The Life and Journey of a 2023 Mercedes-AMG E63 S Wagon
Old Aug 6, 2025 | 09:21 AM
  #676
I.T. Guy's Avatar
2023 E63S Wagon
static vs dynamic tolerances - had success with a stationary setup only to have rub at speed with bumps and road contours ... hopefully it works out for you; I see in the other thread you've worked through all this geometry significantly
I'm still afraid.
Old Aug 6, 2025 | 10:51 AM
  #677
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
It could be a victory or a expensive experiment.
Old Aug 7, 2025 | 05:09 PM
  #678
I.T. Guy's Avatar
2023 E63S Wagon
Tire and Wheel rabbit hole
I like the squared off look so that means:
11" rim (bead to bead) = 12" overwall width x 25.4mm = 305 optimal tire size
This means I will probably not go with a 315, and explains why everyone goes with 305 as it's optimal for an 11" rim.
9.5" (bead to bead) = 10.5" overall x 25.4mm = 267 so rounding to a 265 optimal tire size. The factory nailed this one.
10" wheel = 11" overall x 25.4 = 279 rounding up or down you get 275 or 285 optimal tire size, explains why everyone goes with those on the front with a 10" wheel. But I dont' like the scrub radius of this combo - it's squirly at ET 10 and too sunk in ET 25/30.
So...
If 10.5" wheel fits up front then that's perfect for a 295, and srub radius gos inwards back to almost stock location.
If 10.25" wheel fits up front then 285 will work, and again scrub radius goes back inward almost to stock location.
Rear at 11" = 305. Or 315 with a tiny bulge. Hmm.
After that's decided, 30 or 35 series? Argh, more pics and youtubes to watch!!!
Old Aug 7, 2025 | 05:33 PM
  #679
PeterUbers's Avatar
I like the squard off look so that means:
So...
30 and you're closer to the BRC.... (bent rims club)
Old Aug 7, 2025 | 07:02 PM
  #680
I.T. Guy's Avatar
2023 E63S Wagon
but I can move the 295/30 rears to the front and be cheap, er, frugal lol
Old Aug 7, 2025 | 09:06 PM
  #681
PeterUbers's Avatar
I always wonder if the weight of the engine over the front wheels makes the front wheels more prone to cracking or bending…as well as the fact that they plow into the deviation in the road versus being dragged over it like the back wheels.
but I hear ya
Old Aug 9, 2025 | 02:54 PM
  #682
I.T. Guy's Avatar
2023 E63S Wagon
The cords are really showing on the fronts, I don't think there is more time to dink around. So for now I'm getting 285/35 and 305/35 on stock rims. Yeah yeah go ahead and fill the thread with "bulge" and "sidewall danger" and "skating" and all that. I get it, it's just kinda a 1-2 month test before winter to get a handle on the look. If I like the added height of the 35 series tires I can fix the rim widths over winter.
I also ordered a cheap replika 10.5" wheel with ET40 to play with spacers on the front for tires V2.0. Crawling around under the car more today with a straight edge it looks like it just might work!
Old Aug 9, 2025 | 05:55 PM
  #683
bobblehead's Avatar
go fast grocery getter wagon
Extremely hot weather will raise even more risks on those old worn tires
Old Aug 9, 2025 | 06:06 PM
  #684
I.T. Guy's Avatar
2023 E63S Wagon
+1
Luckily I have an extra car to drive until Sept so the wagon has been parked. Hopefully new tires and alignment this week. Too much mental gymnastics over one small thing, and will probably come to the same conclusion in the end as everyone else regarding width and offset. Haha.
Old Aug 12, 2025 | 11:07 AM
  #685
SM105K's Avatar
2019 E63S and 2014 CLS 63S
I did the opposite with the factory wheels lol. I took the factory 10 spoke off, and after 9 months of searching found a set of pretty mint OEM black forged wheels.
What is crazy is, I like your wagon with the ten spoke wheels better. However, on my sedan I like the black forged wheels better. It is so weird because both of our cars are silver. LOL.
Old Aug 12, 2025 | 10:48 PM
  #686
I.T. Guy's Avatar
2023 E63S Wagon
Wheel mock up
(Cheapie for measuring with different spacers)
I think this is enough space… suppose it’s time to try a couple tires sizes on and drive around!
20x10.5 ET25 (15mm spacer on ET40 Wherl)
20x10.5 ET25 (15mm spacer on ET40 Wheel)
1mm or 1m, clear is clear, right?
Can always use a larger spacer to give 1-2-3 more mm if needed
Can always use a larger spacer to give 1-2-3 more mm if needed.
Lots of height for rubber
Fender poke looks same as current stock wheel setup below
20x9.5 ET 10 (stock ET 25 with 15mm spacer)
Current 20x9.5 ET10 (stock ET25 with 15mm spacer)
Old Aug 13, 2025 | 03:09 PM
  #687
natesamg's Avatar
2020 E53 AMG Sedan
Finally ordered the spare tire and picked it up today https://mbworld.org/forums/w213-amg/...ml#post8995775
i don't see any of that part number for sale anywhere. do you know if A2304012702 would fit the E53/E63? it's 6.5Bx19 ET14
Old Aug 13, 2025 | 05:43 PM
  #688
I.T. Guy's Avatar
2023 E63S Wagon
That part number is for a W212 spare. You will need different lug bolts for sure; the stock ones will not work with that spare.
I regret not trying the 212 sapre on the 213. That 212 spare is amazing how it collapses when it deflates. Real space saver.
Someone with a 212 needs to try the spare on a 213 please - just make sure not to mess up your hub using 213 logs that will be way too long for threading in (212 wheel faces are a lot thinner).
Old Aug 21, 2025 | 10:48 AM
  #689
I.T. Guy's Avatar
2023 E63S Wagon
Purge valve ticking fixed today in warranty:
W213 E63S Ticking Noise - Fixed - MBWorld.org Forums
Old Aug 21, 2025 | 12:31 PM
  #690
I.T. Guy's Avatar
2023 E63S Wagon
305/35 and 285/35 tires fitted to stock rims:
305 section width rear tires on OEM wheels - MBWorld.org Forums
Old Aug 21, 2025 | 04:42 PM
  #691
figuwx's Avatar
2018 AMG E63s Ed1
but I hear ya
More than likely yes as that is why MB has the pressures high on the front tires... even without top speed runs. you are looking at the 41 PSI for the front and 35 for rears.
Old Aug 21, 2025 | 11:03 PM
  #692
W205C43PFL's Avatar
but I hear ya
Which is strange because I heard bmw has the rear pressures higher than the front, despite being the same front engine layout.
Old Aug 27, 2025 | 12:30 PM
  #693
I.T. Guy's Avatar
2023 E63S Wagon
305 / 285 tires update
Originally the dealer said they could not fit the rear tires without using the 12.5mm spacers.
I did not like the look and also experienced some rubbing on the outside of the tires on suspension compression during large dips.
I was able to remove the rear spacers and the tires fit fine.
The original plan was to widen the wheels over winter 11” rear and 10.25” front but that would necessitate running 15mm spacers front and rear. I’m kind of liking the no-spacer life and think I can see past the poor non-flush fitment with some lowering.
So far it’s lowered to -25mm front and -15mm rear and zero rubbing. I will play with the heights to nail the look.
Here are some pics with rear spacers at stock height:
12mm spacer stock height
And here are some pics no spacers and lowered:
Front -25mm Rear -15mm no spacers
Rear maybe needs more lowering
Old Aug 27, 2025 | 05:50 PM
  #694
I.T. Guy's Avatar
2023 E63S Wagon
I think I’ve settled on
-30mm / -25mm F/R
IMHO these cars look so much better with 28” diameter vs 26” roller skates.
Old Aug 28, 2025 | 12:07 PM
  #695
SM105K's Avatar
Looks great bud.
Old Aug 28, 2025 | 02:46 PM
  #696
PeterUbers's Avatar
Looks good. This has been owning your mind for a bit, glad to see you able to release from it with satisfaction 😊
I think these cars' aesthetics as it relates to the tires change in terms of how they appeal to us based on a couple things:
- color of the car, darker colors seem to allow for different types of tires in terms of aesthetic appeal
- the rim itself, the design first, then the size
- offset seems to go hand-in-hand with the design of the rim
- the drop and camber associated with the drop.
$0.02
Old Aug 28, 2025 | 09:07 PM
  #697
I.T. Guy's Avatar
2023 E63S Wagon
^^ yes
In a perfect world for my taste I’d love 5-7mm more rear aggressive offset and 15-18mm front.
I just don’t want to mess with scrub radius and spacers or aftermarket looking wheels so this is the compromise.
Since the wheels are centered again like MB engineers designed all the WOT is buttery smooth, no skittish squirming and darting. Everything is perfect again. Except the fitment
Old Aug 31, 2025 | 09:58 PM
  #698
I.T. Guy's Avatar
2023 E63S Wagon
Last one is off to University!
Cant even tell it’s moving a whole life back there. What a machine!
Now you see it,
Now you see it,
Now you don’t!
Now you don’t!
Old Aug 31, 2025 | 11:42 PM
  #699
PeterUbers's Avatar
Now you see it,
Now you see it,
Now you don’t!
Now you don’t!
coolest dad at university drop off.
"hey man, which wallet [wagon] is your dad's?"
"the one that says bad *****----- on it!"
Old Sep 1, 2025 | 06:10 AM
  #700
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I have heard that....and I don't have kids (wife does)
Oh, congrats on the VERY hard job of creating adults.
