Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Aug 20, 2003 | 02:56 AM
  #601
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Originally posted by AMG4Me
Hey Steve,
Will you ever be getting in any Eurospec bi-xenons for the coupe?
I wish...
greetingz,
Old Sep 6, 2003 | 11:53 AM
  #602
djbguitar's Avatar
2003 C240 4Matic
Bi xenon Seller besides the usuals?
Anyone know of any sellers in THE WORLD besides Steve or performance products that sells new Bi Xenon's for a w203???
Any responses would make me very happy.
Old Sep 6, 2003 | 01:10 PM
  #603
djbguitar's Avatar
2003 C240 4Matic
Wink NEVERMINd!!!!
STEVE IS THE MAN!!!!!!!!!!!!!!!!!!!!!
Old Sep 6, 2003 | 02:22 PM
  #604
JAM's Avatar
JAM
SL600
Europarts.com or ClairParts.com will sell them to you for 20% off of dealership prices.
Telephone numbers for each at their websites...
Old Sep 6, 2003 | 03:01 PM
  #605
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
Re: NEVERMINd!!!!
so.. u find steve?? i need him to help me install bi-xenon too..
Old Sep 10, 2003 | 07:29 PM
  #606
Taiwanese's Avatar
2003 C230
03 C230K Sedan Bi-Xenon
I have a 2003 C230 Sedan with OEM Bi-Xenon.
Here is a pic of my Bi-Xenon at night. I feel the light doesn't project far enough.
My other car is a MDX with after market HID. I can see real far at night. I understadn MDX is a higher vehical so the light will project further.
I just feel I can't see far enough while driving at 70mph in my W203 at night.
By the way, the light pattern has a cut out on the driver side.
From the bumper to the valley of the cut out is about 33 feet.
All you W203 owners with OEM bi-Xenons. Do you have the same problem?
Attached Thumbnails Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread-c230.jpg
Old Sep 10, 2003 | 07:55 PM
  #607
Guest0001
Guest
Posts: n/a
yeah you just have to to manualy level it to a higher position. i need to do this as well
did you have it done aftermarket?
Old Sep 10, 2003 | 08:04 PM
  #608
CSportAnt's Avatar
C230 SS
Mine seem not bright enough as well. My sister in law's Bimmer was so much brighter. Have any people here upgraded theirs?
Old Sep 10, 2003 | 08:34 PM
  #609
Matt230K's Avatar
2010 C300 4matic
Re: 03 C230K Sedan Bi-Xenon
The driver's side is always lower so that it does not shine in people's eyes as much.
Old Sep 11, 2003 | 11:07 AM
  #610
mctwin2kman's Avatar
My OEM's are fine. The problem may be the line where the beam ends. On a halogen light the beam blends with the night sky and with the design of the reflectors on the Bi-Xenons the beam just cuts off. You do not notice this on high beams because there is a secondary halogen high beam in the city lamp housing. Maybe yours are adjusted down a hair, I will have to look later and see if there are any adjustments on my coupe lights to raise them mechanically. They also auto adjust on startup, so check at night and make sure they are auto leveling when the vehicle is started. You will notice the ligths lower and then raise back up.
Old Sep 11, 2003 | 11:30 AM
  #611
LorinserCClass's Avatar
The True OG Modded out W203
I think I know what you guys mean. The bixenons are great 10x better than halogens BUT they dont seem to be as luminescent as my Audi's xenons. And not as blue too.
Old Sep 11, 2003 | 12:03 PM
  #612
Taiwanese's Avatar
2003 C230
I have a C4 package when I buy the car. It's not done after market.
Old Sep 11, 2003 | 12:05 PM
  #613
Taiwanese's Avatar
2003 C230
It has auto-leveling. I should not need to adjust it.
Old Sep 11, 2003 | 12:08 PM
  #614
Taiwanese's Avatar
2003 C230
Thanks for all your input.
It's fine for city (low speed) driving. I just don't feel safe when driving on freeway because I can see far enough to avoid stuff on the road or sharp turns.
Old Sep 13, 2003 | 01:34 AM
  #615
peet's Avatar
09 C63
Can someone elaborate on this autoleveling nonsense?
If we turn the lights angle up - thereby increasing distance, will the autoleveler bring the angle inside the housing (the reflector and lense assembly) down without bringing down the housing itself to compensate?
Or is it's job to simply figure out - ok, car is started, lights on - they are in position X and keep them there?
This has been bugging me a while now.
Old Sep 13, 2003 | 05:21 AM
  #616
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
first of all, great screenname...
second, when you have to see far, use the high beam when there's no car in front of you. When you can't use the high beam, it means there's car in front of you, you don't need to see that far.
third, you feel that way probably because you are still used to have street lamps everywhere on the highway like they do in Taiwan, which could cause glare when you are driving at night.
lastly, I don't think you'll be able to adjust the beam height when there's the autoleveling system.
Old Sep 13, 2003 | 01:09 PM
  #617
Lynn's Avatar
Of course you can adjust the headlight aiming on a car with auto-leveling.
Search the internet. There are a number of websites which will show you how to aim the headlights. This initial aiming will provide the baseline to which the auto-leveling system will adjust the aim as the load in the car changes. It seems that the factory aim is often lower than the specs allow.
Old Sep 13, 2003 | 06:33 PM
  #618
rrf's Avatar
rrf
Thumbs up
Lynn,
right on!
Old Sep 13, 2003 | 10:57 PM
  #619
TomGuy's Avatar
2003 C32 AMG
I have a similiar problem also. When driving next to a BMW or Audi, my Bi-Xenons seem more yellowish and not as bright as theirs.
I am thinking it's the design of the headlights. I thought it was the bulb, but my car has around 12k on it and it's still project somewhat yellowish on the road.
Old Sep 14, 2003 | 12:07 AM
  #620
Lynn's Avatar
The bulbs used by Mercedes have a color temperature of 4300 degrees Kelvin, while the others are 6000 degrees Kelvin. So, the BMW's and Audi's will have bluer lights. The 4300 degree bulbs are closer to sunlight and are close to optimal for human vision.
If you really want the bluer light, you can change to the 6000 degree or even higher bulbs. You will pay around $150 per bulb.
Old Sep 14, 2003 | 12:11 AM
  #621
TomGuy's Avatar
2003 C32 AMG
Not really.. All BMWs, Audis and MBs use the same OSRAM 4300K D2S Bulbs. The only difference is the design of the projector and how it projects light onto the road. Those 6000k bulbs are not OEM spec and are not used by any manufacturer.
Check out this page:
http://faq.auto.light.tripod.com/hl-hid-bulbs.htm
Old Sep 14, 2003 | 06:51 AM
  #622
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I'm pretty sure my 2000 328Ci had 4300k xenon bulb. It just appear more blue then the C's xenon.
Old Sep 14, 2003 | 08:29 AM
  #623
Lynn's Avatar
Okay, I will concede that some or even most BMW's and Audi's come with 4300 degree bulbs. But I still believe that some models, especially Audi's have higher temperature bulbs.
Old Sep 14, 2003 | 10:59 AM
  #624
Kar don's Avatar
Mercedes-Benz
I have heard M3's and some other bimmers use 5100K bulbs. not sure tho.
Old Sep 15, 2003 | 04:00 AM
  #625
WhoAmI's Avatar
Look it's yellow.
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
