Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Rating: Thread Rating: 21 votes, 4.81 average.
Old Mar 2, 2003 | 08:22 PM
  #426
Matt230K's Avatar
2010 C300 4matic
You two are just confused because of the Canada and US difference. In Canada, since they are required, you probably don't have a choice in the menu to turn them off,right?
But tifosiv122, you can still turn off the drl's in the US even if they are xenon's.
And they only run at full intensity because this is the only way they can run. I think they turn off if you try to lower the wattage.
Old Mar 2, 2003 | 09:14 PM
  #427
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Yeah, thats what I meant...thanks.
Erik
Old Mar 11, 2003 | 09:04 PM
  #428
Blueice's Avatar
2002 C320
Question Bi xenon install around LA area
Hello everyone I am getting my Bi-Xenon soon, I hope.. =)
So anyway anyone know a good place I can go to install my xenon light? and which dealer I can go to for the xenon funtion turn on and who should I speek to? I try felcher jones and they are giveing me hard time about turning on the xenon funtion..
THX in advance for the help =)
Old Mar 11, 2003 | 09:25 PM
  #429
JackoOnMyBacko's Avatar
BMW 740iL
go to evo sport down in huntington beach. www.evosport.com
Old Mar 11, 2003 | 09:29 PM
  #430
Class C's Avatar
W203
I can do the install for you... Done several already... PM me!
Old Mar 11, 2003 | 10:46 PM
  #431
oggle's Avatar
E320
Jay I didn't know you do Comand installs now!!
Old Mar 12, 2003 | 02:40 AM
  #432
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
bi xenons...not comands...yet...
greetingz,
Old Mar 12, 2003 | 04:36 AM
  #433
oggle's Avatar
E320
greetingz,
Oops didn't read carefully.
Old Mar 16, 2003 | 02:55 AM
  #434
Lycon's Avatar
BI-Xenon from Steve
Steve is excellent. I just got my Bi-xenon and installed it already. Very Sweet!!! It took only 2 1/2days to reach singapore from when steve sent it out. Excellent service!
Now is the questions time!
Q: When I turn on my lights, and watch the beam projected on a white wall, The light is blue/purple for the the first 15secs, then it slowly changes to yellow/white, maybe more to the yellow side. Is this normal?? Why is it like that?
Q: People said Bi-xenons have high beam as xenon as well. But my high beam is yellow??? However, I have change all my bulbs (ie: daylight and high beam to piaa plasma, so that solves my problem.) But the question is what the hell is bi-xenon if my high beam is yellow before i changed the bulb??
The product from steve is excellent and i still dont regret. It looks awesome, but these are some critical question i need to clarify. So If someone has answers to my questions please reply.
Old Mar 16, 2003 | 09:49 AM
  #435
Matt230K's Avatar
2010 C300 4matic
Re: BI-Xenon from Steve
Xenons are usually a different color when you first turn them on, and change color when they get up to temperature.
Bi-xenons have a cover over half the bulb when you are on low beams. When you switch to high beams, it uncovers the rest of the bulb to give you more xenon light. But it also turns on the halogen high beam in the small inner circle. So you get lots of light, but some of it is xenon and some is halogen.
Old Mar 16, 2003 | 11:00 AM
  #436
Lycon's Avatar
But when you turn them on and when it changes color as the it gets to temperature, doesnt it become more white/blue/purple?
mine loses the blue/purple after 15secs i turn them on. Correct me if Im wroing pls. Thx
you answer to my second question is great. Thx.
Old Mar 16, 2003 | 11:08 AM
  #437
Lynn's Avatar
They are most purple/blue/white when they first come on, then they go towards yellow at operating temperature.
Old Mar 16, 2003 | 11:13 AM
  #438
Class C's Avatar
W203
They should not look yellow, they should look white. Compare them to a car w/ halogens, then you'll see yellow.
If you want to keep the bluish tone, I suggest getting a higher temp like a 6000k bulb for it.
Old Mar 16, 2003 | 11:30 AM
  #439
Lycon's Avatar
class c I understand your bi-xenon was from steve as well. Did you also notice the same thing? How many kelvins is the bulb that comes the bi xenon? Did you change yours?
Old Mar 16, 2003 | 11:35 AM
  #440
Class C's Avatar
W203
Not at all, they are alot whiter than my stock halogens. Blue for about 15 secs or so but it turns white after and not yellow.
You probably need to aim them aswell, try looking at your lights from a distance and not standing up over them.
I believe the stock HID bulbs are 4300k.
Old Mar 16, 2003 | 12:29 PM
  #441
Xeon's Avatar
lycon..
glad to see someone from singapore ( i am a malaysian..studied in sg for 10 yrs)
Old Mar 16, 2003 | 09:34 PM
  #442
oggle's Avatar
E320
Where do you get this type of bulb? Will it require custom modification to the inside of the light fixture or is it just a straight swap?
Old Mar 16, 2003 | 09:38 PM
  #443
Class C's Avatar
W203
Hey Kenny,
It's a direct replacement bulb. I believe Autowerks has carries them. Autowerks Direct
Jay
Old Mar 17, 2003 | 12:20 AM
  #444
Lycon's Avatar
Just to clarify things,
c class, I hope you are talking about bi xenons not halogens.
Old Mar 17, 2003 | 01:40 PM
  #445
Class C's Avatar
W203
Ofcourse I'm taking about the Bi-xenons, they sell direct bulb replacements for them. If your interested in changing the color temp you can go for the 6000k bulb which are blue'r
Jay
Old Mar 17, 2003 | 02:35 PM
  #446
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Talking Xenon...
I had to get my regular xenons replaced about 5 months after I got my car, warranty replacement of course, anyway the light on my factory xenons were way on the cool side (blue) compared to the new replacements. I thought that they put regular halogens by accident at first. Turns out the bulb needs about 2 weeks of use or longer to start changing to that color. They are real blue now(6 months ago), time and usage makes the lights look better. But If you have to replace one of your bulbs, might as well do both. Cause they won't match. My 2¢...
Old Mar 17, 2003 | 08:50 PM
  #447
oggle's Avatar
E320
Thanks Jay.
Old Mar 17, 2003 | 09:33 PM
  #448
Blueice's Avatar
2002 C320
Question Question about turn on xenon
Hello all sorry to trouble you guys! but does any of you know if is ok for me to turn on the xenon funtion before I have the xenon light install? I like to have then turn on before I can get the replacement light [my light got broken by fedex, steve is dealing with fedex now ] I like to have my car ready for the light thx in advance!
Old Mar 17, 2003 | 10:07 PM
  #449
kaduku's Avatar
2000 ML320, 2003 C240
Not Advisable!
Hi,
I would wait for the lights before activating the xenon. First your dealer may not want to activate the xenon, especially when there's no bi-xenon lights installed. Second, your regular lights might malfunction, because the computer is reading xenon, not halogens. You really would like to do these things one time (install, programming, and light alignment). I know your excited, but this is the way I did it. Hope this helps.
Randy
_______________________
C240, ML320, C280, 190E 2.3
Old Mar 17, 2003 | 11:00 PM
  #450
Class C's Avatar
W203
check this thread
https://mbworld.org/forums/showthrea...threadid=24056
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
