The Life and Journey of a 2023 Mercedes-AMG E63 S Wagon
Old Jul 22, 2025 | 09:52 PM
  #651
W205C43PFL's Avatar
Here is the door module drain issue on the newer models:
https://mbworld.org/forums/new-membe...ml#post9118476
https://mbworld.org/forums/new-membe...ml#post9118472
Once this update is installed, no more trickle charger needed. Problem is, don't think it affects the W213.
Old Jul 27, 2025 | 10:35 PM
  #652
I.T. Guy's Avatar
2023 E63S Wagon
Now that it’s been “topped up” if I don’t charge it for a few days then throw it on the charger it only takes a couple hours to be topped up again, not a long time at all.
Old Jul 27, 2025 | 10:41 PM
  #653
I.T. Guy's Avatar
2023 E63S Wagon
The lowrider life has done its thing and worn the inside fronts to the cords.
Even with the Cete raising to stock at 90 kph the front tires are done.
57,000 kms with half on snows = 23,500 kms, that’s only 15k miles.
Oof!
Rears still look ok.
I stopped lowering to try and stretch these to fall. That’s a lot of tire $$ just to look a bit cooler when parked…
Old Jul 27, 2025 | 11:45 PM
  #654
W205C43PFL's Avatar
nice.
Old Jul 28, 2025 | 02:33 AM
  #655
PeterUbers's Avatar
Oof!
this is commensurate with other peoples experiences without the cete module - just the unfortunate wheel geometry of the w213 amg (and 212)
https://mbworld.org/forums/w213-amg/...ber-bolts.html
consider these tires next (ps s5 mo1):
https://mbworld.org/forums/w213-amg/...rt-s5-mo1.html
Old Jul 28, 2025 | 04:12 AM
  #656
bobblehead's Avatar
go fast grocery getter wagon
You need to replace them now, not later. Given we are in the midst of very hot weather, you sure don’t want a blow out.
Old Jul 28, 2025 | 09:27 AM
  #657
I.T. Guy's Avatar
2023 E63S Wagon
I know you are right.
Old Jul 28, 2025 | 09:28 AM
  #658
I.T. Guy's Avatar
2023 E63S Wagon
Wow what a 1st thread there. I thought it was "my fault" but looks like many stock cars experience the same wear.
Dang
Thank you
Old Jul 28, 2025 | 10:34 AM
  #659
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
The only fix is to modify the suspension to allow greater adjustment, either arms or offset bushings. BTW, adding offset just makes it worse, making mods even more important.
Old Jul 28, 2025 | 05:39 PM
  #660
bobblehead's Avatar
Dang
Thank you
my blow out experience is on that link too.
check your rear as well. At least check them once a month while the summer set is on.
Old Jul 29, 2025 | 04:38 AM
  #661
W205C43PFL's Avatar
Truly scary stuff, safety first for sure.
Old Jul 29, 2025 | 10:08 AM
  #662
zukmeister's Avatar
2023 E63S AMG - Grey Magno
Nice - looks like I found my new tires. I have 8k miles on stock set and the inside of the front wheels is definitely wearing unevenly. Thinking I'll get through the summer and these may need replaced next year
Old Jul 29, 2025 | 11:08 AM
  #663
I.T. Guy's Avatar
2023 E63S Wagon
Been there done that 2x in the 212 but thought it was from KW lowering springs. I had hope the Cete raising to stock height at speed would help.
I guess these cars just eat tires.
Summer
Summer
Winter
Winter
Old Jul 29, 2025 | 11:38 AM
  #664
zukmeister's Avatar
Summer
Summer
Winter
Winter
When that happened twice, did you destroy the wheel or were you lucky?
Old Jul 29, 2025 | 12:00 PM
  #665
I.T. Guy's Avatar
2023 E63S Wagon
Lucky
The winter one we were going 100kph in the left lane heavy traffic with the kids in the car full trunk on the way to the lake. The warning systems worked and I watched the pressure PSI bleed down from yellow to red as I scooted over slowing down as it approached zero. There was an offramp right there so I decided to sacrifice the rim and drive 1/4 mile to a Wendy's parking lot and safety. I went slow and rim was fine.
The summer one I was alone in the city diving slow and got to pull over right away and put the spare on.
I hate the 213 don't have a place for a spare. I have a euro spare tire, rim, bag, and tie down but leave it in the basement. Keeping it in the car makes the rear annoyingly unusable for how we live ife.
Old Jul 31, 2025 | 07:36 PM
  #666
Drone_S213's Avatar
Veteran: Air Force
2021 AMG E63s Wagon
Miss my 2021 AMG Wagon but got tired of gremlins at age 64. Just sold TSLA stock and bought a 2025 GR Corolla 6-stick. Besides my 2024 AWD Maverick 2.0T greatest purchase ever! Once I saw Jay Leno and Johnny Lieberman from Motor Trend review GRolla on YT Leno’s Garage mind was made up. Keep the backseat folded down in the hatchback for wagon vibes…lol
Hit push to start button and everything works as Engineered. They only make 49 a day at same Japanese plant that made the Iconic Lexus LFA by seasoned Toyota Specialists akin to AMG Engine Builders. I recommend @I.T. Guy buy one for your Son so you can drive it to work!
Still own 2015 Chevy SS 6-stick but my Ducati is now For Sale!
Old Aug 2, 2025 | 12:19 PM
  #667
I.T. Guy's Avatar
2023 E63S Wagon
Since the car needs front tires I'm down a wheel and tire rabbit hole. So when I read @Drone_S213 post the only thing that jumped out at me was "49" because that's a good rear offset for rear rims! :P
What I've decided so far
1) Must keep using 30 or 35 series tires. 25 aspect ratio is out.
2) Maximum meat. I want to stuff the largest tires possible Front and Rear. I think that is 285 front and 315 rear. Has anyone done 295 front?
3) Do not want front spacers.
4) The new Pilot Sport S5 M01 while nifty is not available in non OEM sizes, so that's out.
5) Still be able to lower (so no 325 rear like one member has done)
What I haven't decided:
Upgrade to 21" or stay 20".
If I do new wheels they should be 21" or why bother. But will they be too large with the 30 aspect ratio tires?
Front 10" wide ET 10ish
and Rear 11" ET 50ish
This is where I get stuck
Tire sizes
From the wonderful After Market Wheel thread I see 285 and 315 will fit no issues in 20 or 21"
I *think* 20" looks a bit small and 21" looks perfect when using 305's in the rear. But I want 315.
I *think* 315 looks a bit chunky in the rear on 21's - a bit too tall for the wheel well, so do I go to 305?
What I don't know is what 315's on 20" wheels looks like on the E63.
Old Aug 2, 2025 | 12:42 PM
  #668
I.T. Guy's Avatar
2023 E63S Wagon
Math Check
And just to prove I'm crazy and all over the map I'm contemplating keeping the stock wheels and making them OEM++. I've used weldcraft wheels in the past on other projects so did some maths and believe adding 1" to the inside of a stock rear wheel and using a 15mm spacer will work perfectly, turning it into a 11" wheel. Voila, 315's. The front 9.5" wheel can take a 285 tire so there is that too. Unsure if front will need spacers to clear internal suspension stuff.
I have done the math but am not posting the answer to avoid confirmation bias. Anyone want to check this?
On a 254mm wide wheel the centerline is 127mm
The ET is +55 (55mm from the centerline towards the front/outside)
Add 25.4mm material to the rear/inside barrel, moving the rear back 25.4mm
Now you have a ~280mm wide wheel, with the centerline at 140mm
What is the new ET?
And to keep it simple both trains leave the station at the same time.
Old Aug 2, 2025 | 01:07 PM
  #669
I.T. Guy's Avatar
2023 E63S Wagon
PS I asked A.I. and it was "wrong" and I had to question it back 3 times until it got my answer.
We are doomed either way
1) I'm wrong but IA just gave into my pressure and caved or
2) I'm right and can never trust AI unless I argue with it
IT'S MATH how can a giant calculator be getting addition and subtraction wrong?!
LOLZ
Old Aug 2, 2025 | 04:15 PM
  #670
I use AI nearly every day and I've learned to never trust it for anything. It may be OK to write an email, but anything technical should be taken with a grain of salt (if that much).
Old Aug 3, 2025 | 09:10 PM
  #671
I.T. Guy's Avatar
2023 E63S Wagon
Here's my latest crazy idea for the front wheels.
A 10.5" ET22 wheel puts the outside of the wheel and tire at the exact same place all the "known" setups using 10" rims and ET10 are running at, which is the same as my stock wheel with 15mm spacer. So we know the outside will work.
The 10.5" ET22 wheel puts the inside of the wheel and 9cm inward from what the stock 9.5" ET25 setup is.
I guess I need to measure some stuff and see if the car can clear another 1cm inboard from stock.
Old Aug 4, 2025 | 02:34 PM
  #672
wildta's Avatar
GLE 580
LOLZ
Which AI did you ask? I will sometimes ask both ChatGPT and Gemini to see how they compare.
Old Aug 5, 2025 | 05:31 PM
  #673
I.T. Guy's Avatar
2023 E63S Wagon
Copilot! lol
Old Aug 5, 2025 | 05:36 PM
  #674
I.T. Guy's Avatar
2023 E63S Wagon
I rolled around on my back around the front wheel with a 2 foot long 1" dowel
By feel laying the dowel across the the back of the 9.5" wheel all round and trying to wedge it into places. It seems like there is only one spot near the top of the wheel where the 1" dowel fits in then only has 1/8" wiggle room to/from sitting flush on the wheel/tire. So it appears perhpas a 10.5" front wheel is possible! I will still want to use a lift and proper straight edge and test steering from lock to lock, but this is very encouraging!
Old Aug 5, 2025 | 06:31 PM
  #675
PeterUbers's Avatar
static vs dynamic tolerances - had success with a stationary setup only to have rub at speed with bumps and road contours ... hopefully it works out for you; I see in the other thread you've worked through all this geometry significantly
