because the new normal is radically different than usual. Not a problem, quite the opposite: hope your engine will switch into that mode. You'll recognize it.
At cold startup my engine sounds just like yours then switches after being fully warmed up. After that it can restart warm with this injection mode.
My ECU started allowing this after MOD2.0. I attribute this to tight tensioners allowing stable timings.
Old 03-28-2024, 02:06 PM
  #1347
thick 15W-50... only with moderation
I see... it's your call to try and thin out your mix or to stick with it until ECU learns to work with it.
You added a single shot of 5% and now realize how transformative it is. Your ECU/TCU has no knowledge of engine oil pressure or viscosity.
From MOD1 to MOD2.1 I recommend multiple smaller shots such as: 200ml + 100ml then perhaps 100ml once or twice as needed.
I can not imagine 100% of 15w-50 being compatible with my MOD engines.
In stock limited pressure engines perhaps 15w50 works because the higher viscosity helps build at low RPM but when the stock pump switches pressure, the ECU is still going to freak out.
The pressure switching is not accounted by software and that's one thing MOD1 fixes: smooth pressure ramp without any switching step.
I don't know that Mob1. 15w50 has approved additive package for MB engines, so personally I boost "approved base oil" to be safe.
Old 03-28-2024, 04:08 PM
  #1348
TomZVB's Avatar
R231 SL 63
Would love for someone to explain the additive package and specifications of a 229.5 approved oil. I keep looking and find no real explanation.
For direct injection I know we want oils that will not create an easier ash. But what else? My boat doesn’t care. And neither does my Suburban. Neither did my Hellcat.
As I’ve said before my main concern is longevity especially if beat on hard. Don’t care about a warranty - and if it breaks, I’ll build another one (but I don’t see the oil spec contributing to damage).
Old 03-28-2024, 04:21 PM
  #1349
TomZVB's Avatar
R231 SL 63
And to note… everything that I have found an out 229.5 has to adhere to stringent standards of fuel economy. Funny thing is that 600 hp/700 lbs ft and fuel economy do not mix - at least to me (and as I said a page or two back, it is pretty amazing that MB was able to pull it off - but also at the expense of longevity).
Old 03-28-2024, 04:56 PM
  #1350
juanmor40's Avatar
Received 1,564 Likes on 981 Posts
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
Not sure if you have seen the following:
https://360.lubrizol.com/Specificati...20base%20oils.
The variant 229.51/52 are variations from there, but at least is an entry point for further research. MB229.5 -> European specifications + Daimler extensions (I guess that is where the unknown comes in)
TomZVB (03-28-2024)
You have already rated this thread Rating: Thread Rating: 9 votes, 4.33 average.
Quick Reply: Oil pump solenoids
