Oil pump solenoids
#1626
Received 3,366 Likes
MY'14 W212 M276 3.5NA @55kMi
self-tuned engine bliss...
Went for a third drive (30 minutes) today to try on settling things out. While I noticed an improvement in throttle response, boost, and steady temps the shifts are still working themselves out. Where I noticed a massive difference was in Comfort. Normally, it’s sluggish AF after my tune. There was never any response until there was loads of throttle applied. Not the case anymore. It’s so much more responsive and the shifts are SMOOTH! I’m planning a transmission fluid change soon so I’m hoping that’ll only make things better.
Thanks to all involved in figuring this out.
Nino
Nino
-- Now wait with time + patience for ECU to enable better "GDI timings"... The idle will sound different and the accelerator will become pressure sensitive with honestly-enriched mixtures for plenty torque at 900.RPM!
-- Such low range may well sounds miningless for raw power but is essential for driveability and predictable 1-2-3-4 shifts.
-- The fuel map and precise timings are a smooth continuum that built on solid balanced base trims. Strong performance is not built on laggy low end.
-- If you don't notice your brake pedal improving with blow-by reduction then check the small check valve on the vaccum pump and/or question your oil not sealing drafty rings.
> Virtuous Rewards include:
Experimenters are faced with a giant smile from all improvements besides the tranny can act confused by too great of changes. It's loaded with mismatched data. While engine is transforming... you get into an interesting situation - A sort of adventure between ECU/TCU agreeing on what to do when for perfect shifts.
Anyway here are things to celebrate with a road trip:
- More power on tap without any lag
- Normally cooled engine bay
- Change into direct GDI power control
- Temperature regulated oil viscosity
- Homogenous performance map across RPM's
- Accelerator violently kicks *** on demand (GDI)
Every extra 1kMi your ECU/TCU roll out more ownership satisfaction... enjoy the recovery journey and your Mercedes travels.
Last edited by CaliBenzDriver; 04-27-2024 at 05:17 PM. Reason: unbelievable but true!
The following 3 users liked this post by CaliBenzDriver:
#1627
Received 2,453 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Here's a pic on my M276 bi-turbo. While the connector is not directly behind the coolant hose, removing or disconnecting the hose will give you easier access.
https://cimg2.ibsrv.net/gimg/www.mbw...5a652776e2.png
W205,
I was under the car today and took a look at the oil pump solenoid. I did not remove aftercooler.
Go under the car, remove the under carriage steel cover and 2 plastic ones for best view and access.
Do you have clear view of your alternator like my car below : I know urs is a 4-matic.....but you can always try
https://cimg7.ibsrv.net/gimg/www.mbw...8f4aa9e3f5.jpg
https://cimg6.ibsrv.net/gimg/www.mbw...9676905b4e.jpg
If you have similar space like above photo, you probably can access the connector like I did today.
https://cimg9.ibsrv.net/gimg/www.mbw...affef0f4ce.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...dc708e2e9f.jpg
https://cimg7.ibsrv.net/gimg/www.mbw...c55e4d01fb.jpg
See above carefully, that grey lock is already UNLOCKED. 2-3mm pop out.
https://cimg8.ibsrv.net/gimg/www.mbw...5b7e5e48be.jpg
No tool, just my fingers.
https://cimg6.ibsrv.net/gimg/www.mbw...3b2c124b70.jpg
My hand access as per red arrow
https://cimg8.ibsrv.net/gimg/www.mbw...059318be68.jpg
The green line is the wire to oil solenoid.
https://cimg3.ibsrv.net/gimg/www.mbw...900e7b6a9a.jpg
Good luck.
Good luck.
What I did was I put the car on ramps and dropped both the splashguards, think that was two weekends ago when I first attempted this.
Last weekend, I figured that I need more clearance for both my tool and arm (especially for rotating my arm and tool), so I used the low profile jack and jacked the centre point then put jack stands on both sides. I never had a chance to put the vehicle on a hoist which might had made it way better, neither I have access to one.
Here is the disappointing news, the underbody of my car looks nothing like this, it is pretty much covered by the sub frame, I confirmed I removed both splash guards, the one hiding the oil pan and the one in front.
I wish I can take a picture to show you what I mean but my camera isn't able to capture it with the little amount of space I have, without putting the vehicle on a hoist. That is despite I am using the ultra wide camera view.
I will try to see if I can get the car higher and take a picture on my next attempt, I really appreciate all these pictures, I will try to look for the alternator this time. I didn't see it last time, at least I really don't think so as the alternator should stand out to me.
I will see if I can remove the steel cover you mentioned maybe that was why I don't see the alternator. What I remembered was, the subframe covered everything and there were no further covers after removing the two plastic splashguards, happy to revisit this again and hopefully I just missed it and can just take off the said steel cover.
I also appreciate the good luck, I desperately needed that.
#1628
Nino
Nino
That is funny : ) and glad things are working out for you.
slobo (04-28-2024)
#1629
Received 1,601 Likes
It is a Stage 2 tune which is supposed to deliver about 420 hp. (The tune is no longer listed on Vivid Racing's site.) There were real drivability issues and Vivid wrote a new tune that worked great, but with less output. I called it Stage 1.5 but I think they called it v.3. After disconnecting the solenoid, I loaded the Stage 2 again just to see if it made any difference. Amazingly, all the drivability issues went away and the more powerful tune works great.
#1630
W212 E63S Wagon - GSL580 - E63 - E350 - C300
That was an easy $25 some odd dollar fix with some Chineese knock off's from AliExpress
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
#1631
Received 4,392 Likes
W205,
If your car has electric power steering protection plate, you must remove that, or else it will block your hand access.
See below item D : Based on my E400 W212
On my car I got total 4 under carriage covers.
From front to rear of the car.
Cover A
Cover B, the heavy metal plate covering forward engine oil pan. You must remove this to work.
Cover C, the Batman Plastic cover, this one from middle of engine to 1/2 of tranny.
Cover D, the power steering protection plate
Let's try again......... Red zone below is where EPS protection steel plate is installed, hence you must first remove it to get to oil solenoid.
In green is oil solenoid wire
This is how my hand access the oil solenoid. I already re-installed my EPS. The blue tape is where EPS 3 connectors are.
EPS installed. RHD car is mine, I think on LHD car the wire connection to EPS would be on the left side of the car and not on the right like mine.
Okey dokey....go and try again.
NOTE : I have a 50cm working height QuickJack, so not too bad for me.
Cover A
juanmor40 (04-28-2024)
#1632
W205,
https://cimg3.ibsrv.net/gimg/www.mbw...9707364213.jpg
Cover A
https://cimg0.ibsrv.net/gimg/www.mbw...afa5dd1699.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...cbc274405a.jpg
https://cimg2.ibsrv.net/gimg/www.mbw...f859aef510.jpg
https://cimg0.ibsrv.net/gimg/www.mbw...239f442d86.jpg
https://cimg6.ibsrv.net/gimg/www.mbw...deb76ea54e.jpg
Cover A
I probably should get a QuickJack as well.
#1633
Can be seen on xentry but does not illuminate cel or cause limp mode.
Try it. However, I suspect it will trigger a cell and put the car in diminished power mode to protect the motor because the ecu can't see it vs it getting in the stuck position and not throwing a code.
I'm of similar mindset as you in that oil pressure under no load is not a bad thing.
The following 2 users liked this post by Krule77:
CaliBenzDriver (04-29-2024),
slobo (04-29-2024)
#1634
I’m really blown away at the difference I’ve seen driving the car in Eco and Comfort modes! As I’ve mentioned before, after my time, those modes were so sluggish! I’m actually content driving in either mode now. Wish I knew about this mod sooner!
The following 3 users liked this post by ninobrn99:
The following 3 users liked this post by OldManAndHisCar:
#1637
Success!
Success! https://cimg7.ibsrv.net/gimg/www.mbw...9ddc677fe9.jpg
This might sound weird but I couldn't be happier to see a stored (DTC, diagnostic trouble code) like this in the ECU and I couldn't had done it without the countless pointers from forum members who helped.
Please allow me to express my greatest gratitude to forum members (order has no significance, you all are awesome!) JettaRed, CaliBenzDriver, S-Prihadi especially they did all this research, experiment on their own personal vehicle for the greater of the MBworld community to benefit them and to potentially prolong engines.
Thank you forum member S-Prihadi for starting the experiment in the first place and posting about it in the other thread back in 2022.
Thank you forum member CaliBenzDriver for all the documentations and explaining everything in depth and answering forum members' questions.
Thank you forum member JettaRed for all the pointers again the pictures, thank you for measuring the oil pressure using a gauge and posting your findings, thank you for the useful tools listed with the links, the steps and especially going under the car again and again to help clarify everything in great depth.
Thank you to all of them for taking high quality pictures, lots of encouragement, thank you so much for all the patience you all had with me on this challenge of unplugging this connector with the broken sliding lock, lots of recommendations, videos showing in detail the proper way to unplug.
Thank you those who posted YouTube videos with impressions, tutorials and other pointers.
Thank you OP for making this thread the longest thread on mbworld along with others I forgot names but contributed dearly to this project.
Thank you as well to forum member ninobrn99 for suggesting different things to try!
I really can't thank all of you enough.
Initial very positive impressions, this transformed my car:
Transmission is way smoother (this is despite how this transmission was very smooth ever since the forced adaptation performed by the dealership back in 2019 and ATF was performed in 2023).
On heavier throttle (but not WOT) lag is reduced to minimal and even none as the transmission downshifts several gears without jerking at all followed by RPM climbing.
The gas pedal as everyone mentioned is much firmer and the vehicle responds much quicker at low RPMs in both Comfort and even Eco which the latter I rarely use.
The vehicle is no longer a garage heater.
The oil temperature raises much quicker, the engine idles much smoother. The idle noise is greatly reduced.
Vehicle doesn't need to crank for more than half a second and starts up. While as before it cranks for 1 second or even 1.5, close to 2 seconds.
This wasn't mentioned but I wonder if it is a placebo as it sounds like the exhaust got louder too. There also seems to be more burbles.
Last and certainly not least, I am sure the other benefits like better oiling and better protection for the engine that everyone also experienced applies as well.
Time to answer the survey in the OP : )
All the best to those who are planning to unplug it as well!
The following 5 users liked this post by W205C43PFL:
CaliBenzDriver (04-30-2024),
JettaRed (04-30-2024),
juanmor40 (04-30-2024),
ninobrn99 (04-30-2024),
S-Prihadi (05-01-2024)
#1638
For sure for sure!
#1639
Glad to hear you finally had success! I think you’ll notice it more once you drive it casually and aren’t hyper focused on what immediate changes you notice. You’ll just realize it bit by bit how things are just different.
#1640
#1641
So seems like the general consensus is any m278 and m157 needs this mod!
OldManAndHisCar (05-03-2024)
#1642
Actually, there are several "mods" discussed here, including disconnecting the oil pump solenoid and changing oil viscosity weights. But, yeah, the consensus is to make these changes, but not just on the M278 and M157. The M276, both turbo and NA, benefit, as well. Any Mercedes engine with the two-stage oil pump should convert to a single-stage pump.
Rickman30 (05-03-2024)
#1643
#1644
#1645
juanmor40 (05-05-2024)
#1646
- secondary chain TENSIONERS,
- leaky CPS,
- plugs + coils/boots.
- HPFP + rollers around 80-100kMi.
- Vacuum pump small check valve.
- (Thermostats: coolant+oil)
- plastic coolant hoses...
#1647
#1650
The list I quoted contains items that most certainly do not affect oil pressure.
