Hyper-White & LED License Plate Lights thread
Old Jun 12, 2002 | 11:43 AM
PoonerElRay's Avatar
2017 GLA 250 4Matic
I'm in the process of replacing the stock bulbs with "super white" or "blue" bulbs to match my Capri Blue exterior.
It's damn frustrating because nobody carries the size that MB uses.
Any advice?
Old Jun 12, 2002 | 12:09 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
same problem here... I can't find the right wattage for the interior lights. If you hear anything, let me know too.
Old Jun 12, 2002 | 03:21 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
i was board one day so i was also thinking of getting different interior lights i wanted something with a tint of blue. i did not see any ones that i could buy to fit this car so i took out the bulbs in the front and the rear u know the lights that light up when u open the doors at night. well anyway i took a permanent blue marker and i colored the whole bulb blub, i waited for it to dry and put it in and it looked great. i did the same on the one in the back seat 2. if u dont want it to be that blue dont color theh whole bulb. u will see it actually comes out pretty good. i gave it a try if i did not like it once its hot u can usually wipe it off. or the worst thing i go to the dealer and buy new bulbs. i know its a kinda ghetto way of gettin blue bulds but it looks good and no one can tell the difference.
Old Jun 12, 2002 | 04:10 PM
2017 GLA 250 4Matic
That's a really clever way of doing it. Do you have photos of what they look?
Did you do that to all 3 bulbs in the front (the map light and the two side reading lamps)?
I was thinking of doing the license plate light too.
Post the pics please
Old Jun 12, 2002 | 04:26 PM
Fast Cars!
no i left the map lights as is. i just did the one big one in the front and the one in the back seat. i will try to take pics now.
Old Jun 12, 2002 | 04:39 PM
Fast Cars!
well i just took pictures but they are terrible u cant even tell there blue. i suggest u just try it i am sure u will like it.
here is a pic but u cant even really tell its blue in person its very blue and it looks cool even out of the car.
Old Jun 12, 2002 | 04:52 PM
2017 GLA 250 4Matic
I just found where to get these colored bulbs that fit the MB. Check out canadiantire.com and euro-tails.com
By the way, did you have a problem with the fit of your clear side markers?
Old Jun 12, 2002 | 05:00 PM
Fast Cars!
yes i did have a problem with the fit of the side markers as well as alot of other people here i ordered 2 sets and both fit terrible but i was able to fit it with so 2 sided tape in some of the important spots so now it fits fine there nice a snug for now. but before that they were almost hanging off the car.
Old Jun 12, 2002 | 05:34 PM
2017 GLA 250 4Matic
A while back some guy posted a message saying his fit fine after he heated up the clips on the side markers to make them extend out for a tighter fit. I wonder if you know what tool he used to heat up the plastic.
By the way, ALL members welcome to check out my new pics in the member's gallery.
Old Jun 12, 2002 | 05:47 PM
Fast Cars!
no i am not sure what tool i think the store did it for him.
Old Jun 12, 2002 | 11:37 PM
2017 GLA 250 4Matic
Today I put in a pair of PIAA Xtreme White wedge bulbs to replace the interior reading bulbs. Man it looks wicked! I took a pic of the upgrade compared with the stock bulb. What a difference. The stock bulb produces an ugly yellow light while the PIAA's are super white with a tint of blue. Awesome!
Becareful when replacing the reading bulbs. You don't pry the lens open like the big fat map light, you need to remove the entire housing and replace the bulbs from above.
I learned the hard way, I didn't know at first and I almost pryed the plastic housing to death. Good thing I was gentle but there's some damage marks on it, but I used super fine sandpaper and water and sanded the plastic smooth so you can't tell I messed with it. I bet that housing is "expensive". It's made by Hella.
The problem is PIAA doesn't make the bulb for the map light nor the rear light, so I'd have to get those elsewhere and I'd run the risk of having unmatching colored interior lights!
What I plan to do is to check out those hardcore import car shops in my area hoping to find a matching set of wedge and dome bulbs. If not, I'll do what you did and paint them blue with a felt marker.
One more thing, I just ordered a MB sunshade for the C230. It's expensive ($US 52.00).
Old Jun 13, 2002 | 12:38 AM
604_kpEscoba's Avatar
c240
how do u pry those lights open i kinda tried seems pretty difficut without breaking...
Old Jun 13, 2002 | 01:45 AM
2017 GLA 250 4Matic
There are 4 lights in the interior cabin:
1 map light using a 1 5/8" 10W bulb (front)
2 reading lights using wedge 5W bulb each (front)
1 rear light using a 1 1/2" 10W bulb (rear)
The map light lens and the rear light lens are removed by sticking a coin or a flat-head drvier and "prying" the lens apart from the housing unit.
The 2 reading lights "cannot" be pryed. The bulbs are housed deep inside the entire light unit. This light unit can be removed from the ceiling of your car by pulling on the white tabs located underneath the map light lens. See the instruction manual on how to do this. It's explained in the part about manually opening the sunroof.
If you need assistance and I'll tell you over the phone or something since you're from Vancouver as well.
Old Jun 13, 2002 | 06:40 AM
c240
gee thanks
i am still a lil bizzy to go work on mycar at the momment
but when i do ill pm u thx
i removed the rear light with ease
but the front lights appear harder
to take out n e wayz ttyl
Old Jun 26, 2002 | 07:27 PM
2017 GLA 250 4Matic
preyx: What was the brand of bulbs u used for the plate light?
were they exactly the same size as the stocks or a lil bit smaller?
Old Jun 27, 2002 | 02:20 AM
preyx's Avatar
'02 C230K Coupe
The were about 1-2mm shorter. I posted a similar reply in the clear corner topic.
The stock bulbs fit snugly in the bracket that holds the plate lights, but the ricer bulbs seem not to stay in as tightly. Just carefully replace it and screw it in, and the bulb will make contact with the internal connectors and it'll work.
Old Jun 27, 2002 | 12:49 PM
2017 GLA 250 4Matic
Plate Light: What Color Looks Best?
I tried replacing the license plate lights with a pair of 10W bulbs. No problems with the fuse and the heat is not immense. I will stick with them, however now it's time to choose a color to match the car's capri blue exterior. Which color bulb you think will look best at night:
blue
purple
ocean blue/green
Feedback is much appreciated. Thanks!
Old Jun 27, 2002 | 01:09 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
i would go with the regular blue.
Old Jun 27, 2002 | 01:21 PM
SoCal240/6's Avatar
'01 C240/6
You have got to be kidding.
What is it with kids and light bulbs???
Old Jun 27, 2002 | 02:13 PM
C230 Sports Coupe
Us "Kids" and our "HATCHBACKS" right SoCal. I guess that means if the kids get the hatchback the the old farts get the sedan? no offense Fuzzo!
Old Jun 27, 2002 | 02:18 PM
2017 GLA 250 4Matic
Good one Timmy!
Old Jun 27, 2002 | 02:52 PM
Fuzzo's Avatar
i'd go wit the blue....
Old Aug 29, 2002 | 02:45 PM
CarlssonPower's Avatar
2002 C240
neon blue
Old Aug 29, 2002 | 03:02 PM
Enze6997's Avatar
E350 Coupe (2010)
"Kleeman Pink"
Old Aug 29, 2002 | 03:32 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Plate Light: What Color Looks Best?
blue
purple
ocean blue/green
Pink, complimented by purple underbody neon.
