Old 06-10-2015, 01:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
DIY and How to Guides for w204 All Together
Rating: Thread Rating: 14 votes, 4.57 average.
Old 04-01-2013, 10:59 PM
  #176
ottomerc's Avatar
C220 CDI
Brake pad - rotor change
Hi, great list of links thanks, does anyone have a link for changing all pads & rotors on a C220 W204? Are there any difficulties involved in the process? Any help is appreciated, as my first time doing this diy on this car.
Old 04-04-2013, 06:42 AM
  #177
tpdietz's Avatar
2008 c300 sport 4matic
Originally Posted by 430752
Okay, so I feel like I should use tampons to ask how to change the sparkplugs on a w204 c300. I've changed dozens in my life. But, in bringing my ride in for its A service at 100K mile tuneup, they quoted me $352 to change sparkplugs. Yes, friggin plugs, 6 of them, for $350. So, unless the dealer is beyond a complete racket, and into criminally insane territory, there has to be something more to changing these out, right? Or is this the price of a 3 pointed star on your hood? I'd guess pop the plastic tupperware engine topper, disconnect the battery, unplug the plug wires and have a go at the plugs, 3 per bank. Dunno the torque to use, maybe the parts guy at the counter would offer?
Also, dealer gave $149 for the engine intake filters. WTF?
Anyway, next up is a check engine light the ***** threw about a month or month and a half ago. I figured it was a thermostat by the way the temp gauge got nervous in the days afterwards. Luckily, it was February in Jersey so little chance of any damage. But now with the weather increasing...... Dealer confirmed it was a thermostat when I brought it in but won't tell me the OBD code. Not sure if Mercedes parses out their codes well enough to tell the location if I could get the code? Anyway, does anyone know where the thermostats are on these things. I reckon like most others there'd be one at the radiator and one at the engine block? But, I've never wrenched on German cars before. Only Swedish, Jap and Amerikan cars. Any tricks to a mercedes thermostat?
much thanks for any help
-C
Spark plugs, cabin filter, and air filter are all
No-brainer DIY projects. There are videos for both spark plugs and cabin filter on YouTube. The video for the spark plugs is by a channel called BenzWerks (I believe) and he does two different engines in one video - one being the m272. Very easy. Torque should be 17-18nm. I have the exact measurement in my computer and will post when I get home later.
If you can change spark plugs, the engine air filter doesn't need much explanation. Pull the engine cover off. Wiggle the two big air hoses free, wiggle a small rubber hose free near the center of the air box. Flip over and remove 6 torx screws in each side to access the filter housing.
Good luck
Old 05-13-2013, 11:42 AM
  #178
ITWORKS's Avatar
2009 C300
Here's my contribution. Water leak from sunroof...
https://mbworld.org/forums/c-class-w...ns-w-pics.html
Old 05-27-2013, 12:58 PM
  #179
VargaNorbert's Avatar
skoda fabia
DIY rear bumper removal and parking sensor installation
here's my contribution.
Mercedes C200 2012 Rear bumper removal and Parking sensor installation
Hope this helps.
Old 06-19-2013, 06:23 PM
  #180
natemetro's Avatar
2012 C250
Originally Posted by RavenMDX
Can somebody post a guide and pics on how to remove the side mirror covers on a W204?
I found a guide in this DYI on how to remove the side mirrors (thanks!) but now I need to know how to remove the side mirror covers. I am replacing the covers with the 2010+ models (only the outer plastic part)
as shown here
http://www.ebay.ca/itm/190517128593
Thanks alot
Hello all. New to my MB and new to the forum.
Any luck on this topic? I also saw someone asking about replacing the down facing courtesy lights on the side mirrors. Ultimately this is my goal.
Thank you in advance!
Old 07-09-2013, 09:20 PM
  #181
wabs2013's Avatar
c350 4MATIC
im looking into buying an X-pipe from Mandrel Bending Solutions and since its a custom order part they require me to provide them with all the dimensions. I've seen others members who have gotten their X-pipes from MBS but no one has posted dimensions. can anyone help me out?
Old 09-03-2013, 06:58 PM
  #182
joespeed29's Avatar
2013 C300 Sport
Don't hold your breath waiting for a response. I'll look into this
Old 09-17-2013, 01:37 PM
  #183
adavidyan24's Avatar
2013 MERCEDES BENZ C250
VERY NICE CAR
Old 09-18-2013, 06:05 AM
  #184
vic viper's Avatar
S213
Hope this helps.
http://youtu.be/QSVDMW94G7A
This is somewhat inaccurate, you do not need to loosen the nuts under the rear lights, just snap out the bumper from the brackets below the lights.
And to remove the two center nuts just use this tool:
Old 11-02-2013, 11:23 AM
  #185
black lavender's Avatar
R8, C63, C300
Credit to aMsupp
Better tail light removal with pictures
https://mbworld.org/forums/c-class-w...il-lights.html
Helped me a ton
Old 11-20-2013, 01:09 PM
  #186
IGB
IGB's Avatar
'08 C300 MM Pano
DIY on How To Remove a Sun-Visor Clip for Access to an Easy 12 Volt Power Source
Old 11-26-2013, 04:04 PM
  #187
Peabody's Avatar
I thought I posted a guide to do this back in 2010.. let me look it up.
Originally Posted by Peabody
Pop off the tweeter and remove the sound insulation to reveal three star bolts. Unscrew these bolts and pull the door cover for the side-view mirror off, revealing the wire channel.
From the inside to outside, run a cable tie into the channel. Tape wire to the cable tie, and pull it back through. Replace the side-view mirror cover.
Unplug the (6) connector and lift the clip to slide off the connector lock.
Use a small flathead to push these pins in and back, so you can solder into the wire connector.
Tin the ends of the connector wires and the connectors using a very small amount of solder.
Hold the ends together and apply heat from the soldering iron to solder wire onto connector.
Push the pins forward again, and slide the connector lock back on.
Run it in reverse to reassemble.
I fail, someone tell me how to resize images in the post.
There's a photo album here: http://imgur.com/a/q988z#9ctSK
Old 12-30-2013, 03:25 PM
  #188
jackolee's Avatar
C300
I did a search but couldn't find anything, but does anyone know how to remove the fender? I need to know the location of all the bolts. Thanks
Old 01-21-2014, 03:47 PM
  #189
MBSebas87's Avatar
C300 Sport 4Matic
Any DIY for installing a new diffuser?
Old 02-02-2014, 06:14 PM
  #190
luc1f3r's Avatar
C300
Can someone point me in the direction for a guide on removing the sunroof controls? Need to hardwire my radar detector.
Old 02-02-2014, 09:55 PM
  #191
bostongreg's Avatar
MB '12 C250 Sport
super helpful-thank you!!!
Old 03-26-2014, 11:27 PM
  #192
mbpharoh's Avatar
07 Acura Tsx, 2009 C300 L
https://mbworld.org/forums/c-class-w...t-install.html
created by me for remote start
Old 05-05-2014, 10:52 AM
  #193
romeo291's Avatar
W204
Here's a DIY I wrote up, it's a DIY for Sideskirts removal and Puddle Lights install.
http://www.flawlessfitment.com/2014/...edes-c300.html
Old 05-09-2014, 03:37 PM
  #194
aznmode's Avatar
2010 c300
Wrote a DIY for steering wheel swap from Pre FL to FL steering wheel.
https://mbworld.org/forums/c-class-w...heel-swap.html
Old 05-12-2014, 03:27 PM
  #195
cbrea97's Avatar
'09 C300 4matic (w204)
diy for voltage regulator and bosch part no.? please and thank you.
Old 06-01-2014, 02:52 AM
  #196
wxm803's Avatar
2008 c280
Hi guys, I'm new on the site. Please help me. I own a 2008 c280 and have a problem with my horn that went dead any possible problem that I can look at?
Old 06-09-2014, 10:05 PM
  #197
istue's Avatar
w204
thanks for the info
Old 06-20-2014, 08:44 PM
  #198
C250INLA's Avatar
2017 corvette stingray. 2013 C250 Sport. 04 Volvo XC90
Originally Posted by kHuNkHuNa
Heres my attempt at making a DIY guide for side markers, hopefully this helps,
I wouldn't mind suggestions either of what i could have done better
https://mbworld.org/forums/c-class-w...ml#post5130919
The video wouldn't play for me. I got a 'Video is private' message when I tried to play.
However, I found this one which looks very similar :
Old 07-15-2014, 07:56 AM
  #199
DJ BIS's Avatar
2009 Manual C300 Sport
This is awesome
Subscribing for updates. Thank you for the info!
Originally Posted by Robbio204
Here is a list of all the DIYs I could find in the w204 section of the site. Sometimes the search is tricky and does not return the results one might be looking for. Many of these have been helpful in my experience. I did not make any of these, just put them together so they are easy to find on the forum. Thanks to those who took the time to make them.
Online Owner's Manual
(Learn to change bulbs, batteries, other troubleshooting help)
http://www4.mercedes-benz.com/e/cars...d13e42004.html
Syramg's Grill Removal PDF (on post 153)
https://mbworld.org/forums/c-class-w...ections-7.html
License Plate / Number Light Removal Guide
https://mbworld.org/forums/c-class-w...te-lights.html
Tail Lights
https://mbworld.org/forums/c-class-w...moval-diy.html
Interior Light Removal
https://mbworld.org/forums/c-class-w...t-removal.html
Eyelids / Daytime Running Lights
https://mbworld.org/forums/c-class-w...elids-tb5.html
DIY for HID fogs
https://mbworld.org/forums/c-class-w...g-hid-kit.html
Glove Box Removal
https://mbworld.org/forums/c-class-w...glove-box.html
ECU Removal
https://mbworld.org/forums/c-class-w...oval-pics.html
Heater Blower Intake
https://mbworld.org/forums/c-class-w...heater-blower-
intake-battery.html
SmartKey Battery Replacement
https://mbworld.org/forums/c-class-w...placement.html
Rear Camera Installation
https://mbworld.org/forums/c-class-w...-location.html
https://mbworld.org/forums/c-class-w...d-cyclops.html
https://mbworld.org/forums/c-class-w...der-200-a.html
Oil Change
https://mbworld.org/forums/c-class-w...-pictures.html
Door Sill Instructions
https://mbworld.org/forums/c-class-w...sills-diy.html
Lowering Springs Guide
https://mbworld.org/forums/c-class-w...g-springs.html
Grill Painting Guide
https://mbworld.org/forums/c-class-w...ing-grill.html
K&N Air Filter
https://mbworld.org/forums/c-class-w...tallation.html
Engine Cover Removal
If I left any out, sorry, just post it. Thanks again to those who made them.
Old 08-17-2014, 12:45 AM
  #200
huy801's Avatar
w204
Anyone have a diy for replacing the brake booster vacuum pump, pn 2722300565, which sits between the engine and the firewall on the driver side?
You have already rated this thread Rating: Thread Rating: 14 votes, 4.57 average.
Quick Reply: DIY and How to Guides for w204 All Together
